| //----------------------------------------------------------------- //  名称: STC15+W5500-Server模式应用
 //网关:192.168.1.1
 //掩码:        255.255.255.0
 //物理地址:0C 29 AB 7C 00 01
 //本机IP地址:192.168.1.199
 //端口0的端口号:5000
 //端口0的目的IP地址:192.168.1.190
 //端口0的目的端口号:6000
 #define u8  unsigned char
 #define u16 unsigned int
 #define MAIN_Fosc 12000000L        //系统时钟
 #include <string.h>
 #include <stdio.h>
 #include <intrins.h>
 #include <stdlib.h>
 #include "STC15xxx.h"
 #include "W5500.h"
 #include "src/oled.h"
 #include "src/bmp.h"
 //10号模块板外部资源引脚定义
 sbit BEEP  =  P0^6;
 sbit RELAY =  P0^7;
 sbit LED0  =  P1^4;
 sbit LED1  =  P1^5;
 sbit LED2  =  P1^6;
 volatile u8 LED_Control_Flag = 0;
 sbit MA    =  P3^2;
 sbit MB    =  P3^3;
 sbit DQ    =  P1^7;
 extern u8 Read_Temperature();
 extern u8 Temp_Value[];
 void Delay300us()        {        //@12.000MHz
 u8 i, j; i = 4; j = 125;
 do {
 while (--j);
 } while (--i);
 #define ADC_POWER         0x80         //ADC电源控制位
 #define ADC_FLAG                 0x10         //ADC完成标志
 #define ADC_START         0x08         //ADC起始控制位
 #define ADC_SPEEDLL        0x00         //540个时钟
 #define ADC_SPEEDL         0x20         //360个时钟
 #define ADC_SPEEDH         0x40         //180个时钟
 #define ADC_SPEEDHH        0x60         //90个时钟
 extern void Delay1us();
 extern void delay_us(u16 x);
 extern void Delay1ms();
 extern void delay_ms(u16 ms);
 // 蜂鸣器程序
 void Sound() {
 u16 i;
 for (i = 0; i < 300; i++) { Delay300us(); BEEP ^= 1;};
 BEEP = 1;//最后要判断驱动三极管
 void Delay(unsigned int d);                        //延时函数(ms)
 // 初始化ADC
 void InitADC() {
 P1ASF = 0xF0;                                         //P1高4位设为AD口
 ADC_RES = 0;                                                 //结果寄存器清0
 ADC_CONTR = ADC_POWER | ADC_SPEEDLL;//上电,转换速度:540个时钟
 delay_ms(2);                                                 //ADC上电并延时
 // 读取ADC结果
 u16 GetADCResult(u8 ch) {
 ADC_RES = 0; ADC_RESL = 0;                        //A/D转换结果先清零(可省)
 //选择通道并启动转换(含上电与540个时钟速度配置)
 ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START | ch;
 _nop_(); _nop_(); _nop_(); _nop_();
 while (!(ADC_CONTR & ADC_FLAG));        //等待ADC转换完成
 ADC_CONTR &= ~ADC_FLAG;                                         //清ADC结束标志
 return (ADC_RES<<2 | ADC_RESL) ;        //读取转换结果
 // 读取ADC结果
 u8 GetKeyStatus() {
 u8 keystatus = 0x00;
 if (GetADCResult(0)<400) keystatus |= 1<<0;
 if (GetADCResult(1)<400) keystatus |= 1<<1;
 if (GetADCResult(2)<400) keystatus |= 1<<2;
 if (GetADCResult(3)<400) keystatus |= 1<<3;
 return keystatus;
 // W5500初始化
 void W5500_Initialization(void) {
 W5500_Init();                //初始化W5500寄存器函数
 Detect_Gateway();        //检查网关服务器
 Socket_Init(0);                //指定Socket(0~7)初始化,初始化端口0
 // W5500装载网络参数
 // 网关、掩码、物理地址、本机IP地址、端口号、目的IP地址、目的端口号、端口工作模式
 void Load_Net_Parameters(void) {
 Gateway_IP[0] = 125;//加载网关参数
 Gateway_IP[1] = 221;
 Gateway_IP[2] = 52;
 Gateway_IP[3] = 254;
 Sub_Mask[0]        =        255;//加载子网掩码
 Sub_Mask[1]        =        255;
 Sub_Mask[2]        =        255;
 Sub_Mask[3]        =        0;
 Phy_Addr[0]        =        0x0c;//加载物理地址
 Phy_Addr[1]        =        0x29;
 Phy_Addr[2]        =        0xab;
 Phy_Addr[3]        =        0x7c;
 Phy_Addr[4]        =        0x00;
 Phy_Addr[5]        =        0x01;
 IP_Addr[0]        =        125;//加载本机IP地址    125.221.52.100
 IP_Addr[1]        =        221;
 IP_Addr[2]        =        52;
 IP_Addr[3]        =        100;
 S0_Port[0] = 0x13;//加载端口0的端口号5000
 S0_Port[1] = 0x88;
 //        S0_DIP[0]=192;//加载端口0的目的IP地址
 //        S0_DIP[1]=168;
 //        S0_DIP[2]=1;
 //        S0_DIP[3]=190;
 //        S0_DPort[0] = 0x17;//加载端口0的目的端口号6000
 //        S0_DPort[1] = 0x70;
 S0_Mode = TCP_SERVER;//加载端口0的工作模式,TCP服务端模式
 // W5500端口初始化配置
 // 分别设置4个端口,根据端口工作模式,将端口置于TCP服务器、TCP客户端或UDP模式.
