SC92F7323+LCD88888
990|0
 楼主| 34af9uc 发表于 2021-8-24 22:51 | 显示全部楼层 |阅读模式
/***************SC92F7323+LCD88888*****************/
/***************QQ:74145445************************/
/*************快手:共同学习STM8********************/
/*************keiluvision2*************************/
/*************20210808*****************************/
//                  lcd88888
//|1|2|3|4|5|6|7|8|9|10|11|12|com4|com3|com2|com1|
//SC92F7323   ________    ________
//        5V-|1 /VDD  \_/  P0.0/28|-com1
//        0V-|2 /VSS       P0.1/27|-com2
//          -|3 /P5.1      P0.2/26|-com3
//          -|4 /P5.0      P0.3/25|-com4
//          -|5 /P1.0      P0.4/24|-lcd_1
//          -|6 /P1.1      P0.5/23|-lcd_2
//       TCK-|7 /P1.2      P0.6/22|-lcd_3
//      TDIO-|8 /P1.3      P0.7/21|-lcd_4
//          -|9 /P1.4      P2.0/20|-lcd_5
//          -|10/P1.5      P2.1/19|-lcd_6
//          -|11/P1.6      P2.2/18|-lcd_7
//  beiguang-|12/P1.7      P2.3/17|-lcd_8
//    lcd_12-|13/P2.7      P2.4/16|-lcd_9
//    lcd_11-|14/P2.6______P2.5/15|-lcd_10
#include <SC92F732x_C.H>
/**************************************************/                //lcd
sbit                lcd_1                =P0^4;
sbit                lcd_2                =P0^5;
sbit                lcd_3                =P0^6;
sbit                lcd_4                =P0^7;
sbit                lcd_5                =P2^0;
sbit                lcd_6                =P2^1;
sbit                lcd_7                =P2^2;
sbit                lcd_8                =P2^3;
sbit                lcd_9                =P2^4;
sbit                lcd_10                =P2^5;
sbit                lcd_11                =P2^6;
sbit                lcd_12                =P2^7;
sbit                beiguang        =P1^7;
unsigned char        lcd_a1;                //第一位
unsigned char        lcd_a2;                //第二位
unsigned char        lcd_a3;                //第三位
unsigned char        lcd_a4;                //第四位
unsigned char        lcd_a5;                //第五位
unsigned        char        xs_a1;                //显示用
unsigned        char        xs_a2;
unsigned        int                xs_a3;
unsigned char code biao[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};                //0-9字模
#define                bit0                0x01
#define                bit1                0x02
#define                bit2                0x04
#define                bit3                0x08
#define                bit4                0x10
#define                bit5                0x20
#define                bit6                0x40
#define                bit7                0x80
#define                com1_gao                P0VO &= ~bit0;        P00=1
#define                com1_ban                P0VO |=bit0
#define                com1_di                        P0VO &= ~bit0;        P00=0
#define                com2_gao                P0VO &= ~bit1;        P01=1
#define                com2_ban                P0VO |=bit1
#define                com2_di                        P0VO &= ~bit1;        P01=0
#define                com3_gao                P0VO &= ~bit2;        P02=1
#define                com3_ban                P0VO |=bit2
#define                com3_di                        P0VO &= ~bit2;        P02=0
#define                com4_gao                P0VO &= ~bit3;        P03=1
#define                com4_ban                P0VO |=bit3
#define                com4_di                        P0VO &= ~bit3;        P03=0
