[KungFu8位 MCU] 急!!!请问如何过EK9软件认证
5178|3
 楼主| machwave 发表于 2021-10-20 21:43 | 显示全部楼层 |阅读模式
Central processing unit(CPU)
1.1
register        Stuck at
1.2 VOID
1.3
Programme counter        Stuck at
Interrupt handling and execution        No interrupt or to frequent interrupt
Clock        Wrong frequency(for quartz synchronized clock : harmonics/sub-harmonics only)
Memory
4.1
Invariable memory        All single bit faults
4.2
Variable memory        DC fault
4.3
Addressing(relevant to variable and invariable memory)        Stack at
Internal data path        Stack at
5.1 VOID
5.2
Addressing        Wrong address
External communication        Hamming distance 3
6.1 VOID
6.2 VOID
6.3
Timing        Wrong point in time
Wrong sequence
Input/output periphery        Fault conditions specified in 19.11.2
7.1 VOID
7.2
Analog I/O
7.2.1
A/D- and D/A- convertor        Fault conditions specified in 19.11.2
7.2.2
Analog multiplexer        Wrong addressing
 楼主| machwave 发表于 2021-10-20 21:51 | 显示全部楼层
在主程序中要对ROM和RAM进行定时读写校验(也可以开机自检一次),并对使用到的寄存器进行读写测试,这个本人没有接触过,哪位达人帮帮忙!
daichaodai 发表于 2021-10-21 18:04 来自手机 | 显示全部楼层
EK9软件认证是什么东东?
自己造声卡 发表于 2021-10-28 08:49 | 显示全部楼层
这个是什么认证,可以告诉一下吗?
