EC_N76E003_Open_Loop_BLDC_Motor_V1.00 (3).zip
(639.95 KB, 下载次数: 42)
- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.00
- * [url=home.php?mod=space&uid=247401]@brief[/url] Open Loop BLDC Motor
- * @note
- * Copyright (C) 2019 Nuvoton Technology Corp. All rights reserved.
- /* Pin Functions */
- //P07 - HALL Sensor W Phase, HALL_W
- //P06 - HALL Sensor V Phase, HALL_V
- //P05 - HALL Sensor U Phase, HALL_U
- //P12 - Upper-arm MOS control of U phase, uh
- //P14 - Lower-arm MOS control of U phase, ul
- //P10 - Upper-arm MOS control of V phase, vh
- //P00 - Lower-arm MOS control of V phase, vl
- //P01 - Upper-arm MOS control of W phase, wh
- //P03 - Lower-arm MOS control of W phase, wl
- //P15 - Motor on/off switch
- //P02 - UART RX
- //P16 - UART TX
- //P17 - ADC input
- /* Include File */
- #include "N76E003.h"
- #include "Common.h"
- #include "Delay.h"
- #include "SFR_Macro.h"
- #include "Function_define.h"
- /* Macro */
- #define UART1_DEBUG 0
- #define ABS(X) (X) >= 0 ? (X) : -(X)
- #define TIMER0_VALUE 65536-13333 //10ms
- #define MotorBoostDuty 0.15
- #define HallSensorPhase1 (0x05<<5)
- #define HallSensorPhase2 (0x01<<5)
- #define HallSensorPhase3 (0x03<<5)
- #define HallSensorPhase4 (0x02<<5)
- #define HallSensorPhase5 (0x06<<5)
- #define HallSensorPhase6 (0x04<<5)
- #define ADC_CONVERT_FINISH 1
- #define MOTOR_ON_OFF_SWITCH P15
- #define MOTOR_OFF 0
- /* Global variables */
- unsigned char data g_u8HallSensorMotorPhaseState = 0;
- unsigned char data g_u8TimerIntCount;
- unsigned char data g_u8TH0_Tmp, g_u8TL0_Tmp;
- unsigned short data g_u16CurrentSpeed = 0;
- /* Functions */
- void CheckMotorPhaseByHallSensor(unsigned char HallSensorInput)
- switch (HallSensorInput)
- case HallSensorPhase1:
- g_u8HallSensorMotorPhaseState = 1;
- break;
- case HallSensorPhase2:
- g_u8HallSensorMotorPhaseState = 2;
- break;
- case HallSensorPhase3:
- g_u8HallSensorMotorPhaseState = 3;
- break;
- case HallSensorPhase4:
- g_u8HallSensorMotorPhaseState = 4;
- break;
- case HallSensorPhase5:
- g_u8HallSensorMotorPhaseState = 5;
- break;
- case HallSensorPhase6:
- g_u8HallSensorMotorPhaseState = 6;
- break;
- void ChangeMotorPhaseClockwise(void)
- /* Change motor phase to next phase. */
- switch (g_u8HallSensorMotorPhaseState)
- case 1:
- PMEN = 0xfe; //uh
- PMD = 0x20; //wl
- break;
- case 2:
- PMEN = 0xfb; //vh
- PMD = 0x20; //wl
- break;
- case 3:
- PMEN = 0xfb; //vh
- PMD = 0x02; //ul
- break;
- case 4:
- PMEN = 0xef; //wh
- PMD = 0x02; //ul
- break;
- case 5:
- PMEN = 0xef; //wh
- PMD = 0x08; //vl
- break;
- case 6:
- PMEN = 0xfe; //uh
- PMD = 0x08; //vl
- break;
- void ChangeMotorPhaseCounterClockwise(void)
- case 6:
- PMEN = 0xfe; //uh
- PMD = 0x20; //wl
- break;
- case 5:
- PMEN = 0xfb; //vh
- PMD = 0x20; //wl
- break;
- case 4:
- PMEN = 0xfb; //vh
- PMD = 0x02; //ul
- break;
