| 期望实现4个CANFD通道的fifo分配与测试;发现并不顺利! 请指出代码问题
 * @file     main.c
 * @version  V1.00
 * @brief    An example of M460 CAN FD Transmition .
 * SPDX-License-Identifier: Apache-2.0
 * @CopyRight (C) 2021 Nuvoton Technology Corp. All rights reserved.
 #include "stdio.h"
 #include "string.h"
 #include "NuMicro.h"
 #include "gv.h"
 CANFD_BUF_T __attribute__((section(".ARM.__at_0x40020200"))) CANFD0_Txfifo[2];
 CANFD_BUF_T __attribute__((section(".ARM.__at_0x40024200"))) CANFD1_Txfifo[2];
 CANFD_BUF_T __attribute__((section(".ARM.__at_0x40028200"))) CANFD2_Txfifo[2];
 CANFD_BUF_T __attribute__((section(".ARM.__at_0x4002C200"))) CANFD3_Txfifo[2];
 uint8_t u8Item = 0;
 uint32_t u32TimeOutCnt0 = 0;
 uint32_t u32TimeOutCnt1 = 0;
 uint32_t u32TimeOutCnt2 = 0;
 uint32_t u32TimeOutCnt3 = 0;
 void TIM1_Init(void)
 TIMER_Open(TIMER1, TIMER_PERIODIC_MODE, 100000);//1khz中断一次
 TIMER_EnableInt(TIMER1);
 NVIC_EnableIRQ(TMR1_IRQn);
 TIMER_Start(TIMER1);
 void TMR1_IRQHandler(void)
 if (++u8Item > 1) u8Item = 0;
 TIMER_ClearIntFlag(TIMER1);
 void SYS_Init(void)
 /* Set PF multi-function pins for XT1_OUT(PF.2) and XT1_IN(PF.3) */
 SET_XT1_OUT_PF2();
 SET_XT1_IN_PF3();
 /* Init System Clock        */
 /* Enable HIRC and HXT clock */
 CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk | CLK_PWRCTL_HXTEN_Msk);
 /* Wait for HIRC and HXT clock ready */
 CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk | CLK_STATUS_HXTSTB_Msk);
 /* Set PCLK0 and PCLK1 to HCLK/2 */
 CLK->PCLKDIV = (CLK_PCLKDIV_APB0DIV_DIV1 | CLK_PCLKDIV_APB1DIV_DIV1);
 /* Set core clock to 200MHz */
 CLK_SetCoreClock(200000000);
 /* Enable all GPIO clock */
 CLK->AHBCLK0 |= CLK_AHBCLK0_GPACKEN_Msk | CLK_AHBCLK0_GPBCKEN_Msk | CLK_AHBCLK0_GPCCKEN_Msk | CLK_AHBCLK0_GPDCKEN_Msk |
 CLK_AHBCLK0_GPECKEN_Msk | CLK_AHBCLK0_GPFCKEN_Msk | CLK_AHBCLK0_GPGCKEN_Msk | CLK_AHBCLK0_GPHCKEN_Msk;
 CLK->AHBCLK1 |= CLK_AHBCLK1_GPICKEN_Msk | CLK_AHBCLK1_GPJCKEN_Msk;
 CLK_EnableSysTick(CLK_CLKSEL0_STCLKSEL_HCLK_DIV2, 0);
 CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
 CLK_EnableModuleClock(UART0_MODULE);
 /* Set IP clock */
 CLK_SetModuleClock(CANFD0_MODULE, CLK_CLKSEL0_CANFD0SEL_HCLK, CLK_CLKDIV5_CANFD0(1));
 CLK_SetModuleClock(CANFD1_MODULE, CLK_CLKSEL0_CANFD1SEL_HCLK, CLK_CLKDIV5_CANFD1(1));
 CLK_SetModuleClock(CANFD2_MODULE, CLK_CLKSEL0_CANFD2SEL_HCLK, CLK_CLKDIV5_CANFD2(1));
 CLK_SetModuleClock(CANFD3_MODULE, CLK_CLKSEL0_CANFD3SEL_HCLK, CLK_CLKDIV5_CANFD3(1));
 /* Enable IP clock */
 CLK_EnableModuleClock(CANFD0_MODULE);
 CLK_EnableModuleClock(CANFD1_MODULE);
 CLK_EnableModuleClock(CANFD2_MODULE);
 CLK_EnableModuleClock(CANFD3_MODULE);
 CLK_SetModuleClock(TMR1_MODULE, CLK_CLKSEL1_TMR1SEL_PCLK0, MODULE_NoMsk);
 CLK_EnableModuleClock(TMR1_MODULE);
 /* Init I/O Multi-function        */
 SET_UART0_RXD_PB12();       // Set multi-function pins for UART0 RXD and TXD
 SET_UART0_TXD_PB13();
 //CAN
 SET_CAN0_TXD_PD11();
 SET_CAN0_RXD_PD10();
 SET_CAN1_TXD_PC13();
 SET_CAN1_RXD_PD12();
 SET_CAN2_TXD_PB9();
 SET_CAN2_RXD_PB8();
