| 随着技术的进步,MP3播放器已成为现代消费者首选的随身听产品,它以小巧玲珑的体积,精美的外形,低廉的价格以及其强大的功能深得消费者的厚爱。 MP3播放器的主要作用是解压压缩的MP3数字音频,再现MP3音乐。AT89C51SND1是ATMEL公司专门针对开发MP3而设计的,其主要特点是内部集成了MPEG2解码器和USB通信接口,内含64KB的内部程序存储器,支持在系统编辑ISP功能,通过USB或者串行口对芯片进行编程操作,内部数据存储器为2056B。
 以下为C语言程序
 #include "AT89C51SND1C.H"
 #include "Initial.h"
 #include "file_system.h"
 #include "IDE.H"
 #include "keyboard.h"
 #include "hardware.h"
 #include "MP3.H"
 #include "LCD.H"
 unsigned char status;   //程序运行状态
 extern unsigned char mp3_file_exist;
 void DAC_start(unsigned char clk)  //DAC开始工作
 set_DAC_CLK(clk);   //根据MP3文件,设置相应的DAC时钟频率
 DAC_interface_en();
 DAC_data_request_en();
 unsigned char xdata function,vol,bas,med,tre;  //保存音量等设置
 code unsigned char MPEGVer[2][7]={"MPEG-2","MPEG-1"}; //版本显示信息
 code unsigned char Fs[8]={22,44,24,48,16,32,22,44};     //采样率
 code unsigned char DACFs[8]={33,16,30,15,46,22,33,16};  //256Fs
 //code unsigned char DACFs[8]={22,10,20,9,30,15,0,0}; //384Fs
 ///////////////////////////  MP3 play  /////////////////////////////////////////
 void play(void)
 unsigned long int LBA;
 unsigned int i;
 unsigned char sectors_count;
 signed long int file_length;
 unsigned char count;
 unsigned char MPEG_inf;   //用来保存MP3版本和采样率
 bit0=0 vertion 2
 bit0=1 bertion 1
 LCD_go_home();
 prints("               ");
 LCD_line_feed();
 prints("               ");
 file_length=file.length;
 LBA=file.next_cluster_number-(dbr[driver_number].root_cluster_num);
 LBA=LBA*(dbr[driver_number].sectors_per_cluster)+DATA_start_sector[driver_number];
 MP3_CRC_disen();
 sectors_count = dbr[driver_number].sectors_per_cluster;
 read_IDE_sector(LBA);
 if(buffer[0]!=0xFF){pause();MP3_decoder_disen();DAC_interface_disen();get_next_file();key=0;return;}
 if((buffer[1]&0x06)!=0x02){pause();MP3_decoder_disen();DAC_interface_disen();key=0;LCD_line_feed();prints("MP3 层错误!!  ");while(!key);get_next_file();return;}
 //////////////////////// 从MP3侦头中获取采样率和压缩版本信息  //////////////
 MPEG_inf=buffer[2]&0x0C; //采样率
 MPEG_inf>>=1;
 if((buffer[1]&0x18)==0x18)MPEG_inf=MPEG_inf | 0x01; //版本1
 if((buffer[1]&0x18)==0x10)MPEG_inf=MPEG_inf & (~0x01);  //版本2
 ////////////////////////   填充1K数据  ////////////////////////////////////
 for(i=0;i<512;i++)MP3DAT=buffer[i];
 LBA++;
 sectors_count--;
 if(file_length>512)file_length-=512;
 else {pause();MP3_decoder_disen();DAC_interface_disen();get_next_file();key=0;return;}
 if(sectors_count==0){LBA=get_next_sector();sectors_count=dbr[driver_number].sectors_per_cluster;}
 LBA++;
 sectors_count--;
 MP3_decoder_en();           //启动解码器
 DAC_start(DACFs[MPEG_inf]); //初始化DAC接口
 byte_offset=512;
 key=KEY_FUN;
 function=FUN_MAX;
 while(1)
 if(key)                 //如果有键按下
 switch (key)
 case KEY_FUN:  //功能键按下
 function++;
 if(function>=FUN_MAX)function=FUN_SEL;
 switch (function)
 case FUN_SEL:LCD_go_home();for(count=0;count<14;count++)write_LCD_data(((unsigned char *)dir_name)[count]);LCD_line_feed();prints("当前曲号: ");printf(play_count);LED1=1;LED2=1;LED3=1;break;
