[STM32F1] stm32f103rb驱动max7219点阵无反应,代码如下
1168|7
 楼主| 慢醇 发表于 2024-4-11 06:51 | 显示全部楼层 |阅读模式
  1. **spi.c**
  2. #include "bsp_spi_dot_matrix_led.h"
  3. #include "bsp_usart.h"
  4. /**
  5.   * [url=home.php?mod=space&uid=247401]@brief[/url]  SPI_FLASH初始化
  6.   * @param  无
  7.   * @retval 无
  8.   */
  9. void SPI_DOT_LED_Init(void)
  10. {
  11.
  12.   GPIO_InitTypeDef GPIO_InitStructure;
  13.     RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB, ENABLE);
  14.
  15.   /* 配置SPI的 CS引脚,普通IO即可 */
  16.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  17.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  18.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  19.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  20.
  21.      /* 配置SPI的 CLK引脚,普通IO即可 */
  22.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  23.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  24.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  25.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  26.
  27.
  28.      /* 配置SPI的 DIN引脚,普通IO即可 */
  29.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
  30.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  31.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  32.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  33. }
  34. ////-------------------------------------------
  35. ////功能:向MAX7219写入数据
  36. ////入口参数:address、dat
  37. ////出口参数:无
  38. ////说明:
  39. //--------------------------------------------
  40. //功能:向MAX7219(U3)写入字节
  41. //入口参数:DATA
  42. //出口参数:无
  43. //说明:
  44. void Write_Max7219_byte(uchar DATA)
  45. {
  46.             uchar i,w;
  47.         Max7219_pinCS_LOW();
  48.         for(i=8;i>=1;i--)
  49.         {
  50.             Max7219_pinCLK_LOW();
  51.                         w=DATA&0x80;
  52.                         w=DATA>>7;
  53.                       Max7219_pinDIN(w);
  54.                         printf(" %d \n",w);
  55.                 DATA=DATA<<1;//八位的data从高到底把数据以此发送给Max7219_pinDIN
  56.             Max7219_pinCLK_HIGH();
  57.            }
  58. }
  59. void Write_Max7219(uchar address,uchar dat)
  60. {
  61.      Max7219_pinCS_LOW();
  62.        Write_Max7219_byte(address);           //写入地址,即数码管编号
  63.      Write_Max7219_byte(dat);               //写入数据,即数码管显示数字
  64.        Max7219_pinCS_HIGH();
  65. }
  66. void Init_MAX7219(void)
  67. {
  68. Write_Max7219(0x09, 0x00);       //译码方式:BCD码
  69. Write_Max7219(0x0a, 0x03);       //亮度
  70. Write_Max7219(0x0b, 0x07);       //扫描界限;8个数码管显示
  71. Write_Max7219(0x0c, 0x01);       //掉电模式:0,普通模式:1
  72. Write_Max7219(0x0f, 0x00);       //显示测试:1;测试结束,正常显示:0
  73. }
  74. /*********************************************END OF FILE**********************/
  75. main.c
  76. #include "stm32f10x.h"
  77. #include "bsp_spi_dot_matrix_led.h"
  78. #include "bsp_SysTick.h"
  79. /* disp1为需要显示字库*/ //其他字可以去网上下载  取模软件
  80. uchar disp1[38][8]={
  81. {0xB4,0x4A,0x8A,0xBE,0x4A,0x4A,0x41,0xFF},/*"迅",0*/
  82. {0x40,0x88,0x7E,0x48,0x4C,0x52,0x7F,0x0},/*"达",0*/
  83. {0x0,0x41,0x22,0x14,0x8,0x14,0x22,0x41},//X
  84. {0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1C},//U
  85. {0x0,0x42,0x62,0x52,0x4A,0x46,0x42,0x0},//N
  86. {0x7C,0x42,0x42,0x42,0x42,0x42,0x7C,0x0},//D
