[STM32G0] STM32G0F6P6芯片,同时使能RTC和IWDG,结果运行了之后串口没反应.
392|1
 楼主| 两只袜子 发表于 2023-10-11 09:53 | 显示全部楼层 |阅读模式
对比了一下,即使能LSI和LSE时钟,估计没有起振;例程只使能了HSI,就可以运行。
使能三个时钟:
void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
/ Configure the main internal regulator output voltage */ HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1); /* Configure LSE Drive Capability / __HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_LOW); / Initializes the CPU, AHB and APB busses clocks */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSI |RCC_OSCILLATORTYPE_LSE; RCC_OscInitStruct.LSEState = RCC_LSE_ON; RCC_OscInitStruct.HSIState = RCC_HSI_ON; RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1; RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT; RCC_OscInitStruct.LSIState = RCC_LSI_ON; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI; RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1; RCC_OscInitStruct.PLL.PLLN = 8; RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2; RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2; if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } /* Initializes the CPU, AHB and APB busses clocks / RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK) { Error_Handler(); } /* Initializes the peripherals clocks / PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC|RCC_PERIPHCLK_USART1 |RCC_PERIPHCLK_ADC; PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1; PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_SYSCLK; PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK) { Error_Handler(); } }
/ USER CODE BEGIN 4 /
/ USER CODE END 4 /
  • @brief This function is executed in case of error occurrence.
  • @retval None / void Error_Handler(void) { / USER CODE BEGIN Error_Handler_Debug / / User can add his own implementation to report the HAL error return state */
/ USER CODE END Error_Handler_Debug / }
ifdef USE_FULL_ASSERT
  • @brief Reports the name of the source file and the source line number
  • where the assert_param error has occurred.
    • @param file: pointer to the source file name
    • @param line: assert_param error line source number
    • @retval None / void assert_failed(uint8_t file, uint32_t line) { / USER CODE BEGIN 6 / / User can add his own implementation to report the file name and line number, tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) / / USER CODE END 6 / }endif / USE_FULL_ASSERT /
      /**** (C) COPYRIGHT STMicroelectronics *END OF FILE/
Stahan 发表于 2023-10-11 19:42 | 显示全部楼层
晶振原因不起振吗
