[其他] 10个C语言基础算法
1035|1
 楼主| mickit 发表于 2023-10-29 19:50 | 显示全部楼层 |阅读模式
算法是一个程序和软件的灵魂,作为一名优秀的程序员,只有对一些基础的算法有着全面的掌握,才会在设计程序和编写代码的过程中显得得心应手。本文是近百个C语言算法系列的第二篇,包括了经典的Fibonacci数列、简易计算器、回文检查、质数检查等算法。
1、计算Fibonacci数列
Fibonacci数列又称斐波那契数列,又称黄金分割数列,指的是这样一个数列:1、1、2、3、5、8、13、21。
C语言实现的代码如下:
/* Displaying Fibonacci sequence up to nth term where n is entered by user. */
#include
int main()
int count, n, t1=0, t2=1, display=0;
printf("Enter number of terms: ");
scanf("%d",&n);
printf("Fibonacci Series: %d+%d+", t1, t2); /* Displaying first two terms */
count=2; /* count=2 because first two terms are already displayed. */
while (count
display=t1+t2;
t1=t2;
t2=display;
++count;
printf("%d+",display);
return 0;
结果输出:
Enter number of terms: 10
Fibonacci Series: 0+1+1+2+3+5+8+13+21+34+
也可以使用下面的源代码:
/* Displaying Fibonacci series up to certain number entered by user. */
#include
int main()
int t1=0, t2=1, display=0, num;
printf("Enter an integer: ");
scanf("%d",&num);
display=t1+t2;
while(display
t1=t2;
t2=display;
display=t1+t2;
return 0;
结果输出:
Enter an integer: 200
Fibonacci Series: 0+1+1+2+3+5+8+13+21+34+55+89+144+
2、回文检查
源代码:
/* C program to check whether a number is palindrome or not */
#include
int main()
int n, reverse=0, rem,temp;
scanf("%d", &n);
temp=n;
while(temp!=0)
rem=temp%10;
reverse=reverse*10+rem;
temp/=10;
/* Checking if number entered by user and it's reverse number is equal. */
if(reverse==n)
printf("%d is a palindrome.",n);
else
printf("%d is not a palindrome.",n);
return 0;
结果输出:
Enter an integer: 12321
12321 is a palindrome.
3、质数检查
注:1既不是质数也不是合数。
源代码:
/* C program to check whether a number is prime or not. */
#include
int main()
int n, i, flag=0;
printf("Enter a positive integer: ");
scanf("%d",&n);
for(i=2;i<=n/2;++i)
if(n%i==0)
flag=1;
break;
if (flag==0)
printf("%d is a prime number.",n);
else
printf("%d is not a prime number.",n);
return 0;
结果输出:
Enter a positive integer: 29
29 is a prime number.
4、打印金字塔和三角形
使用 * 建立三角形
源代码:
#include
int main()
int i,j,rows;
printf("Enter the number of rows: ");
scanf("%d",&rows);
for(i=1;i<=rows;++i)
for(j=1;j<=i;++j)
printf("* ");
printf("\n");
return 0;
如下图所示使用数字打印半金字塔。
1 2 3
1 2 3 4
1 2 3 4 5
源代码:
#include
int main()
int i,j,rows;
scanf("%d",&rows);
for(j=1;j<=i;++j)
printf("%d ",j);
printf("\n");
return 0;
用 * 打印半金字塔
源代码:
#include
int main()
int i,j,rows;
scanf("%d",&rows);
for(i=rows;i>=1;--i)
for(j=1;j<=i;++j)
printf("* ");
printf("\n");
return 0;
用 * 打印金字塔
源代码:
#include
int main()
int i,space,rows,k=0;
scanf("%d",&rows);
for(space=1;space<=rows-i;++space)
printf(" ");
while(k!=2*i-1)
printf("* ");
++k;
k=0;
printf("\n");
return 0;
用 * 打印倒金字塔
源代码:
#include
int main()
int rows,i,j,space;
printf("Enter number of rows: ");
scanf("%d",&rows);
for(space=0;space
printf(" ");
for(j=i;j<=2*i-1;++j)
printf("* ");
for(j=0;j
printf("* ");
printf("\n");
return 0;
5、简单的加减乘除计算器
源代码:
/* Source code to create a simple calculator for addition, subtraction, multiplication and division using switch...case statement in C programming. */
# include
int main()
char o;
float num1,num2;
printf("Enter operator either + or - or * or divide : ");
scanf("%c",&o);
printf("Enter two operands: ");
scanf("%f%f",&num1,&num2);
switch(o) {
case '+':
printf("%.1f + %.1f = %.1f",num1, num2, num1+num2);
break;
case '-':
printf("%.1f - %.1f = %.1f",num1, num2, num1-num2);
break;
case '*':
printf("%.1f * %.1f = %.1f",num1, num2, num1*num2);
break;
case '/':
printf("%.1f / %.1f = %.1f",num1, num2, num1/num2);
break;
default:
/* If operator is other than +, -, * or /, error message is shown */
printf("Error! operator is not correct");