- case 3:
- PMEN = 0xef; //wh
- PMD = 0x02; //ul
- break;
- case 2:
- PMEN = 0xef; //wh
- PMD = 0x08; //vl
- break;
- case 1:
- PMEN = 0xfe; //uh
- PMD = 0x08; //vl
- break;
- void InitPWM(unsigned short *u16PWMDutyValue, unsigned char *u8OldMotorPhaseState)
- /* Initialize the pwm mode and clock. */
- PWM_GP_MODE_ENABLE;
- PWM_SYNCHRONIZED_MODE;
- PWM_CLOCK_FSYS;
- PWMPH = 0x01;
- PWMPL = 0xF3;
- PWM frequency = Fpwm/((PWMPH,PWMPL) + 1), Fpwm = Fsys/PWM_CLOCK_DIV
- = (16MHz)/(0x1F3 + 1)
- = 32KHz (0.03125 ms)
- /* Set PWM duty value on motor boost. */
- *u16PWMDutyValue = 0x1F3 * MotorBoostDuty;
- /* Initialize the pwm value */
- PWM0H = HIBYTE(*u16PWMDutyValue);
- PWM0L = LOBYTE(*u16PWMDutyValue);
- /* Initialize the Motor phase parameter */
- *u8OldMotorPhaseState = 0xFF;
- CheckMotorPhaseByHallSensor((P0 & 0xE0));
- /* Initialize the pwm pin mode and close whole MOS. */
- PMEN = 0xff;
- PMD = 0x00;
- void InitGPIO(void)
- Set_All_GPIO_Quasi_Mode;
- P05_Input_Mode;
- P06_Input_Mode;
- P07_Input_Mode;
- P15_Input_Mode;
- P04_PushPull_Mode;
- P12_PushPull_Mode;
- P14_PushPull_Mode;
- P10_PushPull_Mode;
- P00_PushPull_Mode;
- P01_PushPull_Mode;
- P03_PushPull_Mode;
- PWM0_P12_OUTPUT_ENABLE; /* P12 - Upper-arm MOS control of U phase, uh */
- PWM1_P14_OUTPUT_ENABLE; /* P14 - Lower-arm MOS control of U phase, ul */
- PWM2_P10_OUTPUT_ENABLE; /* P10 - Upper-arm MOS control of V phase, vh */
- PWM3_P00_OUTPUT_ENABLE; /* P00 - Lower-arm MOS control of V phase, vl */
- PWM4_P01_OUTPUT_ENABLE; /* P01 - Upper-arm MOS control of W phase, wh */
- PWM5_P03_OUTPUT_ENABLE; /* P03 - Lower-arm MOS control of W phase, wl */
- Enable_ADC_AIN0; /* ADC input */
- PICON = 0xFC; /* PORT 0 interrupt (Pin int control) */
- PINEN = 0XE0; /* Generates the pin interrupt when falling edge trigger */
- PIPEN = 0XE0; /* Generates the pin interrupt when rising edge trigger */
- set_EPI; /* Enable pin interrupt */
- set_EX0; /* Enable external interrupt */
- void InitTimer0(void)
- clr_T0M; /* T0M=0, Timer0 Clock = Fsys/12 */
- TMOD |= 0x01; /* Timer0 is 16-bit mode */
- /* Calculate the timer counter value for controlling the interrupt period on 10ms. */
- g_u8TH0_Tmp = HIBYTE(TIMER0_VALUE);
- g_u8TL0_Tmp = LOBYTE(TIMER0_VALUE);
- /* Sets the timer counter value for controlling the interrupt period. The period is setting on 10ms. */
- TH0 = g_u8TH0_Tmp;
- TL0 = g_u8TL0_Tmp;
- set_ET0; /* enable Timer0 interrupt */
- set_TR0; /* Timer0 start */
- unsigned int GetTargetSpeed(void)
- unsigned int data s16TargetSpeed;
- /* ADC will sample the variable resistor value on ADCRH. */
- /* Calculate the percentage of Max rotate speed 4500 rpm to target speed. */
- s16TargetSpeed = (((unsigned long int)4500 * (unsigned long int)ADCRH) / 255);
- /* Set the upper bound and lower bound on 450 and 4500 rpm. */
