- DES 加密 8字节为一个数据块
- 实现单、双、三DES加密解密 并实现CBC模式接口
- #include "des.h"
- unsigned char MyKey[8] = "12345678"; // 初始密钥 8字节*8
- void BitsCopy(unsigned char *DatOut, unsigned char *DatIn, int Len); // 数组复制
- void ByteToBit(unsigned char *DatOut, unsigned char *DatIn, int byte_Num); // 字节到位
- void BitToByte(unsigned char *DatOut, unsigned char *DatIn, int byte_Num); // 位到字节
- void TablePermute(unsigned char *DatOut, unsigned char *DatIn, const unsigned char *Table, int Num); // 位表置换函数
- void LoopMove(unsigned char *DatIn, int Len, int Num); // 循环左移 Len长度 Num移动位数
- void Xor(unsigned char *DatA, unsigned char *DatB, int Num); // 异或函数
- void S_Change(unsigned char *DatOut, unsigned char *DatIn); // S盒变换
- void F_Change(unsigned char *DatIn, unsigned char *DatKi); // F函数
- //设置默认密钥 获取子密钥Ki
- void Set_One_DES_64bitKey(unsigned char *KeyIn);
- // 执行DES加密
- void DES_Encrypt_Block(unsigned char *MesIn, unsigned char *MesOut);
- // 执行DES解密
- void DES_Decode_Block(unsigned char *MesIn, unsigned char *MesOut);
- // 对明文执行IP置换得到L0,R0 (L左32位,R右32位) [明文操作]
- const unsigned char IP_Table[64] = {
- 58, 50, 42, 34, 26, 18, 10, 2, 60, 52, 44, 36, 28, 20, 12, 4,
- 62, 54, 46, 38, 30, 22, 14, 6, 64, 56, 48, 40, 32, 24, 16, 8,
- 57, 49, 41, 33, 25, 17, 9, 1, 59, 51, 43, 35, 27, 19, 11, 3,
- 61, 53, 45, 37, 29, 21, 13, 5, 63, 55, 47, 39, 31, 23, 15, 7
- // 对迭代后的L16,R16执行IP逆置换,输出密文
- const unsigned char IPR_Table[64] = {
- 40, 8, 48, 16, 56, 24, 64, 32, 39, 7, 47, 15, 55, 23, 63, 31,
- 38, 6, 46, 14, 54, 22, 62, 30, 37, 5, 45, 13, 53, 21, 61, 29,
- 36, 4, 44, 12, 52, 20, 60, 28, 35, 3, 43, 11, 51, 19, 59, 27,
- 34, 2, 42, 10, 50, 18, 58, 26, 33, 1, 41, 9, 49, 17, 57, 25
- /*--------------------------- 迭代法则 ----------------------------*/
- // F函数,32位的R0进行E变换,扩为48位输出 (R1~R16) [备用A] [明文操作]
- const unsigned char E_Table[48] = {
- 32, 1, 2, 3, 4, 5, 4, 5, 6, 7, 8, 9,
- 8, 9, 10, 11, 12, 13, 12, 13, 14, 15, 16, 17,
- 16, 17, 18, 19, 20, 21, 20, 21, 22, 23, 24, 25,
- 24, 25, 26, 27, 28, 29, 28, 29, 30, 31, 32, 1
- // 子密钥K(i)的获取 密钥为K 抛弃第6,16,24,32,40,48,64位 [密钥操作]
- // 用PC1选位 分为 前28位C0,后28位D0 两部分
- const unsigned char PC1_Table[56] = {
- 57, 49, 41, 33, 25, 17, 9, 1, 58, 50, 42, 34, 26, 18,
- 10, 2, 59, 51, 43, 35, 27, 19, 11, 3, 60, 52, 44, 36,
- 63, 55, 47, 39, 31, 23, 15, 7, 62, 54, 46, 38, 30, 22,
