[技术讨论] CANopen之EMCY
890|1
 楼主| 储小勇_526 发表于 2024-1-8 15:47 | 显示全部楼层 |阅读模式
/*! Sets a new error with code errCode. Also sets corresponding bits in Error register (1001h)
** @param d
** @param errCode Code of the error
** @param errRegMask
** @param addInfo
** @return 1 if error, 0 if successful
UNS8 EMCY_setError(CO_Data* d, UNS16 errCode, UNS8 errRegMask, UNS16 addInfo)
        UNS8 index;
        UNS8 errRegister_tmp;
        for (index = 0; index < EMCY_MAX_ERRORS; ++index)
                if (d->error_data[index].errCode == errCode)                /* error already registered */
                        if (d->error_data[index].active)
                                MSG_WAR(0x3052, "EMCY message already sent", 0);
                                return 0;
                        } else d->error_data[index].active = 1;                /* set as active error */
                        break;
        if (index == EMCY_MAX_ERRORS)                /* if errCode not already registered */
                for (index = 0; index < EMCY_MAX_ERRORS; ++index) if (d->error_data[index].active == 0) break;        /* find first inactive error */
        if (index == EMCY_MAX_ERRORS)                /* error_data full */
                MSG_ERR(0x3053, "error_data full", 0);
                return 1;
        d->error_data[index].errCode = errCode;
        d->error_data[index].errRegMask = errRegMask;
        /* set the new state in the error state machine */
        d->error_state = Error_occurred;
        /* set Error Register (1001h) */
        for (index = 0, errRegister_tmp = 0; index < EMCY_MAX_ERRORS; ++index)
                if (d->error_data[index].active == 1) errRegister_tmp |= d->error_data[index].errRegMask;
        *d->error_register = errRegister_tmp;
        /* set Pre-defined Error Field (1003h) */
        for (index = d->error_history_size - 1; index > 0; --index)
                *(d->error_first_element + index) = *(d->error_first_element + index - 1);
        *(d->error_first_element) = errCode | ((UNS32)addInfo << 16);
        if(*d->error_number < d->error_history_size) ++(*d->error_number);
        /* send EMCY message */
        if (d->CurrentCommunicationState.csEmergency)
                return sendEMCY(d, errCode, *d->error_register, NULL);
        else return 1;
}对这个canfestival的源码有点疑惑,有没有做过工程用过这个传递紧急报文的,想让大神给我解惑解惑。
515192147 发表于 2024-1-9 11:31 | 显示全部楼层
建议 用  CANWeb,交大老师 开发的,编程简单,并送源程序及开发板 PCB文件
详细资料见:CAN通信的高层协议CANWeb源程序及介绍:
https://bbs.21ic.com/icview-3335470-1-1.html?fromuser=515192147
个人签名:因为没有能力,所以顺其自然。
40
