[无线通信] IPQ5018 with QCN6122/QCN6102 to achieve high-performance high-speed Wi-Fi connection.
1025|0
 楼主| Cindy@wallys 发表于 2023-5-9 14:23 | 显示全部楼层 |阅读模式
Introduction of IPQ5018 and chip function advantages.
IPQ5018/IPQ5010,802.11ax,wifi 6e,QCN9074,2X2 2.4G support 2x WiFi 6E Card support BT5.1/
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;
M.2 Card Slot for QCN9074 WIFI 6E Card
IPQ5018 is a high-performance embedded processor launched by Qualcomm, which is specially used for Wi-Fi network applications. It integrates a quad-core ARM Cortex-A53 processor and high-speed network connection, supports multiple Wi-Fi standards, including 802.11ac and 802.11ax, and is also compatible with 802.11a/b/g/n. IPQ5018 also supports a variety of peripheral interfaces, such as USB, PCIe, etc., which can be easily connected and communicated with other devices.
The main functions and advantages of the IPQ5018 chip are as follows:
High performance: IPQ5018 is equipped with a quad-core ARM Cortex-A53 processor with a main frequency of up to 1.0GHz, which provides powerful computing and processing capabilities and can handle a variety of data and applications.
High-speed network connection: IPQ5018 supports multiple Wi-Fi standards, including 802.11ac and 802.11ax, and is also compatible with 802.11a/b/g/n, supports dual-band Wi-Fi, and provides high-speed network connection and transmission speed.
Safe and reliable: The IPQ5018 chip integrates a variety of security functions and encryption algorithms, including WPA3 encryption, AES encryption, TLS/SSL, etc., which can ensure the safety and reliability of network data transmission.
Flexibility: IPQ5018 supports a variety of peripheral interfaces, such as USB, PCIe, etc., which can be easily connected and communicated with other devices, and also supports a variety of operating systems, including Linux, Android, etc., with high flexibility and reliability scalability.
Low power consumption: IPQ5018 adopts advanced manufacturing technology and energy-saving design, with low power consumption and heat, suitable for various embedded application scenarios, such as smart home, Internet of Things, smart manufacturing, etc.