 SET_CAN3_TXD_PF11();
 SET_CAN3_RXD_PF10();
 void CANFD0_TX_fifo_Init(void)
 CANFD0_Txfifo[0].u32Id       = 0x001 << 18 ;                    // SID = 0x111
 CANFD0_Txfifo[0].u32Config   = 0x00300000 + 0x000F0000 ;        // DLC=8 mean 8 Bytes
 CANFD0_Txfifo[1].u32Id       = 0x002 << 18 ;                    // SID = 0x113
 CANFD0_Txfifo[1].u32Config   = 0x00300000 + 0x000F0000 ;        // DLC=9 =12 Bytes
 CANFD0_Txfifo[0].au32Data[0] = 0x11111111;
 CANFD0_Txfifo[1].au32Data[0] = 0x22222222;
 void CANFD1_TX_fifo_Init(void)
 CANFD1_Txfifo[0].u32Id       = 0x011 << 18 ;                    // SID = 0x111
 CANFD1_Txfifo[0].u32Config   = 0x00300000 + 0x000F0000 ;        // DLC=8 mean 8 Bytes
 CANFD1_Txfifo[1].u32Id       = 0x012 << 18 ;                    // SID = 0x113
 CANFD1_Txfifo[1].u32Config   = 0x00300000 + 0x000F0000 ;        // DLC=9 =12 Bytes
 CANFD1_Txfifo[0].au32Data[0] = 0x11111111;
 CANFD1_Txfifo[1].au32Data[0] = 0x22222222;
 void CANFD2_TX_fifo_Init(void)
 CANFD2_Txfifo[0].u32Id       = 0x021 << 18 ;                    // SID = 0x111
 CANFD2_Txfifo[0].u32Config   = 0x00300000 + 0x000F0000 ;        // DLC=8 mean 8 Bytes
 CANFD2_Txfifo[1].u32Id       = 0x022 << 18 ;                    // SID = 0x113
 CANFD2_Txfifo[1].u32Config   = 0x00300000 + 0x000F0000 ;        // DLC=9 =12 Bytes
 CANFD2_Txfifo[0].au32Data[0] = 0x11111111;
 CANFD2_Txfifo[1].au32Data[0] = 0x22222222;
 void CANFD3_TX_fifo_Init(void)
 CANFD3_Txfifo[0].u32Id       = 0x031 << 18 ;                    // SID = 0x111
 CANFD3_Txfifo[0].u32Config   = 0x00300000 + 0x000F0000 ;        // DLC=8 mean 8 Bytes
 CANFD3_Txfifo[1].u32Id       = 0x032 << 18 ;                    // SID = 0x113
 CANFD3_Txfifo[1].u32Config   = 0x00300000 + 0x000F0000 ;        // DLC=9 =12 Bytes
 CANFD3_Txfifo[0].au32Data[0] = 0x11111111;
 CANFD3_Txfifo[1].au32Data[0] = 0x22222222;
 void CANFD0_Tx_Init(CANFD_T *psCanfd, int16_t TxBuff_Quantity, int16_t DLC_Max, uint16_t TxBuff_StartAddr)
 psCanfd->TXBC = (TxBuff_Quantity << CANFD_TXBC_NDTB_Pos)
 + TxBuff_StartAddr ;
 psCanfd->TXESC = DLC_Max <<  CANFD_TXESC_TBDS_Pos;
 void CANFD1_Tx_Init(CANFD_T *psCanfd, int16_t TxBuff_Quantity, int16_t DLC_Max, uint16_t TxBuff_StartAddr)
 void CANFD2_Tx_Init(CANFD_T *psCanfd, int16_t TxBuff_Quantity, int16_t DLC_Max, uint16_t TxBuff_StartAddr)
 void CANFD3_Tx_Init(CANFD_T *psCanfd, int16_t TxBuff_Quantity, int16_t DLC_Max, uint16_t TxBuff_StartAddr)
 void CANFD0_TxTest(CANFD_T *psCanfd, uint8_t cnt)
 switch (cnt)
 case 0:
 while (CANFD_GET_COMMUNICATION_STATE(psCanfd) != eCANFD_IDLE)
 if (--u32TimeOutCnt0 == 0) break;
 psCanfd->TXBAR = 1 << 0 ;
 break;
 case 1:
 psCanfd->TXBAR = 1 << 1 ;
 break;
 default:
 break ;
 void CANFD1_TxTest(CANFD_T *psCanfd, uint8_t cnt)
 switch (cnt)
 case 0:
 if (--u32TimeOutCnt1 == 0) break;
 break;
 case 1:
 break;
 default:
 break ;
 void CANFD2_TxTest(CANFD_T *psCanfd, uint8_t cnt)
 switch (cnt)
 case 0:
 if (--u32TimeOutCnt2 == 0) break;
 break;
 case 1:
 break;
 default:
 break ;