void                lcd_xianshi();                //lcd显示
void                jisuan();                        //计算
void                yanshi();                        //延时
void        main()
//unsigned        char        a1;
xs_a1                =0;
xs_a2                =0;
xs_a3                =0;
/**************************************************/                //液晶初始化
P0CON                |=bit0|bit1|bit2|bit3|bit4|bit5|bit6|bit7;                //输出模式
P2CON                |=bit0|bit1|bit2|bit3|bit4|bit5|bit6|bit7;
OTCON                =bit3|bit2;        //分压电阻87.5k
P1CON                |=bit7;        //背光输出
jisuan();
while(1)
xs_a1        ++;
        if(xs_a1>9)        {xs_a1        =0;}
        xs_a2        ++;
        jisuan();
        if(xs_a2>9)
                xs_a2        =0;
                xs_a3        ++;
                if(xs_a3>9999)        {xs_a3=0;}
lcd_xianshi();
void                lcd_xianshi()                //lcd显示
/**************************************************/                //lcd正控
com1_ban;
com2_ban;
com3_ban;
com4_ban;
if(lcd_a1 & bit5)        {lcd_1 =0;}                else{lcd_1 =1;}                //1f
if(lcd_a1 & bit0)        {lcd_2 =0;}                else{lcd_2 =1;}                //1a
if(lcd_a2 & bit5)        {lcd_3 =0;}                else{lcd_3 =1;}                //2f
if(lcd_a2 & bit0)        {lcd_4 =0;}                else{lcd_4 =1;}                //2a
//if(lcd_xianshi)        {lcd_5 =0;}                else{lcd_5 =1;}                //02竖
lcd_5 =0;
if(lcd_a3 & bit5)        {lcd_6 =0;}                else{lcd_6 =1;}                //3f
if(lcd_a3 & bit0)        {lcd_7 =0;}                else{lcd_7 =1;}                //3a
if(lcd_a4 & bit5)        {lcd_8 =0;}                else{lcd_8 =1;}                //4f
if(lcd_a4 & bit0)        {lcd_9 =0;}                else{lcd_9 =1;}                //4a
if(lcd_a5 & bit5)        {lcd_10 =0;}        else{lcd_10 =1;}        //5f
if(lcd_a5 & bit0)        {lcd_11 =0;}        else{lcd_11 =1;}        //5a
//if(lcd_a)                        {lcd_12 =0;}        else{lcd_12 =1;}        //01锁定
lcd_12 =1;
com1_gao;                //com1高
com2_ban;
com3_ban;
com4_ban;
yanshi();
com1_ban;
com2_ban;
com3_ban;
com4_ban;
if(lcd_a1 & bit6)        {lcd_1 =0;}                else{lcd_1 =1;}                //1g
if(lcd_a1 & bit1)        {lcd_2 =0;}                else{lcd_2 =1;}                //1b
if(lcd_a2 & bit6)        {lcd_3 =0;}                else{lcd_3 =1;}                //2g
if(lcd_a2 & bit1)        {lcd_4 =0;}                else{lcd_4 =1;}                //2b
//if(lcd_a)                        {lcd_5 =0;}                else{lcd_5 =1;}                //防冻
lcd_5 =1;
if(lcd_a3 & bit6)        {lcd_6 =0;}                else{lcd_6 =1;}                //3g
if(lcd_a3 & bit1)        {lcd_7 =0;}                else{lcd_7 =1;}                //3b
if(lcd_a4 & bit6)        {lcd_8 =0;}                else{lcd_8 =1;}                //4g
if(lcd_a4 & bit1)        {lcd_9 =0;}                else{lcd_9 =1;}                //4b
if(lcd_a5 & bit6)        {lcd_10 =0;}        else{lcd_10 =1;}        //5g
if(lcd_a5 & bit1)        {lcd_11 =0;}        else{lcd_11 =1;}        //5b
//if(lcd_a)                        {lcd_12 =0;}        else{lcd_12 =1;}        //中
lcd_12 =1;
com1_ban;
com2_gao;                //com2高
com3_ban;
com4_ban;
yanshi();
com1_ban;
com2_ban;
com3_ban;
com4_ban;
if(lcd_a1 & bit4)        {lcd_1 =0;}                else{lcd_1 =1;}                //1e