- 14, 6, 61, 53, 45, 37, 29, 21, 13, 5, 28, 20, 12, 4
- // 对C0,D0分别进行左移,共16次,左移位数与下面对应 [密钥操作]
- const unsigned char Move_Table[16] = {
- 1, 1, 2, 2, 2, 2, 2, 2, 1, 2, 2, 2, 2, 2, 2, 1
- // C1,D1为第一次左移后得到,进行PC2选位,得到48位输出K1 [备用B] [密钥操作]
- const unsigned char PC2_Table[48] = {
- 14, 17, 11, 24, 1, 5, 3, 28, 15, 6, 21, 10,
- 23, 19, 12, 4, 26, 8, 16, 7, 27, 20, 13, 2,
- 41, 52, 31, 37, 47, 55, 30, 40, 51, 45, 33, 48,
- 44, 49, 39, 56, 34, 53, 46, 42, 50, 36, 29, 32
- /*------------- F函数 备用A和备用B 异或 得到48位输出 ---------------*/
- // 异或后的结果48位分为8组,每组6位,作为8个S盒的输入 [组合操作]
- // S盒以6位作为输入(8组),4位作为输出(4*(8组)=32位)
- // S工作原理 假设输入为A=abcdef ,则bcde所代表的数是0-15之间的
- // 一个数记为 X=bcde ,af代表的是0-3之间的一个数,记为 Y=af
- // 在S1的X列,Y行找到一个数Value,它在0-15之间,可以用二进制表示
- // 所以为4bit (共32位)
- const unsigned char S_Box[8][4][16] = {
- // S1
- 14, 4, 13, 1, 2, 15, 11, 8, 3, 10, 6, 12, 5, 9, 0, 7,
- 0, 15, 7, 4, 14, 2, 13, 1, 10, 6, 12, 11, 9, 5, 3, 8,
- 4, 1, 14, 8, 13, 6, 2, 11, 15, 12, 9, 7, 3, 10, 5, 0,
- 15, 12, 8, 2, 4, 9, 1, 7, 5, 11, 3, 14, 10, 0, 6, 13,
- // S2
- 15, 1, 8, 14, 6, 11, 3, 4, 9, 7, 2, 13, 12, 0, 5, 10,
- 3, 13, 4, 7, 15, 2, 8, 14, 12, 0, 1, 10, 6, 9, 11, 5,
- 0, 14, 7, 11, 10, 4, 13, 1, 5, 8, 12, 6, 9, 3, 2, 15,
- 13, 8, 10, 1, 3, 15, 4, 2, 11, 6, 7, 12, 0, 5, 14, 9,
- // S3
- 10, 0, 9, 14, 6, 3, 15, 5, 1, 13, 12, 7, 11, 4, 2, 8,
- 13, 7, 0, 9, 3, 4, 6, 10, 2, 8, 5, 14, 12, 11, 15, 1,
- 13, 6, 4, 9, 8, 15, 3, 0, 11, 1, 2, 12, 5, 10, 14, 7,
- 1, 10, 13, 0, 6, 9, 8, 7, 4, 15, 14, 3, 11, 5, 2, 12,
- // S4
- 7, 13, 14, 3, 0, 6, 9, 10, 1, 2, 8, 5, 11, 12, 4, 15,
- 13, 8, 11, 5, 6, 15, 0, 3, 4, 7, 2, 12, 1, 10, 14, 9,
- 10, 6, 9, 0, 12, 11, 7, 13, 15, 1, 3, 14, 5, 2, 8, 4,
- 3, 15, 0, 6, 10, 1, 13, 8, 9, 4, 5, 11, 12, 7, 2, 14,
- // S5
- 2, 12, 4, 1, 7, 10, 11, 6, 8, 5, 3, 15, 13, 0, 14, 9,
- 14, 11, 2, 12, 4, 7, 13, 1, 5, 0, 15, 10, 3, 9, 8, 6,
- 4, 2, 1, 11, 10, 13, 7, 8, 15, 9, 12, 5, 6, 3, 0, 14,
- 11, 8, 12, 7, 1, 14, 2, 13, 6, 15, 0, 9, 10, 4, 5, 3,
- // S6
- 12, 1, 10, 15, 9, 2, 6, 8, 0, 13, 3, 4, 14, 7, 5, 11,
- 10, 15, 4, 2, 7, 12, 9, 5, 6, 1, 13, 14, 0, 11, 3, 8,
- 9, 14, 15, 5, 2, 8, 12, 3, 7, 0, 4, 10, 1, 13, 11, 6,
- 4, 3, 2, 12, 9, 5, 15, 10, 11, 14, 1, 7, 6, 0, 8, 13,
- // S7
- 4, 11, 2, 14, 15, 0, 8, 13, 3, 12, 9, 7, 5, 10, 6, 1,
