例程分享- /*源代码*/
- #include "AT24.h"
- uint8_t AT24_ADDR_W1 = 0XA0;
- uint8_t AT24_ADDR_W2 = 0XA2;
- uint8_t AT24_ADDR_R1 = 0xA1;
- uint8_t AT24_ADDR_R2 = 0xA3;
- * @brief AT24C04初始化
- * @param None
- * @retval None
- void AT24_init(void){
- myi2c_init();
- * @brief 指定地址写入一个字节数据(0 ---- 255)
- * @param uint16_t addr 写入数据地址
- * @param uint8_t data 写入字节
- * @retval 写入成功返回4
- uint8_t AT24_write_byte(uint16_t addr, uint8_t data){
- i2c_start(); //发送起始信号
- myi2c_sendbyte(AT24_ADDR_W1); //发送从机地址
- if(myi2c_recv_ack() == 1){
- i2c_stop(); //发送停止位
- printf("AT24寻址未应答\r\n");
- return 1;
- myi2c_sendbyte(addr); //发送要写入的地址
- printf("AT24内部寻址未应答\r\n");
- return 2;
- myi2c_sendbyte(data); //发送要写入的数据
- printf("AT24写入数据未应答\r\n");
- return 3;
- printf("AT24写入数据成功\r\n");
- return 4;
- * @brief 指定地址读出一个字节数据(0 ---- 255)
- * @param uint16_t addr 读数据地址
- * @retval 成功返回读出数据
- uint8_t AT24_read_byte(uint16_t addr){
- uint8_t read_data = 0;
- return 1;
- return 2;
- myi2c_sendbyte(AT24_ADDR_R1); //发送从机地址
- return 1;
- read_data = myi2c_recv_byte();
- myi2c_send_ack(1);
- return read_data;
- * @brief 指定地址页写入数据(0 ---- 255)
- * @param uint8_t data 写入字节首地址
- * @param uint8_t num 写入字节个数
- * @retval 写入成功返回4
- uint8_t AT24_write_page(uint16_t addr, uint8_t num, uint8_t *data){
- return 1;
- return 2;
- while(num--){
- myi2c_sendbyte(*data); //发送要写入的数据
- return 3;
- data++;
- return 4;
- * @brief 随机写
- * @param uint8_t *pBuffer 写入数据的首地址
- * @param uint32_t WriteAddr 写入地址
- * @param uint16_t NumByteToWrite 数据长度
- * @retval None
- void AT24_WriteBuffer(uint8_t *pBuffer, uint32_t WriteAddr, uint16_t NumByteToWrite){
- uint8_t NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0, temp = 0;
- Addr = WriteAddr % 16; //判断地址是否为整页
- count = 16 - Addr; //当前页剩余字节数
- NumOfPage = NumByteToWrite / 16; //需要的整页数
- NumOfSingle = NumByteToWrite % 16; //除整页剩余的字节数
- if (Addr == 0) /*整页开始 */
- if (NumOfPage == 0) /*所写数据不够一整页,直接调用页编程函数 */
- AT24_write_page(WriteAddr, NumByteToWrite, pBuffer);
- else /*所写数据超过一页*/
- while (NumOfPage--) //整页写
- AT24_write_page(WriteAddr, 16, pBuffer);
- WriteAddr += 16;
- pBuffer += 16;
- AT24_write_page(WriteAddr, NumOfSingle, pBuffer); //除整页之外剩余的
- else /*不是整页开始写 */
- if (NumOfPage == 0) /*所写不到一页 */
- if (NumOfSingle > count) /*所需空间大于当前页所剩空间*/
- temp = NumOfSingle - count; //当前页写完之后剩余量
- AT24_write_page(WriteAddr, count, pBuffer); //在当前页写,写满
- WriteAddr += count;
- pBuffer += count;
- AT24_write_page(WriteAddr, temp, pBuffer); //剩余写入下一页
- else
- AT24_write_page(WriteAddr, NumByteToWrite, pBuffer); //直接写当前页
- else /*写入数据量大于一页 */
- NumByteToWrite -= count; //写满当前页所剩数据
- NumOfPage = NumByteToWrite / 16; //要写入的整页
- NumOfSingle = NumByteToWrite % 16; //写完整页剩余的字节
- AT24_write_page(WriteAddr, count, pBuffer);//把当前页写满
- pBuffer += count;
- while (NumOfPage--) //写整页
- WriteAddr += 16;
- pBuffer += 16;
- if (NumOfSingle != 0) //写剩余不满一页的字节
- * @brief 随便读
- * @param None
- * @retval None
- uint8_t AT24_readBuffer(uint16_t addr, uint16_t num, uint8_t *recvdata){
- Delay_us(10);
- printf("AT24器件寻址未应答\r\n");
- return 1;
- return 2;
- printf("AT24器件2寻址未应答\r\n");
- return 1;
- while(num--){
- *recvdata = myi2c_recv_byte();
- myi2c_send_ack(0);
- recvdata++;
- Delay_us(5);
- return num;
