23种编程语言说“hello world”的区别?
841|0
 楼主| hqyjcdzx 发表于 2023-3-9 15:18 | 显示全部楼层 |阅读模式
01. Python
print('Hello, world!')02. C
#include <stdio.h>int main() {  printf("Hello, World!");  return 0;}03. C++
#include <iostream>int main() {  std::cout << "Hello World!";  return 0;}04. Java
class HelloWorld {  public static void main(String[] args) {    System.out.println("Hello, World!");   }}
05. C#
namespace HelloWorld{  class Hello {             static void Main(string[] args)    {      System.Console.WriteLine("Hello World!");    }  }}06. Visual Basic
Imports System Module Module1  Sub Main()    Console.WriteLine("Hello World!")    Console.WriteLine("Press Enter Key to Exit.")    Console.ReadLine()  End SubEnd Module
07. JavaScript
  console.log('Hello World');08. SQL
CREATE TABLE helloworld (phrase TEXT);INSERT INTO helloworld VALUES ("Hello, World!");SELECT * FROM helloworld;09. Assembly Language
global    _start            section   .text_start:   mov       rax, 1                  ; system call for write          mov       rdi, 1                  ; file handle 1 is stdout          mov       rsi, message            ; address of string to output          mov       rdx, 13                 ; number of bytes          syscall                           ; invoke operating system to do the write          mov       rax, 60                 ; system call for exit          xor       rdi, rdi                ; exit code 0          syscall                           ; invoke operating system to exit            section   .datamessage:  db        "Hello, World", 10      ; note the newline at the end
10. PHP
<!DOCTYPE html><html><body>  <h1>My first PHP page</h1>  <?phpecho "Hello World!";?>  </body></html>11. Swift
print("Hello, world!")12. Go
package main  import "fmt"  func main() {    fmt.Println("hello world")}13. R
print("Hello World!")14. Classic Visual Basic
Imports System  Module Module1  Sub Main()    Console.WriteLine("Hello World!")    Console.WriteLine("Press Enter Key to Exit.")    Console.ReadLine()  End SubEnd Module15. MATLAB
function y = hello_world %#codegeny = 'Hello World!';
16. Ruby
puts "Hello World"17. Rust
fn main() {  println!("Hello World!");}18. Scala
@main def hello() = println("Hello, World!")19. Perl
#!/usr/bin/perluse warnings;print("Hello, World!\n");20. Scratch
  say Hello World!21. (Visual) FoxPro
Messagebox("Hello World!",64)? "Hello World"22. SAS
proc ds2 libs=work;data _null_;    /* init() - system method */  method init();    declare varchar(16) message; /* method (local) scope */    message = 'Hello World!';    put message;  end;enddata;run;quit;23. Objective-C
- (BOOL)application:(UIApplication *)application didFinishLaunchingWithOptions:(NSDictionary *)launchOptions {      NSAutoreleasePool * pool = [[NSAutoreleasePool alloc] init];    NSLog (@"Hello, World!");    [pool drain];    return YES;  }
