[STM32F1] ucgui sendkeymsg收不到问题
1405|13
 楼主| wenfen 发表于 2021-11-13 22:13 | 显示全部楼层 |阅读模式
*                SEGGER MICROCONTROLLER SYSTEME GmbH                 *
#include "GUI.h"
#include "SIM.h"
#include "FRAMEWIN.h"
#include "LISTBOX.h"
#include <stddef.h>
#include "WM.h"
#include "BUTTON.h"
WM_HWIN mainwin;
int status = 0;
static void MainBin**WinCallBack(WM_MESSAGE * pMsg)
    WM_HWIN hWin = pMsg->hWin;
    int i = 0;
    switch (pMsg->MsgId)
    case WM_CREATE:
        //WIDGET_SetDefaultEffect(&WIDGET_Effect_None);
        //LISTBOX_Handle hListBox;
        /* Create the listbox */
        //hListBox = LISTBOX_Create(_aListBox, 100, 100, 120, 75, WM_CF_SHOW);
        //WM_SetFocus(hListBox);
        //LISTBOX_SetFont(hListBox, &GUI_Font13B_1);
        //SCROLLBAR_CreateAttached(hListBox, SCROLLBAR_CF_VERTICAL);
        //BUTTON_CreateAsChild(10,10,10,10,mainwin,5,0);
        WM_SetFocus(mainwin);
        break;
    case WM_PAINT:
        GUI_SetBkColor(GUI_BLACK);
        GUI_Clear();
        GUI_SetColor(GUI_WHITE);
        GUI_SetTextMode(GUI_TM_TRANS);
        GUI_DispStringAt("hello world",50,50);
        GUI_DispDecAt(status,100,100,2);
      //  GUI_DrawBitmap(&sg_start**,
      //                 (MYWIN_XSIZE - sg_start**.XSize) / 2,
      //                  (MYWIN_YSIZE - sg_start**.YSize) / 2);
        break;
    case WM_KEY:
        printf(">>key  aaaaaa        \n");
        switch (((WM_KEY_INFO*)pMsg->Data.p)->Key)
            case 19:
            printf("recv 19");
            status = (status == 0)? 1: 0 ;
            WM_InvalidateWindow(pMsg->hWin);
            break;
        break;
    case WM_DELETE:
        break;
    default:
        WM_DefaultProc(pMsg);
void MainTask(void) {
  GUI_Init();
  /* set callback routine for hardkey */
  //SIM_HARDKEY_SetCallback(1, &_cbKeyUp);
  //SIM_HARDKEY_SetCallback(2, &_cbKeyDown);
  /* start demo */
  mainwin = WM_CreateWindow(0, 0, 300, 300,
                                WM_CF_SHOW | WM_CF_MEMDEV, MainBin**WinCallBack, 0);
  while(1){
    GUI_Exec();
    GUI_Delay(500);
    GUI_SendKeyMsg(19, 1);
chenho 发表于 2021-11-13 22:16 | 显示全部楼层
能否找个这种例子看看差别。
dingy 发表于 2021-11-13 22:18 | 显示全部楼层
https://blog.csdn.net/eryueniao1989/article/details/77989361
看看这个贴能否帮你解决。也可能是你使用这个不正确。
wuhany 发表于 2021-11-13 22:20 | 显示全部楼层
没用过uc,用过free
huangchui 发表于 2021-11-13 22:22 | 显示全部楼层
能确认发送了吗
zhanghqi 发表于 2021-11-13 22:24 | 显示全部楼层
示波器有波形吗
chuxh 发表于 2021-11-13 22:26 | 显示全部楼层
没有用过这个系统
pengf 发表于 2021-11-13 22:28 | 显示全部楼层
uc是免费的吗
 楼主| wenfen 发表于 2021-11-13 22:44 | 显示全部楼层
嗯,我再好好缕一缕吧,有了好消息及时通知大家
drer 发表于 2021-12-7 20:04 | 显示全部楼层
这个是什么函数呢
gwsan 发表于 2021-12-7 20:07 | 显示全部楼层
从来没有用过这个系统
kxsi 发表于 2021-12-7 20:09 | 显示全部楼层
应该就是免费的
nawu 发表于 2021-12-7 20:11 | 显示全部楼层
先确认是不是发送了
qcliu 发表于 2021-12-7 20:12 | 显示全部楼层
可以用示波器看看波形吗
