[STM32H5] STM32H562RG 外部RTC晶体起振问题
855|2
 楼主| liszt99 发表于 2024-9-29 11:23 | 显示全部楼层 |阅读模式
小弟最近在使用STM32H562RG ,知道它可以调整外部RTC的驱动能力。程序中我加了个LED灯看代码有没有顺利运行,当我使用外部晶体,并且调整为第三等级的时候。外部晶体不起振,LED灯不闪烁。使用内部LSI的时候,LED灯闪烁,程序正常运行。并且我注意到有这样一句注释。
Configure LSE Drive Capability
*  Warning : Only applied when the LSE is disabled.
翻译过来就是
配置LSE驱动器功能
*警告:仅在禁用LSE时适用。这句话我不是很理解。都禁用LSE了,还能配置LSE驱动功能?要怎么禁用?
部分代码如下。
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE0);
  while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
  /** Configure LSE Drive Capability
  HAL_PWR_EnableBkUpAccess();
__HAL_RCC_LSEDRIVE_CONFIG(RCC_LSEDRIVE_MEDIUMHIGH);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE|RCC_OSCILLATORTYPE_LSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.LSEState = RCC_LSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLL1_SOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 4;
  RCC_OscInitStruct.PLL.PLLN = 250;
  RCC_OscInitStruct.PLL.PLLP = 2;
  RCC_OscInitStruct.PLL.PLLQ = 2;
  RCC_OscInitStruct.PLL.PLLR = 2;
  RCC_OscInitStruct.PLL.PLLRGE = RCC_PLL1_VCIRANGE_1;
  RCC_OscInitStruct.PLL.PLLVCOSEL = RCC_PLL1_VCORANGE_WIDE;
  RCC_OscInitStruct.PLL.PLLFRACN = 0;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2
                              |RCC_CLOCKTYPE_PCLK3;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB3CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
 楼主| liszt99 发表于 2024-10-14 17:05 | 显示全部楼层
问题找到了。官方代码没问题。芯片也没问题。是我用电烙铁焊接晶体的时候,电烙铁有静电。晶体IO口被静电损坏了。
我检查了电烙铁,发现电烙铁地线没接好。接好地线,消除静电,后续没再出现这个问题了。
flycamelaaa 发表于 2024-10-15 17:17 | 显示全部楼层
所以芯片在焊接的时候一定要做好抗静电措施啊
