HC32F460JETA-LQFP48 配置IIC,PB12\PB13可以正常运行,换PA10\PA11就不行了,时钟和数据都监测不到,为啥吖?已确认PA10\PA11未被占用,且支持IIC输出,各位大佬,救救孩子
- //宏定义
- #define ADC_ADDRESS (0x48U) //01001000<<1 = 1001000
- #define I2C_ADC_SCL_PORT (GPIO_PORT_B)
- #define I2C_ADC_SCL_PIN (GPIO_PIN_12)
- #define I2C_ADC_SDA_PORT (GPIO_PORT_B)
- #define I2C_ADC_SDA_PIN (GPIO_PIN_13)
- #define I2C_ADC_GPIO_SCL_FUNC (GPIO_FUNC_49)
- #define I2C_ADC_GPIO_SDA_FUNC (GPIO_FUNC_48)
- #define I2C_ADC_UNIT (CM_I2C3)
- #define I2C_ADC_FCG_USE (FCG1_PERIPH_I2C3)
- //初始化部分
- int32_t ADC_POT_Initialize(void)
- LL_PERIPH_WE(LL_PERIPH_ALL);
- //ADC
- /* Initialize I2C port*/
- GPIO_SetFunc(I2C_ADC_SCL_PORT, I2C_ADC_SCL_PIN, I2C_ADC_GPIO_SCL_FUNC);
- GPIO_SetFunc(I2C_ADC_SDA_PORT, I2C_ADC_SDA_PIN, I2C_ADC_GPIO_SDA_FUNC);
- //GPIO_SetFunc(I2C_PTT_SCL_PORT, I2C_PTT_SCL_PIN, I2C_PTT_GPIO_SCL_FUNC);
- //GPIO_SetFunc(I2C_PTT_SDA_PORT, I2C_PTT_SDA_PIN, I2C_PTT_GPIO_SDA_FUNC);
- /* Enable I2C Peripheral*/
- FCG_Fcg1PeriphClockCmd(I2C_ADC_FCG_USE, ENABLE);
- // FCG_Fcg1PeriphClockCmd(I2C_PTT_FCG_USE, ENABLE);
- int32_t i32Ret;
- stc_i2c_init_t stcI2cInit;
- float32_t fErr;
- I2C_DeInit(I2C_ADC_UNIT);
- //I2C_DeInit(I2C_PTT_UNIT);
- (void)I2C_StructInit(&stcI2cInit);
- stcI2cInit.u32ClockDiv = I2C_CLK_DIV8;
- stcI2cInit.u32Baudrate = I2C_ADC_BAUDRATE;
- stcI2cInit.u32SclTime = 3UL;
- i32Ret = I2C_Init(I2C_ADC_UNIT, &stcI2cInit, &fErr);
- if(i32Ret != LL_OK){
- while(1);
- /*stcI2cInit.u32Baudrate = I2C_PTT_BAUDRATE;
- i32Ret = I2C_Init(I2C_PTT_UNIT, &stcI2cInit, &fErr);
- while(1);
- I2C_BusWaitCmd(I2C_ADC_UNIT, ENABLE);
- //I2C_BusWaitCmd(I2C_PTT_UNIT, ENABLE);
- /* Peripheral registers write protected */
- LL_PERIPH_WP(LL_PERIPH_ALL);
- uint8_t data[3];
- i32Ret = I2C_Master_Receive(I2C_ADC_UNIT, ADC_ADDRESS | 0x01, data, 3);
- if(i32Ret == LL_OK){
- memcpy(&adc_config ,&data[2], 1);
- return i32Ret;
- //不能正常运行的宏,我就改了针脚配置
- #define I2C_ADC_SCL_PORT (GPIO_PORT_A)
- #define I2C_ADC_SCL_PIN (GPIO_PIN_10)
- #define I2C_ADC_SDA_PORT (GPIO_PORT_A)
- #define I2C_ADC_SDA_PIN (GPIO_PIN_11)
- #define I2C_ADC_UNIT (CM_I2C1)
- #define I2C_ADC_FCG_USE (FCG1_PERIPH_I2C1)