 // 从端口状态字节Socket_State可以判断端口的工作情况
 void W5500_Socket_Set(void) {
 if(S0_State==0) {        //端口0初始化配置
 if(S0_Mode==TCP_SERVER) {        //TCP服务器模式
 if(Socket_Listen(0)==TRUE) S0_State=S_INIT; else S0_State=0;
 else if(S0_Mode==TCP_CLIENT) {                                                //TCP客户端模式
 if(Socket_Connect(0)==TRUE) S0_State=S_INIT; else S0_State=0;
 else {        //UDP模式
 if(Socket_UDP(0)==TRUE) S0_State=S_INIT|S_CONN; else S0_State=0;
 // W5500接收并发送接收到的数据
 // 本过程先调用S_rx_process()从W5500的端口接收数据缓冲区读取数据,
 ////*                        然后将读取的数据从Rx_Buffer拷贝到Temp_Buffer缓冲区进行处理。
 ////*                        处理完毕,将数据从Temp_Buffer拷贝到Tx_Buffer缓冲区。调用S_tx_process()
 ////*                        发送数据
 void Process_Net_IO_Data(SOCKET s) {
 unsigned short Size;
 //读取接收缓冲中的数据放入Rx_Buffer并返回字节数
 Size = Read_SOCK_Data_Buffer(s, Rx_Buffer);
 Rx_Buffer[Size] = '\0';
 if (strcmp((char*)Rx_Buffer,"BEEP") == 0) { Sound(); }
 else if (strcmp((char*)Rx_Buffer,"LED_M") == 0) { LED_Control_Flag = 1; } //滚动显示
 else if (strcmp((char*)Rx_Buffer,"LED_F") == 0) { LED_Control_Flag = 2; } //闪烁显示
 else if (strcmp((char*)Rx_Buffer,"LED_K") == 0) { LED_Control_Flag = 0; } //停止显示
 else if (strcmp((char*)Rx_Buffer,"RELAYON") == 0)                 { RELAY = 0; }
 else if (strcmp((char*)Rx_Buffer,"RELAYOFF") == 0)                 { RELAY = 1; }
 else if (strcmp((char*)Rx_Buffer,"MOTOR_F") == 0)                 { MA = 1; MB = 0;}
 else if (strcmp((char*)Rx_Buffer,"MOTOR_R") == 0)                 { MA = 0; MB = 1;}
 else if (strcmp((char*)Rx_Buffer,"MOTOR_STOP") == 0)         { MA = 0; MB = 0;}
 OLED_ShowString(6,0,Rx_Buffer,16);
 //        //所接收数据全部放的发送缓冲Tx_Buffer
 //        memcpy(Tx_Buffer, Rx_Buffer, Size);
 //        Write_SOCK_Data_Buffer(s, Tx_Buffer, Size);
 // T0初始化(16位自动重装载模式/12分频,5ms@12MHz)
 void Timer0Init() {
 AUXR &= 0x7F;                //定时器时钟12T模式
 TMOD &= 0xF0;                //设置定时器模式
 TL0 = 0x78;                        //设置定时初值
 TH0 = 0xEC;                        //设置定时初值
 //上述两行由STC-ISP自动生成的语句还可写成以下语句
 //TL0 = (65536 - 5000) & 0x00FF;
 //TH0 = (65536 - 5000) >> 8;
 //或者:
 //TL0 = - 5000 & 0x00FF;
 //TH0 = - 5000 >> 8;
 TF0 = 0;                                //清除TF0标志
 TR0 = 1;                                //定时器0开始计时
 // 主程序
 int main(void) {
 unsigned int W5500_Send_Delay_Counter =0;
 int x = 0;
 int i = 100;
 char disp_buff[20];
 //float temp;
 P0M1 = 0x00; P0M0 = 0x00;
 P1M1 = 0x00; P1M0 = 0x00; //P1 = 0xF0;
 P2M1 = 0x00; P2M0 = 0x00;
 P3M1 = 0x00; P3M0 = 0x00;
 MA = 0; MB = 0;        //初始时电机停转
