[AT32F415] AT32F415使用DMA ADC某几个通道什么也不接,其他通道ADC不正常
3179|3
 楼主| 视觉℡ 发表于 2024-9-26 22:40 | 显示全部楼层 |阅读模式
dc, DMA, DM, ADC, AD
  1. //初始化ADC
  2. void Adc_Init(void)
  3. {
  4.   adc_base_config_type adc_base_struct;
  5.   gpio_init_type gpio_initstructure;
  6.   dma_init_type dma_init_struct;
  7.         crm_periph_clock_enable(CRM_GPIOA_PERIPH_CLOCK, TRUE);
  8.   crm_periph_clock_enable(CRM_GPIOB_PERIPH_CLOCK, TRUE);
  9.   gpio_default_para_init(&gpio_initstructure);
  10.         //                                ADC_V       ADC_NTC
  11.         gpio_initstructure.gpio_pins =  GPIO_PINS_0 | GPIO_PINS_2 | GPIO_PINS_4 ;
  12.   gpio_initstructure.gpio_mode = GPIO_MODE_ANALOG;
  13.   gpio_init(GPIOA, &gpio_initstructure);
  14.         gpio_default_para_init(&gpio_initstructure);
  15.         //                                ADC_VBC       ADC_A
  16.         gpio_initstructure.gpio_pins =  GPIO_PINS_0 | GPIO_PINS_1 ;
  17.   gpio_initstructure.gpio_mode = GPIO_MODE_ANALOG;
  18.
  19.   gpio_init(GPIOB, &gpio_initstructure);
  20.
  21.
  22.   crm_periph_clock_enable(CRM_DMA1_PERIPH_CLOCK, TRUE);
  23.   nvic_irq_enable(DMA1_Channel1_IRQn, 1, 3);
  24.
  25.   dma_reset(DMA1_CHANNEL1);
  26.         dma_flexible_config(DMA1, FLEX_CHANNEL1, DMA_FLEXIBLE_ADC1);
  27.
  28.   dma_default_para_init(&dma_init_struct);
  29.   dma_init_struct.buffer_size = Collection_num * ADC_CH_NUM;
  30.   dma_init_struct.direction = DMA_DIR_PERIPHERAL_TO_MEMORY;
  31.   dma_init_struct.memory_base_addr = (uint32_t)adc1_ordinary_valuetab;
  32.   dma_init_struct.memory_data_width = DMA_MEMORY_DATA_WIDTH_HALFWORD;
  33.   dma_init_struct.memory_inc_enable = TRUE;
  34.   dma_init_struct.peripheral_base_addr = (uint32_t) & (ADC1->odt);
  35.   dma_init_struct.peripheral_data_width = DMA_PERIPHERAL_DATA_WIDTH_HALFWORD;
  36.   dma_init_struct.peripheral_inc_enable = FALSE;
  37.   dma_init_struct.priority = DMA_PRIORITY_HIGH;
  38.   dma_init_struct.loop_mode_enable = TRUE;
  39.   dma_init(DMA1_CHANNEL1, &dma_init_struct);
  40.   dma_interrupt_enable(DMA1_CHANNEL1, DMA_FDT_INT, TRUE);
  41.   dma_channel_enable(DMA1_CHANNEL1, TRUE);
  42.   crm_periph_clock_enable(CRM_ADC1_PERIPH_CLOCK, TRUE);
  43.         crm_adc_clock_div_set(CRM_ADC_DIV_6);
  44.         //nvic_irq_enable(ADC1_IRQn, 0, 0);
  45.
  46.         /* 启用内部参考电压 */
  47.         adc_tempersensor_vintrv_enable(TRUE);
  48.
  49.   adc_base_default_para_init(&adc_base_struct);
  50.   adc_base_struct.sequence_mode = TRUE; // adc序列模式
  51.   adc_base_struct.repeat_mode = TRUE;   //反复模式
  52.   adc_base_struct.data_align = ADC_RIGHT_ALIGNMENT;
  53.   adc_base_struct.ordinary_channel_length = ADC_CH_NUM;
  54.   adc_base_config(ADC1, &adc_base_struct);
  55.   adc_ordinary_channel_set(ADC1, ADC_CHANNEL_17,1, ADC_SAMPLETIME_7_5);
  56.   adc_ordinary_channel_set(ADC1, ADC_CHANNEL_9  , 2, ADC_SAMPLETIME_7_5);
  57.   adc_ordinary_channel_set(ADC1, ADC_CHANNEL_8 , 3, ADC_SAMPLETIME_7_5);
  58.   adc_ordinary_channel_set(ADC1, ADC_CHANNEL_2, 4, ADC_SAMPLETIME_7_5);
  59.   adc_ordinary_channel_set(ADC1,ADC_CHANNEL_4 , 5, ADC_SAMPLETIME_7_5);
  60.   /* 配置普通触发源和触发沿 */
  61.   adc_ordinary_conversion_trigger_set(ADC1, ADC12_ORDINARY_TRIG_SOFTWARE, TRUE);
  62.   /* 配置dma模式,使用普通dma模式时无用 */
  63.   adc_dma_mode_enable(ADC1, TRUE);
  64.
  65.   adc_enable(ADC1, TRUE);
  66.   adc_calibration_init(ADC1); //初始化指定adc外围设备的校准寄存器。
  67.   while (adc_calibration_init_status_get(ADC1))
  68.     ;
  69.   adc_calibration_start(ADC1);
  70.   while (adc_calibration_status_get(ADC1))
  71.     ;
  72.   adc_ordinary_software_trigger_enable(ADC1, TRUE);
  73. }
其中ADC_V是0V   如果ADC_NTC电压降至0.6V  ADC_VB的电压就会严重下降,只要ADC_NTC电压升高一点到1V,ADC_VB的电压就正常
goodjob 发表于 2024-10-1 12:44 | 显示全部楼层
雅特力的几款MCU,与ADC有关的引脚接外部时如果有可能出现接地的情况,需要加2K左右的限流电阻,即使这个脚不使用ADC功能也得这么做,不然ADC就会出问题。我也不知道为啥
zhjb1 发表于 2024-11-19 15:16 | 显示全部楼层
您好,您的程序设置了5个ADC1通道,如何分别获取他们,有代码吗?谢谢
LEDyyds 发表于 2024-11-20 20:16 | 显示全部楼层
通道间好像是有串扰的
