- // 冒泡排序
- void bubbleSort(int arr[], int n) {
- int i, j, temp;
- for (i = 0; i < n - 1; i++)
- for (j = 0; j < n - i - 1; j++)
- if (arr[j] > arr[j + 1]) {
- temp = arr[j];
- arr[j] = arr[j + 1];
- arr[j + 1] = temp;
- // 选择排序
- void selectionSort(int arr[], int n) {
- int i, j, min_idx;
- for (i = 0; i < n - 1; i++) {
- min_idx = i;
- for (j = i + 1; j < n; j++)
- if (arr[j] < arr[min_idx])
- min_idx = j;
- swap(&arr[min_idx], &arr[i]);
- // 插入排序
- void insertionSort(int arr[], int n) {
- int i, j, key;
- for (i = 1; i < n; i++) {
- key = arr[i];
- j = i - 1;
- while (j >= 0 && arr[j] > key) {
- arr[j + 1] = arr[j];
- j = j - 1;
- arr[j + 1] = key;
- // 快速排序
- int partition (int arr[], int low, int high) {
- int pivot = arr[high];
- int i = (low - 1);
- for (j = low; j <= high - 1; j++) {
- if (arr[j] < pivot) {
- i++;
- swap(&arr[i], &arr[j]);
- swap(&arr[i + 1], &arr[high]);
- return (i + 1);
- void quickSort(int arr[], int low, int high) {
- if (low < high) {
- int pi = partition(arr, low, high);
- quickSort(arr, low, pi - 1);
- quickSort(arr, pi + 1, high);
- // 归并排序
- void merge(int arr[], int l, int m, int r) {
- int i, j, k;
- int n1 = m - l + 1;
- int n2 = r - m;
- int L[n1], R[n2];
- for (i = 0; i < n1; i++)
- L[i] = arr[l + i];
- for (j = 0; j < n2; j++)
- R[j] = arr[m + 1 + j];
- i = 0;
- j = 0;
- k = l;
- while (i < n1 && j < n2) {
- if (L[i] <= R[j]) {
- arr[k] = L[i];
- i++;
- else {
- arr[k] = R[j];
- j++;
- k++;
- while (i < n1) {
- arr[k] = L[i];
- i++;
- k++;
- while (j < n2) {
- arr[k] = R[j];
- j++;
- k++;
- void mergeSort(int arr[], int l, int r) {
- if (l < r) {
- int m = l + (r - l) / 2;
- mergeSort(arr, l, m);
