龙讯LT8631UX HDMI2.0 / 1.4开关
929|0
 楼主| JLKJ18338421851 发表于 2022-3-23 16:01 | 显示全部楼层 |阅读模式
1.说明
Lontium LT8631UX HDMI2.0 / 1.4开关具有符合HDMI2.0 / 1.4规格的31开关,最大6Gbps高速数据速率,自适应均衡RX输入和预加重TX输出,以支持长电缆应用,板上没有XTAL以节省BOM成本。
LT8631UX HDMI2.0 / 1.4开关自动检测电缆损耗,并自适应优化均衡设置。它支持RX终端电阻校准,以进一步改善信号完整性。
LT8631UX支持符合HDMI2.0 / 1.4规范的DDC / SCDC。集成的DDCHPD交换机进一步降低了系统制造成本,并简化了系统板上的布线。此封装为QFN64。它的工作温度范围为−40°C+ 85°C
2.功能
•3输入,1输出HDMI / DVIlinks
兼容HDMI 1.4 / 2.0 / DVI 1.0
支持最高6Gbps的数据速率
•RXODT和管理电路
集成的HPD开关,DDC开关和+ 5V电源指示器开关,大大降低了成本并简化了制造过程
信号源/接收器连接检测,可实现灵活的系统管理
支持I2C控制
低抖动添加
•5V耐压DDC接口
无需外部晶体
自适应均衡
•SCDC监视器
3.应用
用于高级电视机(HDTV)的前面板缓冲器
独立切换台
多输入显示
投影仪
1. Description
The Lontium LT8631UX HDMI2.0/1.4 Switch features a 3:1 switch compliant to HDMI2.0/1.4 specification, max 6Gbps high speed data rate, adaptive equalization RX input and pre-emphasized TX output to support long cable application, no XTAL on board to save BOM cost .
LT8631UX HDMI2.0/1.4 Switch automatically detectsthe cable loss, and adaptively optimize the equalization setting. It supports RX termination resistor calibration to further improve signal integrity.
LT8631UX support DDC/SCDC compliant to HDMI2.0/1.4 specification. The integrated DDC and HPD switches further lower the cost of system manufacture, and simplify the routing on the system board.This package is QFN64. It  operate from −40°C to +85°C.
2. Features
• 3 inputs, 1output HDMI/DVIlinks
• HDMI 1.4/2.0/DVI 1.0compliant
• Supports data rates up to 6Gbps
• RX side ODTs and management circuitry
• Integrated HPD switch, DDC switch, and +5V Power indicator switch, greatly lowering the cost and simplifying the manufacturing process
• Source/Sink connection detection for flexible system management
• I2C control supported
• Low added jitter
• 5V-tolerant DDC interfaces
• No external crystal is needed
• Adaptive equalization
• SCDC monitor
3. Application
• Front panel buffer for advanced television (HDTV) sets
• Standalone switcher
• Multiple input displays
• Projectors
• A/V receivers​
1一般说明
LT8631UX是3端口HDMI/DVI交换机,可将多个HDMI/DVI源设备连接到高清电视(HDTV)。基于ClearEdge™  技术方面,它符合HDMI 2.0/DVI  1.0规范。LT8631UX是一种的高速交换机,它为制造商提供了一种经济高效的方法,可以为其HDTV添加额外的HDMI/DVI端口。多个HDMI/DVI端口允许消费者将各种HDMI/DVI源连接到他们的HDTV。
LT8631UX是一个三对一(3:1)开关,非常适合用于HDTV和a/V接收器的后面板,允许消费者连接多个HDMI/DVI设备,如高清DVD播放器、机顶盒和游戏机LT8631UX交换机从三个接收器端口选择一个HDMI/DVI信号,并生成完全兼容的HDMI//DVI音频/视频输出,以及完全符合HDMI/DVI规范的DDC和HPD切换。
芯片还集成了RX侧芯片终端(ODT),并采用了ODT管理电路,以实现经济高效的系统设计和增强的性能。集成的DDC和HPD交换机进一步降低了系统制造成本,并简化了主板上的布线。
2特征
•3个输入,1个输出HDMI/DVI链路
•符合HDMI 2.0/DVI 1.0
•支持高达3.4Gbps的数据速率
•支持深颜色
•接收侧ODT和管理电路
•集成HPD开关、DDC开关和+5V电源指示开关,大大降低了成本,简化了制造过程
•源/接收器连接检测,以实现灵活的系统管理
•支持I2C控制
•低附加抖动
•单个3.3V电源
•5V容差DDC接口
•根据JESD22-a114-B,HPD、DDC、数据/时钟通道ESD保护等级达到3A级。
三。应用
•用于电视(HDTV)的前面板缓冲器
•独立交换机
•多输入显示
•投影仪
•A/V接收器
九黎科技是龙讯授权代理商,如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!Email:bcxu.jl@foxmail.com
