[WIFI模块] IPQ4019 IPQ4029 support openWRT Industrial Wifi Router Wallys/DR-AP40X9-A
1915|0
 楼主| lilywallys 发表于 2022-11-18 14:22 | 显示全部楼层 |阅读模式
The IPQ4019 SOC is a highly integrated solution on a chip (SOC), designed for high-performance, low-power,and low-cost 2x2 802.11ac dual band concurrent access point applications. The SoC focuses on the quad core ARM Cortex A7 processor, two dual band parallel 802.11ac wave-2 wifi subsystems, and a 5-port Gigabit Ethernet layer 2/3/4 multilayer switch that supports line rate networks.
The IPQ4019 SOC integrates an ARM Cortex-A7 processor with the advanced 802.11ac Wi-Fi (Wave 2) radio to create a highly integrated solution which supports line rate communications over a single 5G link or up to four 10G links through 4x GigE slots.
If you are looking for a wifi5 industrial wireless AP which could support openWRT and with matel enclosure.I will introduce you our industrial wireless AP,DR-AP40X9-A.
The DR-AP40X9-A is a high-power, 2x2 2.4G&5G radio access point with a 5dBi dipole antenna and an IPQ4019/IPQ4029 board. It includes an enclosure, a PSU (DC power or PoE), and an SMA plug interface for connecting to your network.
With its two 2.4G&5G antennas, this AP can provide you with the best coverage for your wireless operations. There are also 5dBi 2.4GHz/5Ghz dipole antennas that ensure that you'll be able to cover all areas of your room with ease.
Dipole antenna
  2 x 2.4G&5G Antenna
  5dBi 2.4GHz/5Ghz
SMA Plug interface
Plastic rod of black
RoHS compliance
Enclosure
Dimension: 132x 119 x 34 mm
Aluminum alloy material
Support WallysDR40X9
For more information about DR-AP40X9-A,please click below the link or email us.
https://www.wallystech.com/Industrial_Wireless_AP/DR-AP40X9-A-Qualcomm-IPQ-4019-IPQ-4029-5G-4G-LTE-aluminum-body-dual-band-wifi-router-2.4GHZ-5GHz-QSDK-firmware.html
Wallys Communications (Suzhou) Co., Ltd. is a leading Chinese company specializing in the research and development and production of wireless communication products, such as Routerboard, Network Card, Industrial Wireless AP, Antenna etc.
We are committed to providing customers with OEM/ODM/JDM services for products. We have a proven track record working with RF and embedded communications, network protocol, firmware, openwrt, linux system development, analog and digital circuit design, network processors and power supplies.
The company's seasoned R&D engineer team is ready to help explore your project with RF and embedded communications, network protocol, firmware development or any other field related to information technology.
Feel free to contact us at sales1@wallystech.com if you have any questions regarding our products!
www.wallystech.com
