[STM8] STM8S怎么用printf?
1046|3
 楼主| xixi2017 发表于 2021-11-12 11:36 | 显示全部楼层 |阅读模式
不知道怎么使用printf啊,怎么做呢?用的是IAR for STM8
香水城 发表于 2021-11-12 11:50 | 显示全部楼层
STM8的外设库里有相关例程:
\stm8-spl\STM8S_StdPeriph_Lib\Project\STM8S_StdPeriph_Examples\UART1\UART1_Printf
www.st.com/stm8 搜索下 en.stsw-stm8069
 楼主| xixi2017 发表于 2021-11-12 12:25 | 显示全部楼层
STM8的外设库里有相关例程:
\stm8-spl\STM8S_StdPeriph_Lib\Project\STM8S_StdPeriph_Examples\UART1\UAR ...
多谢版主。
 楼主| xixi2017 发表于 2021-11-12 13:34 | 显示全部楼层
  1. /**
  2.   ******************************************************************************
  3.   * [url=home.php?mod=space&uid=288409]@file[/url] UART1_Printf\main.c
  4.   * [url=home.php?mod=space&uid=247401]@brief[/url] This file contains the main function for: retarget the C library printf
  5.   *        /scanf functions to the UART1 example.
  6.   * [url=home.php?mod=space&uid=187600]@author[/url]  MCD Application Team
  7.   * [url=home.php?mod=space&uid=895143]@version[/url] V2.0.4
  8.   * [url=home.php?mod=space&uid=212281]@date[/url]     26-April-2018
  9.   ******************************************************************************
  10.   * @attention
  11.   *
  12.   * <h2><center>&copy; COPYRIGHT 2014 STMicroelectronics</center></h2>
  13.   *
  14.   * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  15.   * You may not use this file except in compliance with the License.
  16.   * You may obtain a copy of the License at:
  17.   *
  18.   *        http://www.st.com/software_license_agreement_liberty_v2
  19.   *
  20.   * Unless required by applicable law or agreed to in writing, software
  21.   * distributed under the License is distributed on an "AS IS" BASIS,
  22.   * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  23.   * See the License for the specific language governing permissions and
  24.   * limitations under the License.
  25.   *
  26.   ******************************************************************************
  27.   */
  28. /* Includes ------------------------------------------------------------------*/
  29. #include "stm8s.h"
  30. #include "stdio.h"
  31. /**
  32.   * @addtogroup UART1_Printf
  33.   * @{
  34.   */
  35. /* Private typedef -----------------------------------------------------------*/
  36. /* Private define ------------------------------------------------------------*/
  37. #ifdef _RAISONANCE_
  38. #define PUTCHAR_PROTOTYPE int putchar (char c)
  39. #define GETCHAR_PROTOTYPE int getchar (void)
  40. #elif defined (_COSMIC_)
  41. #define PUTCHAR_PROTOTYPE char putchar (char c)
  42. #define GETCHAR_PROTOTYPE char getchar (void)
  43. #else /* _IAR_ */
  44. #define PUTCHAR_PROTOTYPE int putchar (int c)
  45. #define GETCHAR_PROTOTYPE int getchar (void)
  46. #endif /* _RAISONANCE_ */
  47. /* Private macro -------------------------------------------------------------*/
  48. /* Private variables ---------------------------------------------------------*/
  49. /* Private function prototypes -----------------------------------------------*/
  50. /* Private functions ---------------------------------------------------------*/
  51. /**
  52.   * @brief  Main program.
  53.   * @param  None
  54.   * @retval None
  55.   */
  56. void main(void)
  57. {
  58.   char ans;
  59.   /*High speed internal clock prescaler: 1*/
  60.   CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV1);
  61.
  62.   UART1_DeInit();
  63.   /* UART1 configuration ------------------------------------------------------*/
  64.   /* UART1 configured as follow:
  65.         - BaudRate = 115200 baud
  66.         - Word Length = 8 Bits
  67.         - One Stop Bit
  68.         - No parity
  69.         - Receive and transmit enabled
  70.         - UART1 Clock disabled
  71.   */
  72.   UART1_Init((uint32_t)115200, UART1_WORDLENGTH_8D, UART1_STOPBITS_1, UART1_PARITY_NO,
  73.               UART1_SYNCMODE_CLOCK_DISABLE, UART1_MODE_TXRX_ENABLE);
  74.   /* Output a message on Hyperterminal using printf function */
  75.   printf("\n\rUART1 Example :retarget the C library printf()/getchar() functions to the UART\n\r");
  76.   printf("\n\rEnter Text\n\r");
  77.   while (1)
  78.   {
  79.     ans = getchar();
  80.     printf("%c", ans);
  81.   }
  82. }
  83. /**
  84.   * @brief Retargets the C library printf function to the UART.
  85.   * @param c Character to send
  86.   * @retval char Character sent
  87.   */
  88. PUTCHAR_PROTOTYPE
  89. {
  90.   /* Write a character to the UART1 */
  91.   UART1_SendData8(c);
  92.   /* Loop until the end of transmission */
  93.   while (UART1_GetFlagStatus(UART1_FLAG_TXE) == RESET);
  94.   return (c);
  95. }
  96. /**
  97.   * @brief Retargets the C library scanf function to the USART.
  98.   * @param None
  99.   * @retval char Character to Read
  100.   */
  101. GETCHAR_PROTOTYPE
  102. {
  103. #ifdef _COSMIC_
  104.   char c = 0;
  105. #else
  106.   int c = 0;
  107. #endif
  108.   /* Loop until the Read data register flag is SET */
  109.   while (UART1_GetFlagStatus(UART1_FLAG_RXNE) == RESET);
  110.     c = UART1_ReceiveData8();
  111.   return (c);
  112. }
  113. #ifdef USE_FULL_ASSERT
  114. /**
  115.   * @brief  Reports the name of the source file and the source line number
  116.   *   where the assert_param error has occurred.
  117.   * @param file: pointer to the source file name
  118.   * @param line: assert_param error line source number
  119.   * @retval None
  120.   */
  121. void assert_failed(uint8_t* file, uint32_t line)
  122. {
  123.   /* User can add his own implementation to report the file name and line number,
  124.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  125.   /* Infinite loop */
  126.   while (1)
  127.   {
  128.   }
  129. }
  130. #endif
  131. /**
  132.   * @}
  133.   */
  134. /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
