| 我写的这个函数,是想要完成 按下一次对应按键时,LED 以 5Hz 频率闪烁 (代表进门) ,双击对应按键时,LED 以 2Hz 频率闪烁(代表出门),每个门
 最多可以进入三次,超出进入上限时 LED 常亮 5s;这个任务,但是我发现我·按下按键后第一次能进门,第二次时就进不去了,试了好久也没改出来。求大佬帮帮
 #include <REGX52.H>
 void Timer01Init()
 TMOD = 0x11;                                                //令T0,T1的M1,M0分别为0,1.启用16定时器0,1,启用TL,TH
 TL0 = 0xD8;                                                //1ms,11.0592Hz
 TH0 = 0xF0;
 TL1 = 0xD8;
 TH1 = 0xF0;
 TF0 = 0;                                                //溢出中断标志位,为1时向cpu请求中断;
 TF1 = 0;
 TR0 = 1;                                                //先禁止定时器计数,按下按键才允许计数;1允许
 TR1 = 1;
 EA = 1;                                                        //总中断允许控制位;
 ET0 = 1;                                                //溢出中断允许位;
 ET1 = 1;
 PT0 = 1;                                                //优先级;
 #include <REGX52.H>
 #include "Timer01Init.h"
 #define red      P1_0
 //#define yellow   P1_1
 //#define blue     P1_3
 unsigned char A  , C  ,  LEDtime  , GateNumr , GateNumy , GateNumb , sure , Gatered , Gateyellow , Gateblue ;      //B;
 unsigned char Mode ;
 unsigned int counter ;
 void main()
 ///////////////////////red
 Timer01Init();
 while(1)
 if(P3_1 == 0)        //这里有问题        :我不加         && Gatered == 1这个函数可以执行,我加上之后我没想明白为啥会运行不了。        //5Hz,进门
 if(GateNumr < 3)        //门只能进入三次
 if(counter >= 100)
 counter = 0;
 red = !red;
 LEDtime++;
 if(LEDtime >= 6)                                                //P1_2亮一个周期LEDtime会加两次,所以LEDtime不为3;
 //                                        LCD12864_show_string(1,0,"red");
 LEDtime = 0;
 GateNumr++;
 TR1 = 0;
 A = 0;
 B = 0;
 C = 0;
 }else        //进门超出三次常亮5秒
 counter = 0;
 while(counter <= 5000)                                        //不是5秒?
 red = 0   ;
 red = 1;
 GateNumr = 0;
 counter = 0;
 TR1 = 0;
 if(C == 2)        //2Hz, 出门
 if(GateNumr <= 3)
 //                                LCD12864_show_string(0,1,"KeyPress(P3_1)");
 if(counter >= 250)
 counter = 0;
 red = !red;
 LEDtime++;
 LEDtime = 0;
 GateNumr--;
 TR1 = 0;
 A = 0;
 B = 0;
 C = 0;
 Gatered = 0;