 void CANFD3_TxTest(CANFD_T *psCanfd, uint8_t cnt)
 switch (cnt)
 case 0:
 if (--u32TimeOutCnt3 == 0) break;
 break;
 case 1:
 break;
 default:
 break ;
 void CANFD0_Init(void)
 CANFD_FD_T sCANFD_Config0;
 SYS_ResetModule(CANFD0_RST);
 CANFD_GetDefaultConfig(&sCANFD_Config0, CANFD_OP_CAN_FD_MODE);
 sCANFD_Config0.sBtConfig.sNormBitRate.u32BitRate = 500000;
 sCANFD_Config0.sBtConfig.sDataBitRate.u32BitRate = 2000000;
 CANFD_Open(CANFD0, &sCANFD_Config0);
 void CANFD1_Init(void)
 CANFD_FD_T sCANFD_Config1;
 SYS_ResetModule(CANFD1_RST);
 CANFD_GetDefaultConfig(&sCANFD_Config1, CANFD_OP_CAN_FD_MODE);
 sCANFD_Config1.sBtConfig.sNormBitRate.u32BitRate = 500000;
 sCANFD_Config1.sBtConfig.sDataBitRate.u32BitRate = 2000000;
 CANFD_Open(CANFD1, &sCANFD_Config1);
 void CANFD2_Init(void)
 CANFD_FD_T sCANFD_Config2;
 SYS_ResetModule(CANFD2_RST);
 CANFD_GetDefaultConfig(&sCANFD_Config2, CANFD_OP_CAN_FD_MODE);
 sCANFD_Config2.sBtConfig.sNormBitRate.u32BitRate = 500000;
 sCANFD_Config2.sBtConfig.sDataBitRate.u32BitRate = 2000000;
 CANFD_Open(CANFD2, &sCANFD_Config2);
 void CANFD3_Init(void)
 CANFD_FD_T sCANFD_Config3;
 SYS_ResetModule(CANFD3_RST);
 CANFD_GetDefaultConfig(&sCANFD_Config3, CANFD_OP_CAN_FD_MODE);
 sCANFD_Config3.sBtConfig.sNormBitRate.u32BitRate = 500000;
 sCANFD_Config3.sBtConfig.sDataBitRate.u32BitRate = 2000000;
 CANFD_Open(CANFD3, &sCANFD_Config3);
 int32_t main(void)
 SYS_UnlockReg();                         // Unlock protected registers
 SYS_Init();                              // Init System, peripheral clock and multi-function I/O
 UART_Open(UART0, 115200);                           // Init UART to 115200-8n1 for print message
 CANFD0->CCCR = CANFD_CCCR_CCE_Msk | CANFD_CCCR_INIT_Msk | CANFD_CCCR_BRSE_Msk | CANFD_CCCR_FDOE_Msk;
 CANFD1->CCCR = CANFD_CCCR_CCE_Msk | CANFD_CCCR_INIT_Msk | CANFD_CCCR_BRSE_Msk | CANFD_CCCR_FDOE_Msk;
 CANFD2->CCCR = CANFD_CCCR_CCE_Msk | CANFD_CCCR_INIT_Msk | CANFD_CCCR_BRSE_Msk | CANFD_CCCR_FDOE_Msk;
 CANFD3->CCCR = CANFD_CCCR_CCE_Msk | CANFD_CCCR_INIT_Msk | CANFD_CCCR_BRSE_Msk | CANFD_CCCR_FDOE_Msk;
 CANFD0_Init();
 CANFD1_Init();
 CANFD2_Init();
 CANFD3_Init();
 CANFD0_TX_fifo_Init();
 CANFD1_TX_fifo_Init();
 CANFD2_TX_fifo_Init();
 CANFD3_TX_fifo_Init();
 CANFD0_Tx_Init(CANFD0, 2, 7, 0);
 CANFD0->CCCR = CANFD_CCCR_BRSE_Msk | CANFD_CCCR_FDOE_Msk ;    // Write is OK after 2 CLKs
 CANFD1_Tx_Init(CANFD1, 2, 7, 0);
 CANFD1->CCCR = CANFD_CCCR_BRSE_Msk | CANFD_CCCR_FDOE_Msk ;    // Write is OK after 2 CLKs
 CANFD2_Tx_Init(CANFD2, 2, 7, 0);
 CANFD2->CCCR = CANFD_CCCR_BRSE_Msk | CANFD_CCCR_FDOE_Msk ;    // Write is OK after 2 CLKs
 CANFD3_Tx_Init(CANFD3, 2, 7, 0);
 CANFD3->CCCR = CANFD_CCCR_BRSE_Msk | CANFD_CCCR_FDOE_Msk ;    // Write is OK after 2 CLKs
 SYS_LockReg();
 TIM1_Init();
 u32TimeOutCnt0 = CANFD_TIMEOUT;
 u32TimeOutCnt1 = CANFD_TIMEOUT;
 u32TimeOutCnt2 = CANFD_TIMEOUT;
 u32TimeOutCnt3 = CANFD_TIMEOUT;
 while (1)
 CANFD0_TxTest(CANFD0, u8Item);
 CANFD1_TxTest(CANFD1,u8Item);
 CANFD2_TxTest(CANFD2,u8Item);
 CANFD3_TxTest(CANFD3,u8Item);