  87. {0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22},//A
  88. {0x10,0x5B,0x24,0x24,0x28,0x18,0x18,0x24},/*"文",0*/
  89. {0x00,0x7E,0x10,0x2C,0x24,0x3C,0x24,0x3C},/*"百",0*/
  90. //{0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
  91. //{0x10,0x18,0x14,0x10,0x10,0x10,0x10,0x10},//1
  92. //{0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
  93. //{0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
  94. //{0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},//4
  95. //{0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0},//5
  96. //{0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0},//6
  97. //{0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8},//7
  98. //{0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
  99. {0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E},//9
  100. {0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22},//A
  101. {0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C,0x0},//B
  102. {0x3C,0x40,0x40,0x40,0x40,0x40,0x3C,0x0},//C
  103. {0x7C,0x42,0x42,0x42,0x42,0x42,0x7C,0x0},//D
  104. {0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x7C},//E
  105. {0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x40},//F
  106. {0x3C,0x40,0x40,0x40,0x40,0x44,0x44,0x3C},//G
  107. {0x44,0x44,0x44,0x7C,0x44,0x44,0x44,0x44},//H
  108. {0x7C,0x10,0x10,0x10,0x10,0x10,0x10,0x7C},//I
  109. {0x3C,0x8,0x8,0x8,0x8,0x8,0x48,0x30},//J
  110. {0x0,0x24,0x28,0x30,0x20,0x30,0x28,0x24},//K
  111. {0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7C},//L
  112. {0x81,0xC3,0xA5,0x99,0x81,0x81,0x81,0x81},//M
  113. {0x0,0x42,0x62,0x52,0x4A,0x46,0x42,0x0},//N
  114. {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//O
  115. {0x3C,0x22,0x22,0x22,0x3C,0x20,0x20,0x20},//P
  116. {0x1C,0x22,0x22,0x22,0x22,0x26,0x22,0x1D},//Q
  117. {0x3C,0x22,0x22,0x22,0x3C,0x24,0x22,0x21},//R
  118. {0x0,0x1E,0x20,0x20,0x3E,0x2,0x2,0x3C},//S
  119. {0x0,0x3E,0x8,0x8,0x8,0x8,0x8,0x8},//T
  120. {0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1C},//U
  121. {0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18},//V
  122. {0x0,0x49,0x49,0x49,0x49,0x2A,0x1C,0x0},//W
  123. {0x0,0x41,0x22,0x14,0x8,0x14,0x22,0x41},//X
  124. {0x41,0x22,0x14,0x8,0x8,0x8,0x8,0x8},//Y
  125. {0x0,0x7F,0x2,0x4,0x8,0x10,0x20,0x7F},//Z
  126. {0x8,0x7F,0x49,0x49,0x7F,0x8,0x8,0x8},//中
  127. {0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//国
  128. };
  129. int main(void)
  130. {
  131.
  132.     SysTick_Init();//始终初始化
  133.     SPI_DOT_LED_Init();//初始化传输用的GPIO
  134.     Init_MAX7219();//初始化MAX7219
  135.     while(1)
  136. {
  137.      uchar i,j;
  138.    for(j=0;j<38;j++)
  139.   {
  140.    for(i=1;i<9;i++)
  141.     Write_Max7219(i,disp1[j][i-1]);
  142.     SysTick_Delay_Ms( 1000);
  143.   }
  144. }
  145. }
  146. /*********************************************END OF FILE**********************/
laocuo1142 发表于 2024-4-11 09:11 | 显示全部楼层
STM32F103RB与MAX7219之间的连接是否有误,包括SPI接口、电源和地线。
flycamelaaa 发表于 2024-4-11 10:00 | 显示全部楼层
STM32F103RB的SPI接口是否已经正确初始化
powerantone 发表于 2024-4-11 10:45 | 显示全部楼层
检查MAX7219的初始化序列是否正确,包括设置亮度、扫描方式等。
stormwind123 发表于 2024-4-11 11:30 | 显示全部楼层
驱动代码问题
probedog 发表于 2024-4-11 12:59 | 显示全部楼层
可能是电源问题
两只袜子 发表于 2024-4-11 14:00 | 显示全部楼层
寄存器的值是否正确设置
jcky001 发表于 2024-4-11 15:00 | 显示全部楼层
尝试更换一个MAX7219芯片
