| 按遥控器发射红外信号程序进入中断后会一直卡在 while (IRIN);       //等 IR 变为低电平  是不是单片机检测不到红外接收头发出的低电平啊 还是什么原因 求大神解释 #include <reg52.h>
 void LCD_write_com(unsigned char com);
 void LCD_write_data(unsigned char data);
 void LCD_clear(void);
 //void Clock_Init();
 void LCD_write_str(unsigned char x,unsigned char y,unsigned char *s);
 void LCD_write_char(unsigned char x,unsigned char y,unsigned char data);
 void LCD_init(void);
 void Port_init();
 #define RS_CLR P1OUT &= ~0x01       //RS置低P1.0 = 0
 #define RS_SET P1OUT |= 0x01        //RS置高P1.0 = 1
 #define RW_CLR P1OUT &= ~0x08     //RW置低
 #define RW_SET P1OUT |= 0x08      //RW置高
 #define EN_CLR P1OUT &= ~0x04       //E置低
 #define EN_SET P1OUT |= 0x04
 #define DataPort      P2OUT
 typedef unsigned char uchar;
 typedef unsigned int uint;
 #define CPU_F ((double)1000000)
 #define delay_us(x) __delay_cycles((long)(CPU_F*(double)x/1000000.0))
 #define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0))
 #define IR_DIR_IN   P1DIR&=~BIT1 //红外接收头P1.1设置为输入,
 #define IRIN        (P1IN&BIT1)   //红外接收头输入值
 char data[4];                     //保存地址码,地址反码,数据码,数据反码
 char m;
 void xianshi();
 unsigned char num_char_table[]={"0123456789"};
 unsigned char temp;
 系统初始化
 void InitSys()
 WDTCTL = WDTPW + WDTHOLD;         //关闭看门狗
 DCOCTL=CALDCO_1MHZ;
 BCSCTL1=CALBC1_1MHZ;
 P1IE|=BIT1;      //P1.1中断功能打开
 P1IES|=BIT1;    //P1.1下降沿触发中断
 IR_DIR_IN;      //P1.1设置为输入
 _EINT();        //打开全局中断控制
 int main( void )
 InitSys(); //初始化
 Port_init();
 //delay_ms(100);
 LCD_init();
 LCD_clear();
 while(1)
 xianshi();
 void xianshi()
 LCD_write_str(0,0,"temperature:");
 LCD_write_char(0,1,num_char_table[temp/100]);
 LCD_write_char(1,1,num_char_table[temp%100/10]);
 LCD_write_char(2,1,'.');
 LCD_write_char(3,1,num_char_table[temp%10]);
 //LCD_write_char(4,1,num_char_table[0]);
 LCD_write_str(5,1,"'C");
 端口1中断函数
 #pragma vector=PORT1_VECTOR
 __interrupt void Port1()
 char i,j,k=0,m=1;
 if((P1IFG&BIT1) == BIT1)
 P1IFG &= ~BIT1;         //清除P1.1中断标志
 P1IE &=~BIT1;           //关闭P1.1中断功能
 for (i=0;i<8;i++)        //等待9ms引导码,在9ms内出现高电平则退出解码
 delay_ms(1);
 if (IRIN==1) m=0;
 while(!IRIN);        //等 IR 变为高电平
 delay_ms(4);         //等待4.5ms结果码
 if(m==1)
 for(k=0;k<4;k++)
 for (j=0;j<8;j++)
 delay_us(500);      //等待560us低电平
 while (!IRIN);     //等 IR 变为高电平
 char n=0;
 while (IRIN)       //计算IR高电平时长
 delay_us(140);
 n++;
 data[k]=data[k]>>1;
 if (n<7) {data[k]&=0x7f;}
 else
 if(n>=7&&n<13)
 {data[k]|=0x80;}
 else
 if (n>=13)
 P1IE|=BIT1;
 temp=data[2];
 P1IE|=BIT1;
 void Port_init()
 P2SEL = 0x00;
 P2DIR = 0xFF;     //  设置为输出状态
 P1SEL = 0x00;
 //P2DIR |= BIT5 + BIT6 + BIT7;//为什么呢? RS/RW/EN赋值是给P2.0—P2.2的,
 P1DIR |= BIT0 + BIT3 + BIT2;     //P2口德567位设置为输出 01234作为输入
 //控制口设置为输出模式
 //显示屏命令写入函数
 RS_CLR;//P2.0 = 0
 RW_CLR;//P2.1 = 0
 EN_SET;//P2.2 = 1                 允许写入数据
 DataPort = com;                 //写入的命令
 delay_ms(5);
 EN_CLR;//写入结束,P2.2 = 0;关闭写入
 //显示屏数据写入函数
 RS_SET;//P2.0 = 1;
 RW_CLR;//P2.1 = 0;
 EN_SET;//P2.2 = 1;
 DataPort = data;                //??????
 delay_ms(5);
 EN_CLR;//P2.2 = 0;
 // 显示屏清空显示
 LCD_write_com(0x01);            //清屏幕显示
 delay_ms(5);
 // 显示屏字符串写入函数
 if (y == 0)
 LCD_write_com(0x80 + x);        //第一行显示
 else
 LCD_write_com(0xC0 + x);        //第二行显示
 while (*s)
 LCD_write_data( *s);
 s++;
 // 显示屏单字符写入函数
 if (y == 0)
 else
 LCD_write_data( data);
 // 显示屏初始化函数
 void LCD_init(void)
 LCD_write_com(0x38);  //显示模式设置
 delay_ms(5);
 LCD_write_com(0x08);  //显示关闭
 delay_ms(5);
 LCD_write_com(0x01);  //显示清屏
 delay_ms(5);
 LCD_write_com(0x06);  //显示光标移动设置
 delay_ms(5);
 LCD_write_com(0x0C);  //显示开机光标设置
 delay_ms(5);