break;
return 0;
结果输出:
Enter operator either + or - or * or divide : -
Enter two operands: 3.4
8.4
3.4 - 8.4 = -5.0
6、检查一个数能不能表示成两个质数之和
源代码:
#include
int prime(int n);
int main()
int n, i, flag=0;
scanf("%d",&n);
for(i=2; i<=n/2; ++i)
if (prime(i)!=0)
if ( prime(n-i)!=0)
printf("%d = %d + %d\n", n, i, n-i);
flag=1;
if (flag==0)
printf("%d can't be expressed as sum of two prime numbers.",n);
return 0;
int prime(int n) /* Function to check prime number */
int i, flag=1;
if(n%i==0)
flag=0;
return flag;
结果输出:
Enter a positive integer: 34
34 = 3 + 31
34 = 5 + 29
34 = 11 + 23
34 = 17 + 17
7、用递归的方式颠倒字符串
源代码:
/* Example to reverse a sentence entered by user without using strings. */
#include
void Reverse();
int main()
printf("Enter a sentence: ");
Reverse();
return 0;
void Reverse()
char c;
scanf("%c",&c);
if( c != '\n')
Reverse();
printf("%c",c);
结果输出:
Enter a sentence: margorp emosewa
awesome program
8、实现二进制与十进制之间的相互转换
/* C programming source code to convert either binary to decimal or decimal to binary according to data entered by user. */
#include
#include
int binary_decimal(int n);
int decimal_binary(int n);
int main()
int n;
char c;
printf("Instructions:\n");
printf("1. Enter alphabet 'd' to convert binary to decimal.\n");
printf("2. Enter alphabet 'b' to convert decimal to binary.\n");
scanf("%c",&c);
if (c =='d' || c == 'D')
printf("Enter a binary number: ");
scanf("%d", &n);
printf("%d in binary = %d in decimal", n, binary_decimal(n));
if (c =='b' || c == 'B')
printf("Enter a decimal number: ");
scanf("%d", &n);
printf("%d in decimal = %d in binary", n, decimal_binary(n));
return 0;
int decimal_binary(int n) /* Function to convert decimal to binary.*/
int rem, i=1, binary=0;
while (n!=0)
rem=n%2;
n/=2;
binary+=rem*i;
i*=10;
return binary;
int binary_decimal(int n) /* Function to convert binary to decimal.*/
int decimal=0, i=0, rem;
while (n!=0)
rem = n%10;
n/=10;
decimal += rem*pow(2,i);
++i;
return decimal;
结果输出:
9、使用多维数组实现两个矩阵的相加
源代码:
#include
int main(){
int r,c,a[100][100],b[100][100],sum[100][100],i,j;
printf("Enter number of rows (between 1 and 100): ");
scanf("%d",&r);
printf("Enter number of columns (between 1 and 100): ");
scanf("%d",&c);
printf("\nEnter elements of 1st matrix:\n");
/* Storing elements of first matrix entered by user. */
for(i=0;i
for(j=0;j
printf("Enter element a%d%d: ",i+1,j+1);
scanf("%d",&a[j]);
/* Storing elements of second matrix entered by user. */
printf("Enter elements of 2nd matrix:\n");
for(i=0;i
for(j=0;j
scanf("%d",&b[j]);
/*Adding Two matrices */
for(i=0;i
for(j=0;j
sum[j]=a[j]+b[j];
/* Displaying the resultant sum matrix. */
printf("\nSum of two matrix is: \n\n");
for(i=0;i
for(j=0;j
printf("%d ",sum[j]);
if(j==c-1)
printf("\n\n");
return 0;
结果输出:
10、矩阵转置
源代码:
#include
int main()
int a[10][10], trans[10][10], r, c, i, j;
printf("Enter rows and column of matrix: ");
scanf("%d %d", &r, &c);
/* Storing element of matrix entered by user in array a[][]. */
printf("\nEnter elements of matrix:\n");
for(i=0; i
for(j=0; j
printf("Enter elements a%d%d: ",i+1,j+1);
scanf("%d",&a[j]);
/* Displaying the matrix a[][] */
printf("\nEntered Matrix: \n");
for(i=0; i
for(j=0; j
printf("%d ",a[j]);
if(j==c-1)
printf("\n\n");
/* Finding transpose of matrix a[][] and storing it in array trans[][]. */
for(i=0; i
for(j=0; j
trans[j]=a[j];
/* Displaying the transpose,i.e, Displaying array trans[][]. */
printf("\nTranspose of Matrix:\n");
for(i=0; i
for(j=0; j
printf("%d ",trans[j]);
if(j==r-1)
printf("\n\n");
return 0;
结果输出:
MessageRing 发表于 2023-10-30 12:08 | 显示全部楼层
斐波那契数列在单片机上有什么应用啊
