- /*_____ I N C L U D E S ____________________________________________________*/
 - #include "ML51.h"
- #include "project_config.h"
 - #include "LED_stripe.h"
- /*_____ D E C L A R A T I O N S ____________________________________________*/
 - // xdata volatile uint8_t u8TH0_Tmp = 0;
 - // xdata volatile uint8_t u8TL0_Tmp = 0;
- #define TH0_INIT                                                        (HIBYTE(TIMER_DIV12_VALUE_1ms_FOSC_240000))
 - #define TL0_INIT                                                        (LOBYTE(TIMER_DIV12_VALUE_1ms_FOSC_240000))
- //UART 0
 - bit BIT_UART;
 - bit uart0_receive_flag=0;
 - unsigned char uart0_receive_data;
- uint16_t counter = 0;
 - /*_____ D E F I N I T I O N S ______________________________________________*/
 - volatile uint32_t BitFlag = 0;
 - volatile uint32_t counter_tick = 0;
- /*_____ M A C R O S ________________________________________________________*/
 - #define SYS_CLOCK        (24000000ul)
- /*_____ F U N C T I O N S __________________________________________________*/
- void tick_counter(void)
 -         counter_tick++;
- uint32_t get_tick(void)
 -         return (counter_tick);
- void set_tick(uint32_t t)
 -         counter_tick = t;
- //void compare_buffer(uint8_t *src, uint8_t *des, int nBytes)
 - //    uint16_t i = 0;
 - //    for (i = 0; i < nBytes; i++)
 - //        if (src[i] != des[i])
 - //            printf("error idx : %4d : 0x%2X , 0x%2X\r\n", i , src[i],des[i]);
 - //                        set_flag(flag_error , Enable);
- //        if (!is_flag_set(flag_error))
 - //            printf("compare_buffer finish \r\n");
 - //                set_flag(flag_error , Disable);
- //void reset_buffer(void *dest, unsigned int val, unsigned int size)
 - //    uint8_t *pu8Dest;
 - ////    unsigned int i;
 - //    pu8Dest = (uint8_t *)dest;
- //        #if 1
 - //        while (size-- > 0)
 - //                *pu8Dest++ = val;
 - //        #else
 - //        memset(pu8Dest, val, size * (sizeof(pu8Dest[0]) ));
 - //        #endif
- //void copy_buffer(void *dest, void *src, unsigned int size)
 - //    uint8_t *pu8Src, *pu8Dest;
 - //    unsigned int i;
 - //    pu8Src  = (uint8_t *)src;
- //        #if 0
 - //          while (size--)
 - //            *pu8Dest++ = *pu8Src++;
 - //        #else
 - //    for (i = 0; i < size; i++)
 - //        pu8Dest[i] = pu8Src[i];
 - //        #endif
- //void dump_buffer(uint8_t *pucBuff, int nBytes)
 - //    printf("dump_buffer : %2d\r\n" , nBytes);
 - //    for (i = 0 ; i < nBytes ; i++)
 - //        printf("0x%2X," , pucBuff[i]);
 - //        if ((i+1)%8 ==0)
 - //            printf("\r\n");
 - //    printf("\r\n\r\n");
- //void  dump_buffer_hex(uint8_t *pucBuff, int nBytes)
 - //    int     nIdx, i;
- //    nIdx = 0;
 - //    while (nBytes > 0)
 - //        printf("0x%04X  ", nIdx);
 - //        for (i = 0; i < 16; i++)
 - //            printf("%02X ", pucBuff[nIdx + i]);
 - //        printf("  ");
 - //            if ((pucBuff[nIdx + i] >= 0x20) && (pucBuff[nIdx + i] < 127))
 - //                printf("%c", pucBuff[nIdx + i]);
 - //            else
 - //                printf(".");
 - //            nBytes--;
