[PCB] WALLYS wifi6 Qualcomm IPQ6010 QCN9074 wifi card 802.11AX MU MIMO OFDMA
1374|0
 楼主| wirelesswifi6 发表于 2022-3-16 09:44 | 显示全部楼层 |阅读模式
DR6018-S
Support OpenWRT, Support:QCN9074 WiFi Card
Support OpenWRT IPQ6010 802.11ax 2x2 2.4G&5G
DR6018-S V02 IPQ6010/IPQ6018/IPQ6000
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
8MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48V(DC Jack)
    V
    Operating Temperature Range
    -40 to +70
    ºC
    Storage Temperature Range
    -45 to +105
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm-Atheros IPQ6010
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
    SD Card Slot
    1x SD Card Slot(Option)
    USB /header
    1x USB 3.0 Port(Option)
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V~48V power supply
    LED header
    2.0 pitch pin header
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    Nor Flash
    8MB
    Nand Flash
    256MB
    DDR
    256MB~512MB
    Dimension
    125mm x 105mm x 20mm
    Radio TX Specifications(5180MHz-5825MHz)
    Operating Mode
    Data Rate
    Power
    Tolerance
    1 Chain
    2 Chains
    5Ghz 802.11ax HE20
    MCS0
    20dBm
    23dbm
    ±2dB
    MCS1
    20dBm
    23dBm
    ±2dB
    MCS2
    20dBm
    23dBm
    ±2dB
    MCS3
    20dBm
    23dBm
    ±2dB
    MCS4
    19dBm
    22dBm
    ±2dB
    MCS5
    18dBm
    21dBm
    ±2dB
    MCS6
    17dBm
    20dBm
    ±2dB
    MCS7
    16dBm
    19dBm
    ±2dB
    MCS8
    15dBm
    18dBm
    ±2dB
    MCS9
    14dBm
    17dBm
    ±2dB
    MCS10
    13dBm
    16dBm
    ±2dB
    MCS11
    13dBm
    16dbm
    ±2dB
    5Ghz 802.11ax HE400
    MCS0
    20dBm
    23dbm
    ±2dB
    MCS1
    20dBm
    23dBm
    ±2dB
    MCS2
    20dBm
    23dBm
    ±2dB
    MCS3
    20dBm
    23dBm
    ±2dB
    MCS4
    19dBm
    22dBm
    ±2dB
    MCS5
    18dBm
    21dBm
    ±2dB
    MCS6
    17dBm
    20dBm
    ±2dB
    MCS7
    16dBm
    19dBm
    ±2dB
    MCS8
    15dBm
    18dBm
    ±2dB
    MCS9
    14dBm
    17dBm
    ±2dB
    MCS10
    13dBm
    16dBm
    ±2dB
    MCS11
    13dBm
    16dbm
    ±2dB
    5Ghz 802.11ax HE80
    MCS0
    20dBm
    23dbm
    ±2dB
    MCS1
    20dBm
    23dBm
    ±2dB
    MCS2
    20dBm
    23dBm
    ±2dB
    MCS3
    20dBm
    23dBm
    ±2dB
    MCS4
    19dBm
    22dBm
    ±2dB
    MCS5
    18dBm
    21dBm
    ±2dB
    MCS6
    17dBm
    20dBm
    ±2dB
    MCS7
    16dBm
    19dBm
    ±2dB
    MCS8
    15dBm
    18dBm
    ±2dB
    MCS9
    14dBm
    17dBm
    ±2dB
    MCS10
    13dBm
    16dBm
    ±2dB
    MCS11
    13dBm
    16dbm
    ±2dB
