| GENERAL DESCRIPTION The ZCC3302 is a 7.5V step-up DC/DC converter
 designed for driving up to single 10-series or
 9x3-series WLEDs from a single cell Lithium Ion-
 battery.
 The ZCC3302 uses current mode, fixed frequency
 architecture to regulate the LED current, which is
 measured through an external current sense resistor.
 Its low 300mV feedback voltage reduces power loss
 and improves efficiency. The ZCC3302 supports hig-
 h frequency PWM Dimming through EN pin.
 The ZCC3302 is turned off if an open-circuit condition
 is presented. Please be noted that open-circuit
 condition is not the same as over-voltage condition..
 Please refer to the OPERATION DESCRIPTION and
 APPLICATION INFORMATION sections for more
 detail.
 The ZCC3302 includes soft-start, under-voltage locko-
 ut, current limiting and thermal overload protections.
 The ZCC3302 is available in SOT23-6 package.
 FEATURES
  Operating Voltage: 2.5-7.5V
  Maximum Output Voltage: 35V, capable of
 driving 10-series White LED strings
  Maximum drive Capability: 9x3-series or
 6x6-series.
  Up to 90% Efficiency
  1.25MHz Fixed Switching Frequency
  Low 300mV Feedback Voltage
  Support PWM Dimming
  Open-circuit Protection
  UVLO, Soft-Start and Thermal Shutdown
  Internal 1.5A Current Limit
  SOT23-6 Package
 APPLICATIONS
  5~7” LCD Panels
  Handheld Computers and PDAs
  Digital Cameras
  Small LCD Displays
