今天装了MPLABX和XC32编译器,搞了个串口发送的程序。
代码:
- * Copyright (C) 2019 Microchip Technology Inc. and its subsidiaries.
- * Subject to your compliance with these terms, you may use Microchip software
- * and any derivatives exclusively with Microchip products. It is your
- * responsibility to comply with third party license terms applicable to your
- * use of third party software (including open source software) that may
- * accompany Microchip software.
- * THIS SOFTWARE IS SUPPLIED BY MICROCHIP "AS IS". NO WARRANTIES, WHETHER
- * EXPRESS, IMPLIED OR STATUTORY, APPLY TO THIS SOFTWARE, INCLUDING ANY IMPLIED
- * WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY, AND FITNESS FOR A
- * PARTICULAR PURPOSE.
- * IN NO EVENT WILL MICROCHIP BE LIABLE FOR ANY INDIRECT, SPECIAL, PUNITIVE,
- * INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE, COST OR EXPENSE OF ANY KIND
- * WHATSOEVER RELATED TO THE SOFTWARE, HOWEVER CAUSED, EVEN IF MICROCHIP HAS
- * BEEN ADVISED OF THE POSSIBILITY OR THE DAMAGES ARE FORESEEABLE. TO THE
- * FULLEST EXTENT ALLOWED BY LAW, MICROCHIP'S TOTAL LIABILITY ON ALL CLAIMS IN
- * ANY WAY RELATED TO THIS SOFTWARE WILL NOT EXCEED THE AMOUNT OF FEES, IF ANY,
- * THAT YOU HAVE PAID DIRECTLY TO MICROCHIP FOR THIS SOFTWARE.
- Main Source File
- Company:
- Microchip Technology Inc.
- File Name:
- main.c
- Summary:
- This file contains the "main" function for a project.
- Description:
- This file contains the "main" function for a project. The
- "main" function calls the "SYS_Initialize" function to initialize the state
- machines of all modules in the system
- // Section: Included Files
- #include <stddef.h> // Defines NULL
- #include <stdbool.h> // Defines true
- #include <stdlib.h> // Defines EXIT_FAILURE
- #include "definitions.h" // SYS function prototypes
- #include <string.h>
- #define LED_ON LED_Clear
- #define LED_OFF LED_Set
- #define LED_TOGGLE LED_Toggle
- /* Define the NVMCTRL_SEESBLK_MASK_BITS to extract the NVMCTRL_SEESBLK bits(35:32) from NVM User Page Mapping(0x00804000) */
- #define NVMCTRL_SEESBLK_MASK_BITS 0x0F
- /* Define the NVMCTRL_SEEPSZ_MASK_BITS to extract the NVMCTRL_SEEPSZ bits(38:36) from NVM User Page Mapping(0x00804000) */
- #define NVMCTRL_SEEPSZ_MASK_BITS 0x07
- /* A specific byte pattern stored at the begining of SmartEEPROM data area.
- * When the application comes from a reset, if it finds this signature,
- * the assumption is that the SmartEEPROM has some valid data.
- #define SMEE_CUSTOM_SIG 0x5a5a5a5a
- /* Define the number of bytes to be read when a read request comes */
- #define MAX_BUFF_SIZE 256
- /* The application toggles SmartEEPROM data at the following address
- * each time the device is reset. This address must be within the total
- * number of EEPROM data bytes ( Defined by SBLK and PSZ fuse values).
- #define SEEP_TEST_ADDR 32
- /* This example demo assumes fuses SBLK = 1 and PSZ = 3, thus total size is 4096 bytes */
- #define SEEP_FINAL_BYTE_INDEX 4095
- /* Define a pointer to access SmartEEPROM as bytes */
- uint8_t *SmartEEPROM8 = (uint8_t *)SEEPROM_ADDR;
- /* Define a pointer to access SmartEEPROM as words (32-bits) */
- uint32_t *SmartEEPROM32 = (uint32_t *)SEEPROM_ADDR;
- uint8_t menu[] = "\r\n******** uart send test ******** \r\n";
- typedef enum {ReadSmartEEPROM = '1', WriteSmartEEPROM = '2', ResetDevice = '3', NoSelection = 0} MenuOptions;
- uint8_t data_8;
- uint8_t eeprom_data_buffer[MAX_BUFF_SIZE] = {0};
- * \brief Invert a byte in SmartEEPROM
- * To invert the data at the given index in SmartEEPROM
- void invert_seep_byte(uint8_t index)
- /* Wait till the SmartEEPROM is free */
- while (NVMCTRL_SmartEEPROM_IsBusy());
- /* Read the data, invert it, and write it back */
- data_8 = SmartEEPROM8[index];
- printf("\r\nData at test address %d is = %d\r\n", index, (int)data_8);
- SmartEEPROM8[index] = !data_8;
- printf("\r\nInverted the data at test address and written\r\n");
- * \brief Verify the custom data in SmartEEPROM
- * Verify the custom data at initial 4 bytes of SmartEEPROM
- int8_t verify_seep_signature(void)
- uint32_t NVMCTRL_SEESBLK_FuseConfig = ((*(uint32_t *)(USER_PAGE_ADDR + 4)) >> 0) & NVMCTRL_SEESBLK_MASK_BITS;
- int8_t ret_val = 0;
- /* If SBLK fuse is not configured, inform the user and wait here */
- if (!NVMCTRL_SEESBLK_FuseConfig)
- printf("\r\nPlease configure SBLK fuse to allocate SmartEEPROM area\r\n");
- while (1);
- if (SMEE_CUSTOM_SIG != SmartEEPROM32[0])
- ret_val = 0x4;
- return ret_val;
- * \brief Print a buffer as hex values
- * Print a given array as a hex values
- void print_hex_array(void *mem, uint16_t len)
- unsigned char *p = (unsigned char *)mem;
- for(uint32_t i = 0; i < len; i++)
- if ((i != 0) && (!(i & 0x7)))
- printf("\r\n");
- printf("%03d ", p[i]);
- printf("\r\n");
- // Section: Main Entry Point
- int main ( void )
- //uint32_t NVMCTRL_SEESBLK_FuseConfig = ((*(uint32_t *)(USER_PAGE_ADDR + 4)) >> 0) & NVMCTRL_SEESBLK_MASK_BITS;
- //uint32_t NVMCTRL_SEEPSZ_FuseConfig = ((*(uint32_t *)(USER_PAGE_ADDR + 4)) >> 4) & NVMCTRL_SEEPSZ_MASK_BITS;
- //MenuOptions user_selection = NoSelection;
- uint32_t i=0;
- // uint32_t num_of_bytes_to_read = 0;
- // uint32_t eeprom_data = 0;
- // uint32_t eeprom_addr = 0;
- // uint32_t eeprom_data_buf_start_index = 0;
- long int temp=0;
- /* Initialize all modules */
- // <editor-fold defaultstate="collapsed" desc="comment">
- SYS_Initialize( NULL );
- printf("%s", menu);
- while ( true )
- printf("temp=%ld\r\n",temp);
- temp++;
- for(i=0;i<50000000;i++);
- /* Execution should not come here during normal operation */
- return ( EXIT_FAILURE );
- End of File
效果图:
另外说明一下,我装的是MPLABX IDE V5.30,需要设置一下才能下载程序。
