[文档下载] [经验] 如何使用M051驱动LCD显示中文字符
1351|0
 楼主| flycamelaaa 发表于 2024-3-23 17:53 | 显示全部楼层 |阅读模式
  • 应用程序: 此代码使用 M051 驱动 LCD 显示中文字符 。
  • BSP 版本: M051系列 BSP CMSIS v3.01.001
  • 硬件: Nu-LB_004 v1.0
The sample code is to add LCD Chinese characters display function based on the nuvoton 核 NU-LB_004 learning board. This code is intended to provide a reference design for customers who want to display Chinese characters on the LCD. At present, only the characters of “新唐电子” can be displayed. If you want to display more than one character, the customers need to generate a 16×16 font library. The generation of 16×16 font is from left to right and then from up to down.
如果有几个字符, 您可以把它放在芯片闪光上。 如果您有更多的字符, 推荐将其放到外部的 SPI 闪光上 。
您可以在下列时间下载样本代码http://www.nuvoton.com/resources-downlo. 1220114739
nuvoton 核