 - //        nIdx += 16;
 - //        printf("\n");
 - //    printf("\n");
- void delay(uint16_t dly)
 -         delay(100) : 14.84 us
 -         delay(200) : 29.37 us
 -         delay(300) : 43.97 us
 -         delay(400) : 58.5 us
 -         delay(500) : 73.13 us
 -         delay(1500) : 0.218 ms (218 us)
 -         delay(2000) : 0.291 ms (291 us)
-         while( dly--);
- //void send_UARTString(uint8_t* Data)
 - //        #if 1
- //        while (Data[i] != '\0')
 - //                #if 1
 - //                SBUF = Data[i++];
 - //                #else
 - //                UART_Send_Data(UART0,Data[i++]);
 - //                #endif
- //        #endif
- //        #if 0
 - //        for(i = 0;i< (strlen(Data)) ;i++ )
 - //                UART_Send_Data(UART0,Data[i]);
 - //        #endif
- //        #if 0
 - //    while(*Data)
 - //        UART_Send_Data(UART0, (unsigned char) *Data++);
 - //        #endif
- //void send_UARTASCII(uint16_t Temp)
 - //    uint8_t print_buf[16];
 - //    uint16_t i = 15, j;
- //    *(print_buf + i) = '\0';
 - //    j = (uint16_t)Temp >> 31;
 - //    if(j)
 - //        (uint16_t) Temp = ~(uint16_t)Temp + 1;
 - //    do
 - //        i--;
 - //        *(print_buf + i) = '0' + (uint16_t)Temp % 10;
 - //        (uint16_t)Temp = (uint16_t)Temp / 10;
 - //    while((uint16_t)Temp != 0);
 - //    if(j)
 - //        i--;
 - //        *(print_buf + i) = '-';
 - //    send_UARTString(print_buf + i);
- void WS2812C_Init(void)
 -         #if defined (ENABLE_SPI)
-         #if 1
 -     /* Set LED output */
 -     P00 = 1;
 -     P00_INPUT_MODE;
 -     ENABLE_P00_PULLDOWN;
 -         #endif
-     MFP_P00_SPI0_MOSI;
 -     // P00_QUASI_MODE;
-     MFP_P02_SPI0_CLK;       /*define  SPI0 CLK pin */
 -     P02_QUASI_MODE;
 -         #if 0
 -     MFP_P01_SPI0_MISO;      /*define  SPI0 MISO pin */
 -     P01_QUASI_MODE;
-     MFP_P03_GPIO;           /*define  SPI0 SS pin as normal GPIO*/
 -     P03_PUSHPULL_MODE;
 -         #endif
-     set_SPI0SR_DISMODF;                                        // SS General purpose I/O ( No Mode Fault )
 -     clr_SPI0CR0_SSOE;
-     clr_SPI0CR0_LSBFE;                                  // MSB first
-     clr_SPI0CR0_CPOL;                                   // The SPI clock is low in idle mode
 -     clr_SPI0CR0_CPHA;                                   // The data is sample on the second edge of SPI clock
-     set_SPI0CR0_MSTR;                                   // SPI in Master mode
 -     SPI0_CLOCK_DIV_3;                                        // Select SPI clock
 -     set_SPI0CR0_SPIEN;                                  // Enable SPI function
 -     clr_SPI0SR_SPIF;
-         #elif defined (ENABLE_GPIO_EMULATE)
 -         P00_PUSHPULL_MODE;
 -         P02_PUSHPULL_MODE;        // for debug
 -         #endif
- void loop(void)
 -         static uint8_t flag_first_pwr_on = 1;
-         if (is_flag_set(flag_1000ms))
 -                 set_flag(flag_1000ms , FALSE);
 -                 P32 ^= 1;
 -                 SFRS = 0;printf("log :%d\r\n" , counter++);
-     if (RI)
 -                 clr_SCON_RI;                                         // Clear RI (Receive Interrupt).
