[Studio] 一款arduino 工业控制器
3418|0
 楼主| wenming 发表于 2022-12-14 12:10 | 显示全部楼层 |阅读模式
A light-weight IoT controller for industrial applications
It is an  ESP32 based  cost-effective  controller that provides the functions
required for a variety of field automation applications. The
EdgeBox Hybrid lite monitors, measures, and controls equipment in a
remote environment. It  is ideal for applications
requiring flow computation; Proportional, Integral, and
Derivative (PID) control loops; logic sequencing control; and
a gateway with flexible wireless and field sensors expansion.
Features:
Rugged, reduced-maintenance hardware.
High isolation, surge, and short circuit protection.
Wide operating temperature (–20 C to +60C).
Wide power supply from 10.8 to 36 V DC.
Built-in Cellular radio with 4G/LTE support.
Open architecture  support custom programming.
Fieldbus for data exchange with  PLCs.
IEC 61131-3 compliant programs support(under developing).
Spec:
CPU: ESP32-S3
Memory: 512KB +8MB
Storage:16MB
Retain memory: 8KB
Wireless: Wi-Fi+Bluetooth+Cellular
GPS+GNSS(optional)
Dimensions: 124 (H) x 68 (L) x 35 (W) mm
Weight: 300 g
Power supply: DC 10.8-36 V
Operation temperaturey:  -20..+60 °C
Storage temperature y: -40..+70 °C
IOs:
One 10/100Mbs Ethernet
One Isolated CAN
One Ioslated  RS-485
6 Isolated DO of  transistor up to 1A capacity
4 Isolated DI
4 Isolated AI of 0-10 OR 0-20ma
2 Isolated  AO of 0-5V
Misc:
64kb retain RAM
RTC with  back-up  supcap
Encryption of atecc608a(optional)
APPs:
EdgeBox Hybrid lite comes with various options
and is customizable to your needs.
• RTU
• T-BOX
• Cellular router
• Edge computing
• Building Automation
• Industrial Automation
• Gateway for field bus and IO
• Programable logic controller
个人签名:嵌入式Linux工业控制板,提供ODM与OEM,只做批量,不卖开发板! 欧比特测控   www.OpenEmbed.com
108
