[工具下载] 新唐N7600E003输入捕获解码无线遥控源码
1071|2
 楼主| tifmill 发表于 2024-2-29 15:30 | 显示全部楼层 |阅读模式
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include <stdio.h>
#include <string.h>
// Leader code range                   13.5ms
#define     IR_LDC_MAX                 14500  //14.5ms
#define     IR_LDC_MIN          12500  //12.5ms
// Bit = 1 range                                        2.25ms
#define     IR_BIT_1_MAX               2500         //2.5ms
#define     IR_BIT_1_MIN        2000         //2ms
// Bit = 0 range                                        1.12ms
#define     IR_BIT_0_MAX              1250         //1.25ms
#define     IR_BIT_0_MIN              1000         //1ms
volatile    uint8_t             IR_State = 0;       // IR State
volatile    uint8_t             IR_LDC_Ready = 0;   // LeaDer Code is Ready
volatile    uint8_t             IR_CTC_Ready = 0;   // CusTomer Code is Ready
volatile    uint8_t             IR_CTC0 = 0;        // Received CusTomer Code 0
volatile    uint8_t             IR_CTC1 = 0;        // Received CusTomer Code 1
volatile    uint8_t             IR_DAC = 0;         // Received DAta Code
volatile    uint8_t             IR_DAB = 0;         // Received DAta Bar code
volatile    uint8_t             IR_cnt = 0;
uint8_t             IR_CODE[4]  =   {0x00, 0x00, 0x00, 0x00};
void IrDa_NEC_Rx(uint16_t Capture_Time)
    if(IR_State == 0)
        IR_LDC_Ready = 0;           // Clear LeaDer Code Ready
        IR_CTC_Ready = 0;           // Clear CusTomer Code Ready
        IR_State++;
    // Leader or Repeater code
    else if(IR_State == 1)
        // Leader code
        if((Capture_Time >= IR_LDC_MIN) && (Capture_Time <= IR_LDC_MAX))
            IR_LDC_Ready = 1;       // Set LeaDer Code Ready
            IR_State++;
        else
            IR_State = 1;
    // Customer code 0
    else if((IR_State >= 2 && IR_State < 10) && (IR_LDC_Ready == 1))
        IR_State++;
        IR_CTC0 = IR_CTC0 >> 1;
        if((Capture_Time >= IR_BIT_0_MIN) && (Capture_Time <= IR_BIT_0_MAX))          // 1.12ms = 0
            IR_CTC0 &= 0x7f;
        else if((Capture_Time >= IR_BIT_1_MIN) && (Capture_Time <= IR_BIT_1_MAX)) // 2.25ms = 1
            IR_CTC0 |= 0x80;
        else
            IR_State = 0;
    // Customer code 1
    else if((IR_State >= 10 && IR_State < 18) && (IR_LDC_Ready == 1))
        IR_State++;
        IR_CTC1 = IR_CTC1 >> 1;
            IR_CTC1 &= 0x7f;
            IR_CTC1 |= 0x80;
        else
            IR_State = 0;
    // Data
    else if((IR_State >= 18 && IR_State < 26) && (IR_LDC_Ready == 1))
        IR_State++;
        IR_DAC = IR_DAC >> 1;
            IR_DAC &= 0x7f;
            IR_DAC |= 0x80;
        else
            IR_State = 0;
    // Data bar
    else if((IR_State >= 26 && IR_State < 34) && (IR_LDC_Ready == 1))
        IR_State++;
        IR_DAB = IR_DAB >> 1;
            IR_DAB &= 0x7f;
            IR_DAB |= 0x80;
        else
            IR_State = 0;
        if(IR_State == 34)
            if((IR_DAC ^ IR_DAB) == 0xff)
                IR_CODE[0] = IR_CTC0;
                IR_CODE[1] = IR_CTC1;
                IR_CODE[2] = IR_DAC;
                IR_CODE[3] = IR_DAB;
                IR_cnt++;
                 printf("IR_cnt=%Bd,CTC0=%bX,CTC1=%bX,DAC=%bX,DAB=%bX\n", IR_cnt,IR_CTC0,IR_CTC1,IR_DAC,IR_DAB);
            IR_State = 0;
*    Timer2 Capture interrupt subroutine
void Capture_ISR (void) interrupt 12
                                uint16_t T2_count;
                                T2_count =(C0H<<8)+C0L;
                                IrDa_NEC_Rx(T2_count);
                                clr_CAPF0;                          // clear capture0 interrupt flag
                                clr_TF2;
*    Main function
void main(void)
        Set_All_GPIO_Quasi_Mode;
        InitialUART0_Timer3(115200);
        P15_Input_Mode;
        P15 = 1;
        T2MOD = 0XA9;                        // 定时器2时钟定义为16分频,捕获事件发生后计数值自动清0
        T2CON&=~SET_BIT0;  //定义定时器2功能为自动重装载模式
        IC7_P15_CAP0_FallingEdge_Capture;  //下降沿捕获
        TL2 = 0;
        TH2 = 0;
        set_EA;
        set_ECAP;                                   //Enable Capture interrupt
        set_TR2;                                    //Triger Timer2
        while(1);
gejigeji521 发表于 2024-2-29 15:55 | 显示全部楼层
学习一下,用于无线遥控。这是红外吗
ClarkLLOTP 发表于 2024-3-5 16:03 来自手机 | 显示全部楼层
红外遥控距离很短吧