- 13, 0, 11, 7, 4, 9, 1, 10, 14, 3, 5, 12, 2, 15, 8, 6,
- 1, 4, 11, 13, 12, 3, 7, 14, 10, 15, 6, 8, 0, 5, 9, 2,
- 6, 11, 13, 8, 1, 4, 10, 7, 9, 5, 0, 15, 14, 2, 3, 12,
- // S8
- 13, 2, 8, 4, 6, 15, 11, 1, 10, 9, 3, 14, 5, 0, 12, 7,
- 1, 15, 13, 8, 10, 3, 7, 4, 12, 5, 6, 11, 0, 14, 9, 2,
- 7, 11, 4, 1, 9, 12, 14, 2, 0, 6, 10, 13, 15, 3, 5, 8,
- 2, 1, 14, 7, 4, 10, 8, 13, 15, 12, 9, 0, 3, 5, 6, 11
- // F函数 最后第二步,对S盒输出的32进行P置换 [组合操作]
- // 输出的值参与一次迭代:
- // L(i)=R(i-1)
- // R(i)=L(i-1)^f(R(i-1),K(i)) 异或
- const unsigned char P_Table[32] = {
- 16, 7, 20, 21, 29, 12, 28, 17, 1, 15, 23, 26, 5, 18, 31, 10,
- 2, 8, 24, 14, 32, 27, 3, 9, 19, 13, 30, 6, 22, 11, 4, 25
- // 16个子密钥K(1~16)
- static unsigned char SubKey[16][48] = { 0 };
- 把DatIn开始的长度位Len位的二进制
- 复制到DatOut后
- void BitsCopy(unsigned char *DatOut, unsigned char *DatIn, int Len) // 数组复制 OK
- int i = 0;
- for (i = 0; i < Len; i++)
- DatOut[i] = DatIn[i];
- 字节转换成位函数
- byte_Num 多少个字节
- void ByteToBit(unsigned char *DatOut, unsigned char *DatIn, int byte_Num) // OK
- int i = 0;
- for (i = 0; i < byte_Num * 8; i++)
- //低bit在缓存高地址
- DatOut[i] = ((DatIn[i / 8] << (i % 8)) & 0x80) ? 1 : 0;
- 位转换成字节函数
- byte_Num: 多少个字节
- void BitToByte(unsigned char *DatOut, unsigned char *DatIn, int byte_Num) // OK
- int i = 0;
- for (i = 0; i < byte_Num; i++) //先把数据清零
- DatOut[i] = 0;
- DatOut[i / 8] = (DatOut[i / 8] << 1) | DatIn[i]; //低bit在缓存高地址
- // 表置换函数 OK
- int i = 0;
- unsigned char Temp[256] = { 0 };
- for (i = 0; i < Num; i++) // Num为置换的长度
- Temp[i] = DatIn[Table[i] - 1]; // 原来的数据按对应的表上的位置排列
- BitsCopy(DatOut, Temp, Num); // 把缓存Temp的值输出
- // 子密钥的移位
- void LoopMove(unsigned char *DatIn, int Len, int Num) // 循环左移 Len数据长度 Num移动位数
- unsigned char Temp[10] = { 0 }; // 缓存
- BitsCopy(Temp, DatIn, Num); // 将数据最左边的Num位(被移出去的)存入Temp
- BitsCopy(DatIn, DatIn + Num, Len - Num); // 将数据左边开始的第Num移入原来的空间
- BitsCopy(DatIn + Len - Num, Temp, Num); // 将缓存中移出去的数据加到最右边
- // 按位异或
- void Xor(unsigned char *DatA, unsigned char *DatB, int Num) // 异或函数
- int i = 0;
- DatA[i] = DatA[i] ^ DatB[i]; // 异或
- // 输入48位 输出32位 与Ri异或。
- //把48bit 数据分成八组 进入八个S盒 得到8个十进制数,把8个十进制数转换成32位bit串
- void S_Change(unsigned char *DatOut, unsigned char *DatIn) // S盒变换
- int i, X, Y; // i为8个S盒
- unsigned char data[8]; //S盒中的数据
- for (i = 0, Y = 0, X = 0; i < 8; i++, DatIn += 6) // 每执行一次,输入数据偏移6位
