没有调用子函数却执行
2396|2
 楼主| cotinue 发表于 2012-4-28 22:55 | 显示全部楼层 |阅读模式
程序如下,程序总是执行错误,不知道为啥。
#include <AT89X52.H>
#define uint8    unsigned char
#define uint16   unsigned short int
#define uint32   unsigned int
bit Tflag=0;
bit Dflag=0;
uint8 Timer_counter=0;
uint8 sec=0;
uint8 min=0;
uint8 hour=0;
uint8 day=0;
uint8 code num0[10]={48,49,50,51,52,53,54,55,56,57};
#define MHz     1000000U           // 定义 MHz
#define gCLK    (11.0592*MHz)      // 系统时钟频率
#define UART_BAUD   9600           // 定义所用的波特率
void UartInit();
void SendChar(uint8 t);
void SetBcolor(uint16 bcolor);
void SendBeginCMD();
void SendEndCmd();
void GUI_CleanScreen();
void DisData(uint16 x, uint16 y,uint8 back,uint8 font,uint8 sdata);
void distime(uint8 dissec,uint8 dismin, uint8 dishour);
void Timer0(void) interrupt 1 using 1
Timer_counter++;
if(Timer_counter==20)
  Timer_counter=0;
  TH0=0x4c;
  TL0=0x00;
  Tflag=1;
}else
  TH0=0x4c;
  TL0=0x00;
void main()
UartInit();
TMOD|=0x01;
TH0=0x4c;
TL0=0x00;
EA=1;
ET0=1;
TR0=1;
PT0=1;
SetBcolor(63488);
GUI_CleanScreen();
hour=12;
min=0;
sec=0;
while(1)
  if(Tflag==1)
   Tflag=0;
   sec++;
   if(sec==60)
    min++;
    sec=0;
    if(min==60)
     hour++;
     min=0;
     if(hour==24)
       Dflag=1;
       hour=0;
   };  SetBcolor(0x1f);
   GUI_CleanScreen();
   distime(sec,min,hour);
   if(Dflag==1)
     day++;
     Dflag=0;
uint8 sec1,sec0,min1,min0,hour1,hour0;
sec1=dissec/10; sec0=dissec%10;
min1=dismin/10; min0=dismin%10;
hour1=dishour/10; hour0=dishour%10;
DisData(220, 218, 1, 1, num0[hour1]);
DisData(250, 218, 1, 1, num0[hour0]);
DisData(300, 218, 1, 1, num0[min1]);
DisData(330, 218, 1, 1, num0[min0]);
DisData(380, 218, 1, 1, num0[sec1]);
DisData(410, 218, 1, 1, num0[sec0]);
   SendBeginCMD();
   SendChar(0x42);
   SendChar((bcolor>>8)&0xff);
   SendChar(bcolor&0xff);
   SendEndCmd();
   SendBeginCMD();
   SendChar(0x01);
   SendEndCmd();
void SendBeginCMD()
   SendChar(0xEE);
void SendEndCmd()
   SendChar(0xFF);
   SendChar(0xFC);
   SendChar(0xFF);
   SendChar(0xFF);
void UartInit()
{ SCON  = 0x50;
TMOD |= 0x20;
PCON  = 0x80;
TH1   = 256 - (uint8)(gCLK/192.0F/UART_BAUD);
TR1   = 1;
IE |=0X90;
    SBUF=t;
    while(TI==0);
    TI=0;
void DisData(uint16 x, uint16 y,uint8 back,uint8 font,uint8 sdata )
   SendBeginCMD();
   SendChar(0x20);
   SendChar((x>>8)&0xff);
   SendChar(x&0xff);
   SendChar((y>>8)&0xff);
   SendChar(y&0xff);
   SendChar(back);
   SendChar(font);
   SendChar(sdata);
   SendEndCmd();
原野之狼 发表于 2012-4-28 23:46 | 显示全部楼层
看NE5532的历史发帖  好好学习下
zd420325 发表于 2012-4-30 10:38 | 显示全部楼层
哥你写程序能有点注释不?
个人签名:为生活困扰。。
