- ADC_HandleTypeDef hadc1;//ADC句柄
- //初始化ADC
- void MY_ADC_Init(void)
- hadc1.Instance = ADC1;
- hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4; //4分频,ADCCLK=PCLK2/4=90/4=22.5MHZ
- hadc1.Init.Resolution = ADC_RESOLUTION_12B; //12位模式
- hadc1.Init.ScanConvMode = DISABLE; //非扫描模式
- hadc1.Init.ContinuousConvMode = DISABLE; //关闭连续转换
- hadc1.Init.DiscontinuousConvMode = DISABLE; //禁止不连续采样模式
- hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; //使用软件触发
- hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START; //软件触发
- hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT; //右对齐
- hadc1.Init.NbrOfConversion = 1; //1个转换在规则序列中 也就是只转换规则序列1
- hadc1.Init.DMAContinuousRequests = DISABLE; //关闭DMA请求
- hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV; //关闭EOC中断
- if (HAL_ADC_Init(&hadc1) != HAL_OK) //初始化
- Error_Handler();
- //ADC底层驱动,引脚配置,时钟使能
- //此函数会被HAL_ADC_Init()调用
- //hadc:ADC句柄
- void HAL_ADC_MspInit(ADC_HandleTypeDef* adcHandle)
- if(adcHandle->Instance==ADC1)
- __HAL_RCC_ADC1_CLK_ENABLE(); //使能ADC1时钟
- //获得ADC值
- uint16_t get_adc(uint32_t ch)
- ADC_ChannelConfTypeDef sConfig = {0};
- sConfig.Channel = ADC_CHANNEL_TEMPSENSOR; //选择内部温度传感器通道
- sConfig.Rank = 1; //1个序列
- sConfig.SamplingTime = ADC_SAMPLETIME_480CYCLES; //采样时间
- if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)//通道配置
- Error_Handler();
- HAL_ADC_Start(&hadc1); //开启ADC
- HAL_ADC_PollForConversion(&hadc1,10); //轮询转换
- return (uint16_t )HAL_ADC_GetValue(&hadc1); //返回最近一次ADC1规则组的转换结果
- //获取指定通道的转换值,取times次,然后平均
- //times:获取次数
- //返回值:通道ch的cnt次转换结果平均值
- uint16_t Get_Adc_Average(uint32_t ch,uint8_t cnt)
- uint32_t temp_val=0;
- uint8_t n;
- for(n=0;n<cnt;n++)
- temp_val+=get_adc(ch);
- delay_ms(5);
- return temp_val/cnt;
- //得到温度值
- //返回值:温度值(扩大了100倍,单位:℃.)
- short Get_Temprate(void)
- uint32_t adcx;
- short result;
- double temperate;
- adcx=Get_Adc_Average(ADC_CHANNEL_TEMPSENSOR,10);//读取内部温度传感器通道,10次取平均
- temperate=(float)adcx*(3.3/4096); //电压值
- temperate=(temperate-0.76)/0.0025 + 25; //转换为温度值
- result=temperate*=100; //扩大100倍.
- return result;
