下面只需定义一下自己开发板的外部时钟源频率即可:(加个宏定义)
- * @brief In the following line adjust the value of External High Speed oscillator (HSE)
- used in your application
- Tip: To avoid modifying this file each time you need to use different HSE, you
- can define the HSE value in your toolchain compiler preprocessor.
- #define HSE_VALUE ((uint32_t)8000000) // 定义自己开发版上的外部时钟源频率
- #if !defined (HSE_VALUE)
- #define HSE_VALUE ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
- #endif /* HSE_VALUE */
