烧写成功了么
360|0
 楼主| ousj 发表于 2023-7-31 22:32 | 显示全部楼层 |阅读模式
Connecting to MPLAB PICkit 4...
Currently loaded versions:
Application version............00.02.01
FPGA version...................ff.ff.ff
Script version.................00.02.23
Script build number............45a591cbc0
Application build number.......0123456789
PICKit 4 is supplying power to the target (3.30 volts).
Target Device ID (0x6180) is an Invalid Device ID. Please check your connections to the Target Device.
Erasing...
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x3f
program memory: start address = 0x7fc0, end address = 0x7fff
configuration memory
Programming/Verify complete
