[无线通信] DR6018 QCN9074 WiFi 6E Card , IPQ6010,802.11ax, 2x2 2.4G&5G 2.5Gbps
1472|0
 楼主| wallysJane 发表于 2022-7-12 11:27 | 显示全部楼层 |阅读模式
Qualcomm-Atheros IPQ6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
24V~48
V
Operating Temperature Range
-40 to +70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
         Hardware Specifications
Symbol
Parameter
CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V power supply
LED header
FFC/FPC Connector
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Bluetooth        optional
Nor Flash
8-32MB(normally is 8MB)
Nand Flash
256MB
DDR
1GB
Dimension
185mm x 116mm
  With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards.
    We are engaged in the design and manufacture of wireless communication products, providing OEM/ODM/JDM services.
    Dedicated to innovative design for RF wireless modules and host boards, Wallys also provides Software & Hardware design, product testing and certification and fully customized solution to meet your personal requirement.
IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882/AR9582/AR9531/AR9344/AR9531
WEB:https://www.wallystech.com/d
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:sales1@wallystech.com
