[RISC-V MCU 应用开发] 【RVBoards-哪吒】T-Head C906的规格书
3923|0
 楼主| jcky001 发表于 2021-8-20 10:08 | 显示全部楼层 |阅读模式
ar, AD, Boards, TE, AN, IO
C906兼容RV64架构,且针对算术运算、内存访问等方面进行了增强,同时标配内存管理单元,可运行Linux操作系统。配有单/双精度浮点引擎,可进一步选配面向AI加速的向量计算引擎,适用于视频监控人工智能等应用领域。
OVERVIEW
  The T-Head C906 processor is based on the RV64GCV instruction set and includes customized arithmetic enhancement extension, bit manipulation extension, load store enhancement extension and TLB/Cache operations enhancement extension. The processor adopts a state of the 5 stages in-order pipeline. The C906 supports the Sv39 virtual address system with custom page attribute extensions. In addition, C906 includes standard CLINT and PLIC interrupt controllers, supports RV-compatible peRFormance monitors.
FEATURES
PERFORMANCE