- if (s16TargetSpeed < 450) s16TargetSpeed = 450;
- if (s16TargetSpeed > 4500) s16TargetSpeed = 4500;
- /* Clear ADN interrupt flag and re-trigger ADC to convert. */
- clr_ADCF;
- set_ADCS;
- return s16TargetSpeed;
- void main(void)
- int data s16SpeedDiff = 0;
- unsigned int data s16TargetSpeed = 0;
- unsigned char data u8TimerCntForUART;
- unsigned char data u8OldMotorPhaseState;
- unsigned short data u16PWMDutyValue;
- int data temp;
- InitGPIO();
- #ifdef UART1_DEBUG
- /* Initialize UART1 for Debug */
- u8TimerCntForUART = 0;
- InitialUART1_Timer3(115200);
- #endif
- /* Initial PWM for controlling the 3 phase of motor */
- InitPWM(&u16PWMDutyValue, &u8OldMotorPhaseState);
- /* Initial Timer 0 for interrupt per 10 ms */
- InitTimer0();
- /* Reset timer and check the motor phase */
- /* Clear ADC Flag and Reset Timer interrupt cnt */
- clr_ADCF;
- g_u8TimerIntCount = 0;
- /* Enable all interrupts */
- set_EA;
- /* Start the ADC and PWM */
- set_ADCS;
- set_LOAD;
- set_PWMRUN;
- while (1)
- /* Get Motor realtime speed by ADC */
- if (ADCF == ADC_CONVERT_FINISH)
- s16TargetSpeed = GetTargetSpeed();
- if (MOTOR_ON_OFF_SWITCH == MOTOR_OFF)
- /* Stop the motor */
- clr_PWMRUN;
- PMEN = 0xff;
- PMD = 0x00;
- /* If the on/off switch is keeping in off state, stay on this while loop. */
- while (MOTOR_ON_OFF_SWITCH == MOTOR_OFF);
- /* Motor on/off switch is switching to on, re-initial the pwm for starting rotate. */
- u16PWMDutyValue = 0x1F3 * MotorBoostDuty;
- PWM0H = HIBYTE(u16PWMDutyValue);
- PWM0L = LOBYTE(u16PWMDutyValue);
- u8OldMotorPhaseState = 0xFF;
- /* Start the PWM */
- set_LOAD;
- set_PWMRUN;
- /* Clear the Timer interrupt cnt */
- else if (g_u8TimerIntCount >= 1) /* if the time past x * 10ms( x = 1 ), entering this if. */
- /* Reset the timer interrupt times counter */
- /* Print the speed of motor */
- u8TimerCntForUART++;
- if (u8TimerCntForUART >= 30) //Per 300ms send UART data
- Send_Data_To_UART1(s16TargetSpeed);
- #endif
- /* Modified the PWM duty for tracing the target speed */
- temp = ((((signed long int)0x1F3 * (signed long int)s16TargetSpeed)) / (signed long int)4500);
- u16PWMDutyValue += (( temp > u16PWMDutyValue) ? 1 : (-1));
- /* Set new PWM duty */
- set_LOAD;
- /* Change the Motor phase */
- if (u8OldMotorPhaseState != g_u8HallSensorMotorPhaseState)
- /* Record the last motor phase */
- u8OldMotorPhaseState = g_u8HallSensorMotorPhaseState;
- /* Change the motor phase */
- ChangeMotorPhaseClockwise();
- /* Interrupt */
- void PinInterrupt_ISR(void) interrupt 7
- /* Detecting the motor phase by hall sensor. */
- CheckMotorPhaseByHallSensor(P0 & 0xe0);
- /* Clear the Pin interrupt flag. */
- PIF = 0x00;
- void Timer0_ISR(void) interrupt 1
- /* Recorded the interrupt times. */
- g_u8TimerIntCount++;
- /*** (C) COPYRIGHT 2019 Nuvoton Technology Corp. ***/
