[技术问答] ML51系列的I2C库函数怎么没有读写操作
1007|1
 楼主| jiekou001 发表于 2024-2-6 17:49 | 显示全部楼层 |阅读模式
  1. void I2C_Open(unsigned char u8I2CSel, unsigned long u32SYSCLK, unsigned long u32I2CCLK);
  2. void I2C_Close(unsigned char u8I2CSel);
  3. void I2C_EnableInt(unsigned char u8I2CSel);
  4. void I2C_DisableInt(unsigned char u8I2CSel);
  5. unsigned char I2C_GetStatus(unsigned char u8I2CSel);
  6. void I2C_SetSlaveAddrMask(unsigned char u8I2CSel, unsigned char u8SlaveNo, unsigned char u8SlaveAddrMask);
  7. void I2C_EnableTimeout(unsigned char u8I2CSel);
  8. void I2C_DisableTimeout(unsigned char u8I2CSel);
  9. void I2C_ClearTimeoutFlag(unsigned char u8I2CSel);
  10. void I2C_SLAVE_ADDRESS_MASK_ENABLE(unsigned char u8I2CSel, unsigned char u8I2CAddMaskBit);
  11. void I2C_SLAVE_ADDRESS_MASK_DISABLE(unsigned char u8I2CSel, unsigned char u8I2CAddMaskBit);
只有这些函数,另外没看到有I2C的示例。
jasontu 发表于 2024-2-7 09:26 | 显示全部楼层
bsp中有i2c 读写的例程。
