ZCC103数字温度传感器芯片替代TMP103
2052|0
 楼主| ZCCChina 发表于 2023-10-25 09:19 | 显示全部楼层 |阅读模式
Description
  The ZCC103 is a digital output temperature sensor in
a four-ball wafer chip-scale package (WCSP).The
ZCC103 is capable of reading temperatures to
aresolution of 1°C.
  The ZCC103features a two-wire interface that is
compatible with both I2C and SMBus interfaces. In
addition, the interface supports multiple device
access (MDA) commands that allow the master to
communicate with multiple devices on the bus
simultaneously, eliminating the need to send
individual commands to each ZCC103 on the bus.
Up to eight ZCC103 can be tied together in parallel
and easily read by the host. The ZCC103is
especially suitable for space-constrained, power-s
ensitive applications with multiple temperature
measurement zones that must be monitored.
The ZCC103 is specified for operation over ate
mperature range of –40°C to 125°C.
Features
Multiple Device Access (MDA):
– Global Read/Write Operations
I2C™ and SMBus™-Compatible Interface
Resolution: 8 Bits
Accuracy: ±1°C Typical (–10°C to 100°C)
Low Quiescent Current:
– 3-μA Active IQ at 0.25 Hz
– 1-μA Shutdown
Supply Range: 1.4 V to 3.6 V
Digital Output
4-Ball WCSP (DSBGA) Package
Applications
Handsets
Notebooks
SSDs
Servers
Telecom
Set Top Boxes
ZCC103
Low Power Environmental
Sensors