- { // 每执行一次,输出数据偏移4位
- Y = (DatIn[0] << 1) + DatIn[5]; // af代表第几行
- X = (DatIn[1] << 3) + (DatIn[2] << 2) + (DatIn[3] << 1) + DatIn[4]; // bcde代表第几列
- data[i] = S_Box[i][Y][X]; //得到S盒中的数据 4bit 数据
- // 把找到的点数据换为二进制
- for (i = 0; i < 8; i++)
- DatOut[i * 4 + 0] = (data[i] & 0x08) ? 1 : 0; //最高位
- DatOut[i * 4 + 1] = (data[i] & 0x04) ? 1 : 0;
- DatOut[i * 4 + 2] = (data[i] & 0x02) ? 1 : 0;
- DatOut[i * 4 + 3] = (data[i] & 0x01) ? 1 : 0;
- // F函数
- void F_Change(unsigned char *DatIn, unsigned char *DatKi) // F函数
- unsigned char MiR[48] = { 0 }; // 输入32位通过E选位变为48位
- TablePermute(MiR, DatIn, E_Table, 48); //把32bit 数据扩展到 48bit
- Xor(MiR, DatKi, 48); // 和子密钥异或
- S_Change(DatIn, MiR); // S盒变换 把48bit 数据分成八组 进入八个S盒
- TablePermute(DatIn, DatIn, P_Table, 32); // P置换后输出 32bit串
- //设置默认密钥 获取子密钥Ki
- int i = 0;
- unsigned char KeyBit[64] = { 0 }; // 密钥二进制存储空间
- unsigned char *KiL = &KeyBit[0]; //前28
- unsigned char *KiR = &KeyBit[28]; //后28共56
- ByteToBit(KeyBit, KeyIn, 8); // 把密钥转为二进制存入KeyBit
- TablePermute(KeyBit, KeyBit, PC1_Table, 56); // PC1表置换 56次
- for (i = 0; i < 16; i++)
- LoopMove(KiL, 28, Move_Table[i]); // 前28位左移
- LoopMove(KiR, 28, Move_Table[i]); // 后28位左移
- TablePermute(SubKey[i], KeyBit, PC2_Table, 48); //得到48位 子秘钥
- // 二维数组 SubKey[i]为每一行起始地址
- // 每移一次位进行PC2置换得 Ki 48位
- // 执行DES加密
- { // 字节输入 Bin运算 Hex输出
- int i = 0;
- unsigned char MesBit[64] = { 0 }; // 明文二进制存储空间 64位
- unsigned char Temp[32] = { 0 };
- unsigned char *MiL = &MesBit[0];//前32位
- unsigned char *MiR = &MesBit[32]; // 后32位
- ByteToBit(MesBit, MesIn, 8); // 把明文换成二进制存入MesBit
- TablePermute(MesBit, MesBit, IP_Table, 64); // IP置换
- for (i = 0; i < 16; i++) // 迭代16次
- BitsCopy(Temp, MiL, 32); // 临时存储 备份 Li-1
- BitsCopy(MiL, MiR, 32); // 得到Li Li = Ri-1
- F_Change(MiR, SubKey[i]); // F函数变换 进行E扩展 变成48位 与子秘钥异或
- Xor(MiR, Temp, 32); // 得到Ri Ri =Li-1 异或 F(Ri-1,Ki)
- //最后一轮要改变左右32bit位置 Ri在前 Li 在后进行合并 合并后进行IP逆置换
- BitsCopy(Temp, MiL, 32); //把左边 32bit 备份
- BitsCopy(MesBit, MiR, 32); //把右32位 移到前面
- BitsCopy(&MesBit[32], Temp, 32); //把前32位 移到后面 合并完成
- TablePermute(MesBit, MesBit, IPR_Table, 64); //进行IP逆置换
- BitToByte(MesOut, MesBit, 8);
- // 执行DES解密
- { // Hex输入 Bin运算 字节输出
- int i = 0;
- unsigned char MesBit[64] = { 0 }; // 密文二进制存储空间 64位
- unsigned char *MiL = &MesBit[0]; //前32位