 case FUN_VOL:LCD_line_feed();prints("音量: ");printf(vol);prints("      ");LED1=0;LED2=1;LED3=0;break;
 case FUN_BAS:LCD_line_feed();prints("低音: ");printf(bas);prints("      ");LED1=1;LED2=1;LED3=0;break;
 case FUN_MED:LCD_line_feed();prints("中音: ");printf(med);prints("      ");LED1=1;LED2=0;LED3=1;break;
 case FUN_TRE:LCD_line_feed();prints("高音: ");printf(tre);prints("      ");LED1=0;LED2=1;LED3=1;break;
 case FUN_BOOT:LCD_line_feed();prints("重低音: ");if(MP3CON&0x40)prints("开");else prints("关");prints("      ");LED1=0;LED2=0;LED3=0;break;
 key=0;break;
 case KEY_UP:   //上翻键按下
 switch (function)
 case FUN_SEL:{MP3_decoder_disen();DAC_interface_disen();get_pre_file();LCD_go_home();for(count=0;count<14;count++)write_LCD_data(((unsigned char *)dir_name)[count]);LCD_line_feed();prints("当前曲号: ");printf(play_count);key=0;return;}
 case FUN_VOL:{if(vol<31)vol++;set_vol(vol);set_vor(vol);LCD_line_feed();prints("音量: ");printf(vol);prints("      ");break;}
 case FUN_BAS:{if(bas<31)bas++;set_bas(bas);LCD_line_feed();prints("低音: ");printf(bas);prints("      ");break;}
 case FUN_MED:{if(med<31)med++;set_med(med);LCD_line_feed();prints("中音: ");printf(med);prints("      ");break;}
 case FUN_TRE:{if(tre<31)tre++;set_tre(tre);LCD_line_feed();prints("高音: ");printf(tre);prints("      ");break;}
 case FUN_BOOT:{MP3_bass_boost();LCD_line_feed();prints("重低音: ");prints("开");prints("      ");break;}
 key=0;break;
 case KEY_DOWN:   //下翻键按下
 switch (function)
 case FUN_SEL:{MP3_decoder_disen();DAC_interface_disen();get_next_file();LCD_go_home();for(count=0;count<14;count++)write_LCD_data(((unsigned char *)dir_name)[count]);LCD_line_feed();prints("当前曲号: ");printf(play_count);key=0;return;}
 case FUN_VOL:{if(vol>0)vol--;set_vol(vol);set_vor(vol);LCD_line_feed();prints("音量: ");printf(vol);prints("      ");break;}
 case FUN_BAS:{if(bas>0)bas--;set_bas(bas);LCD_line_feed();prints("低音: ");printf(bas);prints("      ");break;}
 case FUN_MED:{if(med>0)med--;set_med(med);LCD_line_feed();prints("中音: ");printf(med);prints("      ");break;}
 case FUN_TRE:{if(tre>0)tre--;set_tre(tre);LCD_line_feed();prints("高音: ");printf(tre);prints("      ");break;}
 case FUN_BOOT:{MP3_no_bass_boost();LCD_line_feed();prints("重低音: ");prints("关");prints("      ");break;}
 key=0;break;
 case KEY_OK:
 status=STOP;
 for(i=(folder_length/2);i<(7+folder_length/2);i++)dir_name[i]=0x2020;
 LCD_line_feed();
 prints("停止          ");
 key=0;
 return;
 while(MPFREQ)
 if((((unsigned char *)&byte_offset)[0])&0xFE)
 LBA++;
 byte_offset=0;
 sectors_count--;
 file_length-=512;
 while(MPFREQ)
 MP3DAT=buffer[byte_offset];
 byte_offset++;
 if((((unsigned char *)&byte_offset)[0])&0xFE)break;
 if(file_length<=0) {pause();MP3_decoder_disen();DAC_interface_disen();get_next_file();key=0;return;}
 if(sectors_count==0){LBA=get_next_sector();sectors_count=(dbr[driver_number].sectors_per_cluster);}
 if(MPFREQ)
 byte_offset++;
