CCS连接错误
3422|2
 楼主| 三色瑾three 发表于 2012-5-10 16:56 | 显示全部楼层 |阅读模式
ccs, TI, AN, TE, se
在CCS3.3的开发环境下,拿TDS560仿真器连接omapl138的板子,在reset_TDS560USB_plus时出现如下错误:
C:\CCStudio_v3.3\cc\bin>dbgjtag -f brddat\ccbrd0.dat -rv
[Print the reset-command software log-file]-----------------------------
This utility has selected an XDS560 class product.
This utility will load the program 'bh560usbM.out'.
This utility will operate on port address '0'.
Connect failure
An error occurred while soft opening the controller.
[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver.
The value is '-250' (0xffffff06).
The title is 'SC_ERR_ECOM_EMUNAME'.
The explanation is:
An attempt to access the named emulator via USCIF ECOM has failed
各位高手啊,大神啊,帮帮忙,看一下
 楼主| 三色瑾three 发表于 2012-5-12 15:41 | 显示全部楼层
帮帮忙啊
 楼主| 三色瑾three 发表于 2012-5-12 15:44 | 显示全部楼层
问题还没有人回答却已结贴~郁闷
