调试GD32F407xx分享(四)
1094|1
 楼主| QQ2224043166 发表于 2021-12-22 19:05 | 显示全部楼层 |阅读模式
4.TIMvoid GD_TIM_Init(uint32_t timer_periph, uint16_t arr, uint16_t psc)
    timer_parameter_struct timer_initpara;
    timer_ic_parameter_struct timer_icinitpara;
        if(timer_periph == TIMER1)//中断模式
                timer_initpara.period = arr;
                timer_initpara.prescaler = psc;
                timer_initpara.alignedmode = TIMER_COUNTER_EDGE;
                timer_initpara.counterdirection  = TIMER_COUNTER_UP;
                timer_initpara.clockdivision = TIMER_CKDIV_DIV1;
                timer_initpara.repetitioncounter = 0;
                GD_TIM_Base_MspInit(TIMER1);
                timer_init(TIMER1, &timer_initpara);
                timer_update_event_enable(TIMER1);
                timer_interrupt_enable(TIMER1, TIMER_INT_UP);
                timer_flag_clear(TIMER1, TIMER_FLAG_UP);
                timer_update_source_config(TIMER1, TIMER_UPDATE_SRC_GLOBAL);
                timer_enable(TIMER1);
        else if(timer_periph == TIMER3)//编码器
                GD_TIM_Encoder_MspInit(TIMER3);
                timer_init(TIMER3, &timer_initpara);
                /* TIMER3 CH0 input capture configuration */
                timer_icinitpara.icpolarity  = TIMER_IC_POLARITY_RISING;
                timer_icinitpara.icselection = TIMER_IC_SELECTION_DIRECTTI;
                timer_icinitpara.icprescaler = TIMER_IC_PSC_DIV1;
                timer_icinitpara.icfilter    = 0x05;
                timer_input_capture_config(TIMER3,TIMER_CH_0,&timer_icinitpara);
                timer_input_capture_config(TIMER3,TIMER_CH_1,&timer_icinitpara);
            timer_quadrature_decoder_mode_config(TIMER3,TIMER_ENCODER_MODE1,TIMER_IC_POLARITY_RISING,TIMER_IC_POLARITY_RISING);
                timer_interrupt_flag_clear(TIMER3, TIMER_INT_FLAG_CH0);
                timer_interrupt_flag_clear(TIMER3, TIMER_INT_FLAG_CH1);
                timer_interrupt_enable(TIMER3, TIMER_INT_UP);
                timer_interrupt_enable(TIMER3, TIMER_INT_CH0 |TIMER_INT_CH1);
                /* auto-reload preload enable */
//                timer_auto_reload_shadow_enable(TIMER3);
                timer_enable(TIMER3);
void GD_TIM_Base_MspInit(uint32_t timer_periph)
            /* TIM1 clock enable */
                rcu_periph_clock_enable(RCU_TIMER1);
                /* TIM1 interrupt Init */
                nvic_irq_enable(TIMER1_IRQn, 5, 0);
                timer_deinit(TIMER1);
void GD_TIM_Base_MspDeInit(uint32_t timer_periph)
            /* TIM1 clock disable */
                rcu_periph_clock_disable(RCU_TIMER1);
                /* TIM1 interrupt Deinit */
                nvic_irq_disable(TIMER1_IRQn);
//编码器
void GD_TIM_Encoder_MspInit(uint32_t timer_periph)
            /* TIM3 clock enable */
                rcu_periph_clock_enable(RCU_TIMER3);
                /**TIM3 GPIO Configuration
                PD12     ------> TIM3_CH1
                PD13     ------> TIM3_CH2
                gpio_mode_set(GPIOD, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_12|GPIO_PIN_13);
                gpio_output_options_set(GPIOD, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_12|GPIO_PIN_13);
                gpio_af_set(GPIOD, GPIO_AF_2, GPIO_PIN_12|GPIO_PIN_13);
                timer_deinit(TIMER3);
void GD_TIM_Encoder_MspDeInit(uint32_t timer_periph)
            /* TIM3 clock disable */
                rcu_periph_clock_disable(RCU_TIMER3);
                gpio_mode_set(GPIOD, GPIO_MODE_INPUT, GPIO_PUPD_NONE, GPIO_PIN_12|GPIO_PIN_13);
void TIMER1_IRQHandler( void )
    if( timer_interrupt_flag_get(TIMER1, TIMER_INT_FLAG_UP ) != RESET )
        timer_interrupt_flag_clear(TIMER1, TIMER_INT_FLAG_UP);
//timer_counter_value_config(TIMER3, 500); //编码器设置值
//timer_counter_read(TIMER3) //编码器读取值
ychf0000 发表于 2021-12-22 22:24 | 显示全部楼层
支持国产,记录一下
