今天我在配置STM32F103的时候要用到PA5---PA7作为中断,要配置他们的中断函数,但是所有配置都是正常的,自己查不出什么问题,具体代码如下:
- void KEY_Init(void) //IO初始化
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//使能PORTA,PORTE时钟
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//KEY0-KEY1
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //设置成上拉输入
- GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA 5.6.7
- void EXITTI_Init(void)
- EXTI_InitTypeDef EXTI_InitStructure; //定义一个EXTI结构体变量
- NVIC_InitTypeDef NVIC_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); //使能IO复用功能,使用中断功能重要!!!
- KEY_Init();
- /* 引脚选择 */
- GPIO_EXTILineConfig(GPIO_PortSourceGPIOA, GPIO_PinSource5|GPIO_PinSource6|GPIO_PinSource7);//配置端口C的13引脚为中断源
- /* 设置外部中断结构体的成员*/
- EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; //中断模式为中断模式
- EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //下降沿触发
- EXTI_InitStructure.EXTI_Line = EXTI_Line5 | EXTI_Line6|EXTI_Line7;
- EXTI_InitStructure.EXTI_LineCmd = ENABLE; //使能中断线
- EXTI_Init(&EXTI_InitStructure); //根据参数初始化中断寄存器
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //设置中断优先级分组2
- NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn; //设定中断源为PC13
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2; //中断占优先级为2
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //副优先级为0
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能中断
- NVIC_Init(&NVIC_InitStructure); //根据参数初始化中断寄存器
- void EXTI19_5_IRQHandler(void)
- if(EXTI_GetITStatus(EXTI_Line5) != RESET)
- delay_ms(10);//消抖
- if(KEY0==0)
- printf("555");
- LED1=!LED1;
- /* Clear the Key Button EXTI line pending bit */
- EXTI_ClearITPendingBit(EXTI_Line5);
- else if(EXTI_GetITStatus(EXTI_Line6 )!= RESET)
- delay_ms(10);//消抖
- printf("666");
- if(KEY1==0)
- LED0=!LED0;
- EXTI_ClearITPendingBit(EXTI_Line6);
- else if(EXTI_GetITStatus(EXTI_Line7 )!= RESET)
- printf("777");
- EXTI_ClearITPendingBit(EXTI_Line7);
