串口中断配置
- * [url=home.php?mod=space&uid=247401]@brief[/url] This function handles USART1 Handler.
- void USART1_IRQHandler(void)
- if (USART_GetFlagStatus(USART1, USART_FLAG_RXDNE) != RESET)
- /* Read one byte from the receive data register */
- RxBuffer[RxCounter++] = USART_ReceiveData(USART1);
- USART_ConfigInt(USART1, USART_INT_TXDE, ENABLE);
- RxCounter = 0;
- if (USART_GetIntStatus(USART1, USART_INT_TXDE) != RESET)
- /* Write one byte to the transmit data register */
- USART_SendData(USART1, RxBuffer[RxCounter++]);
- /* Disable the USART1 Transmit interrupt */
- USART_ConfigInt(USART1, USART_INT_TXDE, DISABLE);
- RxCounter = 0;
串口配置
- void USART1_Configuration()
- USART_InitType USART_InitStructure;
- /* USART1 configuration ------------------------------------------------------*/
- USART_InitStructure.BaudRate = 115200;
- USART_InitStructure.WordLength = USART_WL_8B;
- USART_InitStructure.StopBits = USART_STPB_1;
- USART_InitStructure.Parity = USART_PE_NO;
- USART_InitStructure.HardwareFlowControl = USART_HFCTRL_NONE;
- USART_InitStructure.Mode = USART_MODE_RX | USART_MODE_TX;
- /* Configure USART1*/
- USART_Init(USART1, &USART_InitStructure);
- /* Enable USART1 Receive interrupts */
- USART_ConfigInt(USART1, USART_INT_RXDNE, ENABLE);
- /* Enable the USART1 */
- USART_Enable(USART1, ENABLE);
时钟配置- void RCC_Configuration(void)
- /* Enable GPIO and USART1 clock */
- RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA | RCC_APB2_PERIPH_AFIO | RCC_APB2_PERIPH_USART1, ENABLE);
GPIO配置
- * @brief Configures the different GPIO ports.
- void GPIO_Configuration(void)
- GPIO_InitType GPIO_InitStructure;
- /* Initialize GPIO_InitStructure */
- GPIO_InitStruct(&GPIO_InitStructure);
- /* Configure USARTx Rx */
- GPIO_InitStructure.Pin = GPIO_PIN_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_MODE_AF_OD;
- GPIO_InitStructure.GPIO_Alternate = GPIO_AF4_USART1;
- GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
- /* Configure USART1 Tx */
- GPIO_InitStructure.Pin = GPIO_PIN_9;
- GPIO_InitStructure.GPIO_Mode = GPIO_MODE_AF_PP;
中断向量表- /**
- * @brief Configures the nested vectored interrupt controller.
- void NVIC_Configuration(void)
- NVIC_InitType NVIC_InitStructure;
- /* Enable the USARTy Interrupt */
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
- NVIC_Init(&NVIC_InitStructure);
main函数
- int main(void)
- /* System Clocks Configuration */
- RCC_Configuration();
- /* NVIC configuration */
- NVIC_Configuration();
- /* Configure the GPIO ports */
- GPIO_Configuration();
- /* Configure the USART1 */
- USART1_Configuration();
- while(1)
测试效果【图】
注:定义全局变量Rxbuffer和RxCounter