-                 if (flag_first_pwr_on)
 -                         DemoState = state_Rainbow;
 -                         flag_first_pwr_on = 0;
 -                 else
 -                         DemoState = SBUF - 0x30;
-                 SFRS = 0;printf("DemoState = %bu,%bc\r\n" , DemoState, SBUF);
-         if (!trans_finish_flag)
 -                 #if defined (ENABLE_DEBUG_WS2812_PROTOCOL)
 -                 setLED_ColorWipe(0xFF, 0x00, 0x00);
 -                 setLED_delayms(1);
 -                 #else
-                 StateMachine();
 -                 #endif
- void GPIO_Init(void)
 -     MFP_P32_GPIO;
 -     P32_PUSHPULL_MODE;
- //        P30_PUSHPULL_MODE;
- void Timer0_IRQHandler(void)
 -         tick_counter();
-         if ((get_tick() % 1000) == 0)
 -                 set_flag(flag_1000ms , TRUE);
-         if ((get_tick() % 50) == 0)
- void Timer0_ISR(void) interrupt 1        // Vector [url=home.php?mod=space&uid=72445]@[/url]  0x0B
 -         _push_(SFRS);
 -         SFRS = 0;
-         clr_TCON_TF0;
 -         TH0 = TH0_INIT;
 -         TL0 = TL0_INIT;
-         Timer0_IRQHandler();
 -         _pop_(SFRS);
- void Timer0_Init(void)
 -         ENABLE_TIMER0_MODE1;
 -         TIMER0_FSYS_DIV12;
-         TH0 = TH0_INIT;
 -         TL0 = TL0_INIT;
 -         clr_TCON_TF0;
-         set_TCON_TR0;                                  //Timer0 run
 -         ENABLE_TIMER0_INTERRUPT;                       //enable Timer0 interrupt
 -         ENABLE_GLOBAL_INTERRUPT;                       //enable interrupts
- // void Serial_ISR (void) interrupt 4
 - //     _push_(SFRS);
- //     if (RI)
 - //       uart0_receive_flag = 1;
 - //       uart0_receive_data = SBUF;
 - //       clr_SCON_RI;                                         // Clear RI (Receive Interrupt).
 - //     if  (TI)
 - //                 clr_SCON_TI;
 - //                 //      if(!BIT_UART)
 - //                 //          TI = 0;
- //     _pop_(SFRS);
- void UART0_Init(void)
 -         MFP_P31_UART0_TXD;
 -         P31_QUASI_MODE;
 -         MFP_P30_UART0_RXD;
 -         P30_QUASI_MODE;
-         SFRS = 0x00;
 -         SCON = 0x50;                    /*UART0 Mode1,REN=1,TI=1*/
 -         set_PCON_SMOD;                  /*UART0 Double Rate Enable*/
 -         T3CON &= 0xF8;                   /*T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1)*/
 -         set_T3CON_BRCK;                  /*UART0 baud rate clock source = Timer3*/
 -         RH3    = 0xFF;                                           /* HIBYTE(65536 - 13)*/
 -         RL3    = 0xF3;                                           /* LOBYTE(65536 - 13); */
 -         set_T3CON_TR3;                  /*Trigger Timer3*/
-         set_SCON_RI;
 -         set_SCON_TI;
 -         BIT_UART = 1;
-         // ENABLE_UART0_INTERRUPT;                                   /* Enable UART0 interrupt */
 -         // ENABLE_GLOBAL_INTERRUPT;                                  /* Global interrupt enable */
-         SFRS = 0;printf("\r\n\r\n\r\n\r\nUART0_Init\r\n");
- void SYS_Init(void)
 - //        FsysSelect(FSYS_HIRC);
-     ALL_GPIO_QUASI_MODE;
 - //    ENABLE_GLOBAL_INTERRUPT;                // global enable bit
- void main (void)
 -         SYS_Init();
-         UART0_Init();
 -         GPIO_Init();
-     WS2812C_Init();
 -         // setLED_ColorWipe(0, 0, 0);
-         Timer0_Init();
-         while(1)
 -                 loop();
