[PIC®/AVR®/dsPIC®产品] dsp33ep512 mplabx xc16 程序报错
1429|8
 楼主| EightNine 发表于 2022-4-2 17:48 | 显示全部楼层 |阅读模式
报这个错误 ,内存50k的内存,才用了20多k。
build/default/production/_ext/812168374/rel_ratiodiff.o: Link Error: Could not allocate section .bss, size = 96 bytes, attributes = bss
build/default/production/_ext/812168374/sam_interrput.o: Link Error: Could not allocate section .bss, size = 90 bytes, attributes = bss
build/default/production/_ext/812168374/Base_DO.o: Link Error: Could not allocate section .bss, size = 40 bytes, attributes = bss
build/default/production/_ext/1239188649/timer.o: Link Error: Could not allocate section .bss, size = 36 bytes, attributes = bss
build/default/production/_ext/812168374/Fun_SelfCheck.o: Link Error: Could not allocate section .bss, size = 30 bytes, attributes = bss
build/default/production/_ext/812168374/CommStruct.o: Link Error: Could not allocate section .bss, size = 20 bytes, attributes = bss
match007 发表于 2022-4-6 16:00 | 显示全部楼层
不知道下划线有影响没有
ynwa 发表于 2022-4-7 17:00 | 显示全部楼层
到项目属性窗口里把XC16编译器选项的data model改成large
tpgf 发表于 2022-5-1 10:43 | 显示全部楼层
堆栈不够用了吗
磨砂 发表于 2022-5-1 10:52 | 显示全部楼层
应该不是下划线的问题
晓伍 发表于 2022-5-1 10:59 | 显示全部楼层
看不明白是什么错误
八层楼 发表于 2022-5-1 11:14 | 显示全部楼层
看不明白是什么错误啊
观海 发表于 2022-5-1 11:22 | 显示全部楼层
那应该不是内存的问题啊
guanjiaer 发表于 2022-5-1 11:32 | 显示全部楼层
连接的问题吧