- F_Change(MiR, SubKey[15 - i]); // F函数变换 进行E扩展 变成48位 与子秘钥异或
- //最后一轮需要左右对换 Ri在前 Li 在后进行合并 合并后进行IP逆置换
- 以下函数加入 DES算法 向量 为CBC加密模式 提供接口
- 一、加密过程 :
- 密文块0 = (明文0 异或 IV )的结果 用秘钥加密
- 密文块1 = (明文1 异或 密文块0) 的结果 用秘钥加密
- 二、解密过程 :
- 1、先用秘钥对密文解密 得到 数据 X0
- 2、X0 异或 向量 得到明文
- 3、前一个数据的密文块 为后一个数据块的向量
- //执行单DES加密 加密一个块 8字节数据
- //IV_IN_OUT: 初始化向量输入 密文输出 为空时则无向量值(CBC模式加密时,前一个数据的密文为后一个明文块的向量)
- //Mes_IN_OUT: 明文输入 密文输出
- //Key64bit: 64bit 秘钥 8字节
- void One_DES_IV_Encrypt_Block(unsigned char *IV_IN_OUT, unsigned char *Mes_IN_OUT, unsigned char *Key64bit)
- unsigned char temp[8];
- if (Key64bit == NULL) //秘钥不能为空
- return;
- if (IV_IN_OUT != NULL)
- Xor(Mes_IN_OUT, IV_IN_OUT, 8); //先把明文数据与加密向量 异或 如果向量全为0 则不改变明文的值
- Set_One_DES_64bitKey(Key64bit); //设置秘钥 生成子秘钥
- DES_Encrypt_Block(Mes_IN_OUT, temp); //执行DES加密 密文保存在 temp 中
- BitsCopy(IV_IN_OUT, temp, 8); //把密文拷贝到向量缓存中
- BitsCopy(Mes_IN_OUT, temp, 8); //把密文拷贝到明文数据缓存中
- //执行单DES解密 解密一个块 8字节数据
- //IV_IN_OUT: 初始化向量输入 原密文输出 为空时则无向量值(CBC模式解密时,前一个数据块的密文为后一个密文块解密后的向量)
- //Mes_IN_OUT: 密文输入 明文输出
- void One_DES_IV_Decode_Block(unsigned char *IV_IN_OUT, unsigned char *Mes_IN_OUT, unsigned char *Key64bit)
- return;
- DES_Decode_Block(Mes_IN_OUT, temp); //执行DES解密 解密的结果保存在 temp 中
- Xor(temp, IV_IN_OUT, 8); //把解密后的结果与向量异或得到明文 如果向量全为0 则不改变值
- BitsCopy(IV_IN_OUT, Mes_IN_OUT, 8); //把原密文拷贝到向量数据缓存中
- BitsCopy(Mes_IN_OUT, temp, 8); //把明文拷贝到密文数据缓存中
- //执行双DES加密 加密一个块 8字节数据 加密顺序 左加密 右解密 左加密
- //IV_IN_OUT: 初始化向量输入 密文输出 (CBC模式加密时,前一个数据的密文为后一个明文块的向量)
- //Key128bit: 128bit 秘钥 16字节
- void Two_DES_IV_Encrypt_Block(unsigned char *IV_IN_OUT, unsigned char *Mes_IN_OUT, unsigned char *Key128bit)
- if (Key128bit == NULL)
- return;
- Set_One_DES_64bitKey(Key128bit); //设置秘钥 生成子秘钥 左边8字节秘钥
- Set_One_DES_64bitKey(&Key128bit[8]); //设置秘钥 生成子秘钥 右边8字节秘钥
- DES_Decode_Block(temp, temp); //执行DES解密 结果保存在 temp 中
- DES_Encrypt_Block(temp, temp); //执行DES加密 密文保存在 temp 中
- //执行双DES解密 解密一个块 8字节数据 解密流程 左解密 右加密 左解密
- void Two_DES_IV_Decode_Block(unsigned char *IV_IN_OUT, unsigned char *Mes_IN_OUT, unsigned char *Key128bit)
- if (Key128bit == NULL) //秘钥不能为空
- return;
- DES_Decode_Block(temp, temp); //执行DES解密 解密的结果保存在 temp 中
- //执行三DES加密 加密一个块 8字节数据 加密顺序 左加密 中解密 右加密
- //Key192bit: 192bit 秘钥 24字节
- void Three_DES_IV_Encrypt_Block(unsigned char *IV_IN_OUT, unsigned char *Mes_IN_OUT, unsigned char *Key192bit)