if(lcd_a1 & bit2)        {lcd_2 =0;}                else{lcd_2 =1;}                //1c
if(lcd_a2 & bit4)        {lcd_3 =0;}                else{lcd_3 =1;}                //2e
if(lcd_a2 & bit2)        {lcd_4 =0;}                else{lcd_4 =1;}                //2c
//if(lcd_a)                        {lcd_5 =0;}                else{lcd_5 =1;}                //保护
lcd_5 =1;
if(lcd_a3 & bit4)        {lcd_6 =0;}                else{lcd_6 =1;}                //3e
if(lcd_a3 & bit2)        {lcd_7 =0;}                else{lcd_7 =1;}                //3c
if(lcd_a4 & bit4)        {lcd_8 =0;}                else{lcd_8 =1;}                //4e
if(lcd_a4 & bit2)        {lcd_9 =0;}                else{lcd_9 =1;}                //4c
if(lcd_a5 & bit4)        {lcd_10 =0;}        else{lcd_10 =1;}        //5e
if(lcd_a5 & bit2)        {lcd_11 =0;}        else{lcd_11 =1;}        //5c
//if(lcd_a)                        {lcd_12 =0;}        else{lcd_12 =1;}        //加热
lcd_12 =1;
com1_ban;
com2_ban;
com3_gao;                //com3高
com4_ban;
yanshi();
com1_ban;
com2_ban;
com3_ban;
com4_ban;
//if(lcd_a)                        {lcd_1 =0;}                else{lcd_1 =1;}                //室温
lcd_1 =1;
if(lcd_a1 & bit3)        {lcd_2 =0;}                else{lcd_2 =1;}                //1d
//if(lcd_a)                        {lcd_3 =0;}                else{lcd_3 =1;}                //设定摄氏度(显示)
lcd_3 =0;
if(lcd_a2 & bit3)        {lcd_4 =0;}                else{lcd_4 =1;}                //2d
//if(lcd_a){lcd_5 =0;}        else{lcd_5 =1;}                                        //空
lcd_5 =1;
//if(lcd_a)                        {lcd_6 =0;}                else{lcd_6 =1;}                //地温
lcd_6 =1;
if(lcd_a3 & bit3)        {lcd_7 =0;}                else{lcd_7 =1;}                //3d
//if(lcd_a)                        {lcd_8 =0;}                else{lcd_8 =1;}                //℃(显示)
lcd_8 =0;
if(lcd_a4 & bit3)        {lcd_9 =0;}                else{lcd_9 =1;}                //4d
//if(lcd_a)                        {lcd_10 =0;}        else{lcd_10 =1;}        //点(显示)
lcd_10 =0;
if(lcd_a5 & bit3)        {lcd_11 =0;}        else{lcd_11 =1;}        //5d
//if(lcd_a)                        {lcd_12 =0;}        else{lcd_12 =1;}                //停止
lcd_12 =1;
com1_ban;
com2_ban;
com3_ban;
com4_gao;                //com4高
yanshi();
/**************************************************/                //lcd反控
com1_ban;
com2_ban;
com3_ban;
com4_ban;
if(lcd_a1 & bit5)        {lcd_1 =1;}                else{lcd_1 =0;}
if(lcd_a1 & bit0)        {lcd_2 =1;}                else{lcd_2 =0;}
if(lcd_a2 & bit5)        {lcd_3 =1;}                else{lcd_3 =0;}
if(lcd_a2 & bit0)        {lcd_4 =1;}                else{lcd_4 =0;}
//if(lcd_a2){lcd_5 =1;}        else{lcd_5 =0;}                //02竖(显示)
lcd_5 =1;
if(lcd_a3 & bit5)        {lcd_6 =1;}                else{lcd_6 =0;}
if(lcd_a3 & bit0)        {lcd_7 =1;}                else{lcd_7 =0;}
if(lcd_a4 & bit5)        {lcd_8 =1;}                else{lcd_8 =0;}
if(lcd_a4 & bit0)        {lcd_9 =1;}                else{lcd_9 =0;}
if(lcd_a5 & bit5)        {lcd_10 =1;}        else{lcd_10 =0;}
if(lcd_a5 & bit0)        {lcd_11 =1;}        else{lcd_11 =0;}
//if(lcd_a)                        {lcd_12 =1;}        else{lcd_12 =0;}                //01锁定
lcd_12 =0;
com1_di;                //com1低
com2_ban;
com3_ban;
com4_ban;
yanshi();
com1_ban;
com2_ban;
com3_ban;
com4_ban;
if(lcd_a1 & bit6)        {lcd_1 =1;}                else{lcd_1 =0;}