 RELAY = 1;                        //初始时继电器断开
 OLED_Init();                        //初始化OLED
 OLED_Clear();
 //        OLED_ShowCHinese(0,0,0);//中
 //        OLED_ShowCHinese(18,0,1);//景
 //        OLED_ShowCHinese(36,0,2);//园
 OLED_ShowString(6,0,"0.91' EE-HELLO",16);
 //OLED_ShowString(8,2,"ZHONGJINGYUAN");
 //        OLED_ShowString(20,4,"2014/05/01");
 //        OLED_DrawBMP(0,0,128,8,BMP1);  //图片显示(图片显示慎用,生成的字表较大,会占用较多空间,FLASH空间8K以下慎用)
 //while (1);
 InitADC();
 Load_Net_Parameters();                                //装载网络参数
 W5500_Hardware_Reset();                                //硬件复位W5500
 W5500_Initialization();                                //W5500初始化
 Timer0Init();                                        //T0初始化
 IE = 0x82;                                                //允许T0中断
 TR0 = 1;                                                        //启动T0
 while (1) {
 W5500_Socket_Set();                                        //W5500端口初始化配置
 W5500_Interrupt_Process();        //W5500中断处理程序框架
 //如果Socket0接收到数据
 if((S0_Data & S_RECEIVE) == S_RECEIVE) {
 S0_Data &=~S_RECEIVE;
 Process_Net_IO_Data(0);                //W5500接收并发送接收到的数据
 //这里可放显示语句
 else if(W5500_Send_Delay_Counter >= 2000) {//定时发送字符串
 if(S0_State == (S_INIT|S_CONN)) {
 S0_Data &= ~S_TRANSMITOK;
 //memcpy(Tx_Buffer, "\r\n欢迎使用E-HELLO模块板!\r\n", 25);
 //Write_SOCK_Data_Buffer(0, Tx_Buffer, 25);//指定Socket(0~7)发送数据处理,端口0发送23字节数据
 Tx_Buffer[0] = GetKeyStatus(); //放置4位按键状态
 x = rand() % 1000;
 Tx_Buffer[1] = x >> 8;
 Tx_Buffer[2] = x & 0xFF;
 sprintf(disp_buff,"Send=>PC:%4d",x);
 OLED_ShowString(6,2,disp_buff,16);
 //if (Read_Temperature())
 {                        //读取正常则显示
 Tx_Buffer[3] = Temp_Value[0];
 Tx_Buffer[4] = Temp_Value[1];
 //计算温度浮点值
 //temp = (int)(Temp_Value[1]<<8 | Temp_Value[0]) * 0.0625;
 //sprintf(disp_buff,"TEMP:%4.1f",temp);
 //OLED_ShowString(6,0,disp_buff,16);
 //else
 Tx_Buffer[3] = -1000>>8;
 Tx_Buffer[4] = -1000;
 Write_SOCK_Data_Buffer(0, Tx_Buffer, 5);//发送5字节
 W5500_Send_Delay_Counter = 0;
 W5500_Send_Delay_Counter++;
 // T0中断函数(控制LED显示:滚动,闪烁,停止)
 void LED_Control() interrupt 1 {
 static u8 T_Count = 0, LED_M_Pattern = 0x40, LED_F_Pattern = 0xFF;
 if ( ++T_Count == 10) {        //累加形成5ms×10=50ms定时
 if (LED_Control_Flag == 1) {                                //控制移动显示
 P1 = (P1 & 0x8F) | LED_M_Pattern;
 if ((LED_M_Pattern >>= 1) == 0x08) LED_M_Pattern = 0x40;
 else if (LED_Control_Flag == 2) {                //控制闪烁
 LED_F_Pattern ^= 0x70; P1 = LED_F_Pattern;
 else if (LED_Control_Flag == 0) {                //停止显示
 P1 &= ~0x70;
 T_Count = 0;