- if (Key192bit == NULL)
- return;
- Set_One_DES_64bitKey(Key192bit); //设置秘钥 生成子秘钥 左边8字节秘钥
- Set_One_DES_64bitKey(&Key192bit[8]); //设置秘钥 生成子秘钥 中间8字节秘钥
- Set_One_DES_64bitKey(&Key192bit[16]); //设置秘钥 生成子秘钥 右边8字节秘钥
- //执行三DES解密 解密一个块 8字节数据 解密流程 右解密 中加密 左解密
- void Three_DES_IV_Decode_Block(unsigned char *IV_IN_OUT, unsigned char *Mes_IN_OUT, unsigned char *Key192bit)
- if (Key192bit == NULL) //秘钥不能为空
- return;
- *@函数名:数据DES加密函数
- *@函数入口:
- * Plaintext 明文
- * Ciphertext 密文
- * Key 秘钥
- * PlaintextLen 明文长度
- *@说明:本函数可以对任意长度的数据进行加密(HXE和ASCII均可),
- * 数据长度不足8字节整数倍时,将自动在末尾凑0后加密。
- * 密文的长度为8的整数倍,例如明文长12,则密文长16;明文长4,密文长8。(向上取8整)
- * 密钥长64位(即八个字节,HXE和ASCII均可)
- void DES_DataEncrypt(unsigned char * Plaintext, unsigned char * Ciphertext, unsigned char * Key, unsigned int PlaintextLen)
- unsigned char EncryptionAliquot =PlaintextLen/8; //加密整数部分
- unsigned char EncryptionRest=PlaintextLen%8; //不足8字节余数
- unsigned char EncryptionBlock=0; //加密块个数
- // unsigned char temp_plaintext=0; //临时明文缓冲区(负责缓冲和补0)
- unsigned char i;
- if(EncryptionRest!=0){ //计算加密块
- EncryptionBlock=EncryptionAliquot+1;
- else{
- EncryptionBlock=EncryptionAliquot;
- for(i=0;i<EncryptionBlock;i++)
- One_DES_IV_Encrypt_Block(NULL,&Plaintext[0+i*8],Key);
- *@函数名:数据DES解密函数
- *@函数入口:
- * Ciphertext 密文
- * Plaintext 明文
- * Key 秘钥
- * CiphertextLen 密文长度
- *@说明:密文长度必须为8的整数倍(即x个加密块),否则函数将直接返回
- void DES_DataDecrypt(unsigned char * Ciphertext,unsigned char * Plaintext,unsigned char * Key,unsigned int CiphertextLen)
- unsigned char i;
- EncryptionBlock=CiphertextLen/8;
- if( (CiphertextLen%8) != 0 )
- { //计算加密块
- EncryptionBlock=EncryptionBlock+1;
- One_DES_IV_Decode_Block(NULL,&Ciphertext[0+i*8],Key);
主函数里面把做一下串口数据的解析就好了
- while (1)
- if( Time_out > 0 ) //串口接收超时
- Time_out--;
- if( Time_out==0 )
- Time_out_flag = 1;
- if( Time_out_flag == 1 ) //数据加解密
- DES_DataDecrypt( RxBuffer1, NULL, MyKey, Rx_num ); //解密
- // DES_DataEncrypt( RxBuffer1, NULL, MyKey, Rx_num ); //加密
- if( Rx_num%8 != 0 )
- Rx_num = (Rx_num/8+1)*8;
- for( i=0;i<Rx_num;i++ )
- USART_SendData(USARTy,RxBuffer1[i]);
- while (USART_GetFlagStatus(USARTy, USART_FLAG_TXDE) == RESET);
- Rx_num = 0;
- Time_out_flag = 0;
- for( i=0;i<64;i++ )
- RxBuffer1[i] = 0;
- Delay(100000);
以下为明文加密,长度不限制:
以下为密文解密:
END