if(lcd_a1 & bit1)        {lcd_2 =1;}                else{lcd_2 =0;}
if(lcd_a2 & bit6)        {lcd_3 =1;}                else{lcd_3 =0;}
if(lcd_a2 & bit1)        {lcd_4 =1;}                else{lcd_4 =0;}                //防冻
//if(lcd_a)                        {lcd_5 =1;}                else{lcd_5 =0;}
lcd_5 =0;
if(lcd_a3 & bit6)        {lcd_6 =1;}                else{lcd_6 =0;}
if(lcd_a3 & bit1)        {lcd_7 =1;}                else{lcd_7 =0;}
if(lcd_a4 & bit6)        {lcd_8 =1;}                else{lcd_8 =0;}
if(lcd_a4 & bit1)        {lcd_9 =1;}                else{lcd_9 =0;}
if(lcd_a5 & bit6)        {lcd_10 =1;}        else{lcd_10 =0;}
if(lcd_a5 & bit1)        {lcd_11 =1;}        else{lcd_11 =0;}
//if(lcd_a)                        {lcd_12 =1;}        else{lcd_12 =0;}                //中
lcd_12 =0;
com1_ban;
com2_di;                //com2低
com3_ban;
com4_ban;
yanshi();
com1_ban;
com2_ban;
com3_ban;
com4_ban;
if(lcd_a1 & bit4)        {lcd_1 =1;}                else{lcd_1 =0;}
if(lcd_a1 & bit2)        {lcd_2 =1;}                else{lcd_2 =0;}
if(lcd_a2 & bit4)        {lcd_3 =1;}                else{lcd_3 =0;}
if(lcd_a2 & bit2)        {lcd_4 =1;}                else{lcd_4 =0;}
//if(lcd_a)                        {lcd_5 =1;}                else{lcd_5 =0;}                //保护
lcd_5 =0;
if(lcd_a3 & bit4)        {lcd_6 =1;}                else{lcd_6 =0;}
if(lcd_a3 & bit2)        {lcd_7 =1;}                else{lcd_7 =0;}
if(lcd_a4 & bit4)        {lcd_8 =1;}                else{lcd_8 =0;}
if(lcd_a4 & bit2)        {lcd_9 =1;}                else{lcd_9 =0;}
if(lcd_a5 & bit4)        {lcd_10 =1;}        else{lcd_10 =0;}
if(lcd_a5 & bit2)        {lcd_11 =1;}        else{lcd_11 =0;}
//if(lcd_a)                        {lcd_12 =1;}        else{lcd_12 =0;}                //加热
lcd_12 =0;
com1_ban;
com2_ban;
com3_di;                //com3低
com4_ban;
yanshi();
com1_ban;
com2_ban;
com3_ban;
com4_ban;
//if(lcd_a)                        {lcd_1 =1;}                else{lcd_1 =0;}                //室温
lcd_1 =0;
if(lcd_a1 & bit3)        {lcd_2 =1;}                else{lcd_2 =0;}
//if(lcd_a)                        {lcd_3 =1;}                else{lcd_3 =0;}                //设定摄氏度(显示)
lcd_3 =1;
if(lcd_a2 & bit3)        {lcd_4 =1;}                else{lcd_4 =0;}
//if(lcd_a)                        {lcd_5 =1;}                else{lcd_5 =0;}                //无
lcd_5 =0;
//if(lcd_a)                        {lcd_6 =1;}                else{lcd_6 =0;}                //地温
lcd_6 =0;
if(lcd_a3  & bit3)        {lcd_7 =1;}                else{lcd_7 =0;}
//if(lcd_a)                        {lcd_8 =1;}                else{lcd_8 =0;}                //℃(显示)
lcd_8 =1;
if(lcd_a4 & bit3)        {lcd_9 =1;}                else{lcd_9 =0;}
//if(lcd_a)                        {lcd_10 =1;}        else{lcd_10 =0;}                //点(显示)
lcd_10 =1;
if(lcd_a5 & bit3)        {lcd_11 =1;}        else{lcd_11 =0;}
//if(lcd_a)                        {lcd_12 =1;}        else{lcd_12 =0;}                //停止
lcd_12 =0;
com1_ban;
com2_ban;
com3_ban;
com4_di;                //com4低
yanshi();
void                jisuan()                        //计算
lcd_a1                =biao[xs_a3/1000];
lcd_a2                =biao[(xs_a3%1000)/100];
lcd_a3                =biao[(xs_a3%100)/10];
lcd_a4                =biao[xs_a3%10];
lcd_a5                =biao[xs_a2%10];
void                yanshi()                        //延时
unsigned        char x,y;
for(x=50;x>0;x--)
        for(y=100;y>0;y--);
lcd555.zip
3.47 KB, 下载次数: 1
319
