- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.0
- * $Revision: 2 $
- * $Date: 15/05/22 3:03p $
- * [url=home.php?mod=space&uid=247401]@brief[/url] Configure SPI0 as Master mode and demonstrate how to communicate
- * with an off-chip SPI Slave device with FIFO mode. This sample
- * code needs to work with SPI_SlaveFifoMode sample code.
- * @note
- * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M051Series.h"
- #define TEST_COUNT 16
- uint32_t g_au32SourceData[TEST_COUNT];
- uint32_t g_au32DestinationData[TEST_COUNT];
- volatile uint32_t g_u32TxDataCount;
- volatile uint32_t g_u32RxDataCount;
- /* Function prototype declaration */
- void SYS_Init(void);
- void SPI_Init(void);
- extern char GetChar(void);
- /* Main function */
- int main(void)
- uint32_t u32DataCount;
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O. */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Configure UART0: 115200, 8-bit word, no parity bit, 1 stop bit. */
- UART_Open(UART0, 115200);
- /* Init SPI */
- SPI_Init();
- printf("\n\n");
- printf("+----------------------------------------------------------------------+\n");
- printf("| SPI Master Mode Sample Code (M05xxDN/DE only) |\n");
- printf("\n");
- printf("Configure SPI0 as a master.\n");
- printf("Bit length of a transaction: 32\n");
- printf("The I/O connection for SPI0:\n");
- printf(" SPISS0(P1.4)\n SPICLK0(P1.7)\n");
- printf(" MISO_0(P1.6)\n MOSI_0(P1.5)\n\n");
- printf("SPI controller will enable FIFO mode and transfer %d data to a off-chip slave device.\n", TEST_COUNT);
- printf("In the meanwhile the SPI controller will receive %d data from the off-chip slave device.\n", TEST_COUNT);
- printf("After the transfer is done, the %d received data will be printed out.\n", TEST_COUNT);
- printf("The SPI master configuration is ready.\n");
- for(u32DataCount = 0; u32DataCount < TEST_COUNT; u32DataCount++)
- /* Write the initial value to source buffer */
- g_au32SourceData[u32DataCount] = 0x00550000 + u32DataCount;
- /* Clear destination buffer */
- g_au32DestinationData[u32DataCount] = 0;
- printf("Before starting the data transfer, make sure the slave device is ready. Press any key to start the transfer.\n");
- GetChar();
- printf("\n");
- /* Set TX FIFO threshold, enable TX FIFO threshold interrupt and RX FIFO time-out interrupt */
- SPI_EnableFIFO(SPI0, 4, 4);
- SPI_EnableInt(SPI0, SPI_FIFO_TX_INT_MASK | SPI_FIFO_TIMEOUT_INT_MASK);
- g_u32TxDataCount = 0;
- g_u32RxDataCount = 0;
- NVIC_EnableIRQ(SPI0_IRQn);
- /* Wait for transfer done */
- while(g_u32RxDataCount < TEST_COUNT);
- /* Print the received data */
- printf("Received data:\n");
- printf("%d:\t0x%X\n", u32DataCount, g_au32DestinationData[u32DataCount]);
- /* Disable TX FIFO threshold interrupt and RX FIFO time-out interrupt */
- SPI_DisableInt(SPI0, SPI_FIFO_TX_INT_MASK | SPI_FIFO_TIMEOUT_INT_MASK);
- NVIC_DisableIRQ(SPI0_IRQn);
- printf("The data transfer was done.\n");
- printf("\n\nExit SPI driver sample code.\n");
- /* Reset SPI0 */
- SPI_Close(SPI0);
- while(1);
- /* Init System Clock */
- /* Enable external 12MHz XTAL */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Switch HCLK clock source to HXT and set HCLK divider to 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT, CLK_CLKDIV_HCLK(1));
- /* Select HXT as the clock source of UART0 */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
- /* Select HCLK as the clock source of SPI0 */
- CLK_SetModuleClock(SPI0_MODULE, CLK_CLKSEL1_SPI0_S_HCLK, MODULE_NoMsk);
- /* Enable UART peripheral clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Enable SPI0 peripheral clock */
- CLK_EnableModuleClock(SPI0_MODULE);
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CyclesPerUs automatically. */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set P3 multi-function pins for UART0 RXD and TXD */
- SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
- /* Setup SPI0 multi-function pins */
- SYS->P1_MFP = SYS_MFP_P14_SPISS0 | SYS_MFP_P15_MOSI_0 | SYS_MFP_P16_MISO_0 | SYS_MFP_P17_SPICLK0;
- /* Init SPI */
- /* Configure as a master, clock idle low, 32-bit transaction, drive output on falling clock edge and latch input on rising edge. */
- /* Set IP clock divider. SPI clock rate = 1MHz */
- SPI_Open(SPI0, SPI_MASTER, SPI_MODE_0, 32, 1000000);
- /* Enable the automatic hardware slave select function. Select the SS pin and configure as low-active. */
- SPI_EnableAutoSS(SPI0, SPI_SS, SPI_SS_ACTIVE_LOW);
- void SPI0_IRQHandler(void)
- /* Check RX EMPTY flag */
- while(SPI_GET_RX_FIFO_EMPTY_FLAG(SPI0) == 0)
- /* Read RX FIFO */
- g_au32DestinationData[g_u32RxDataCount++] = SPI_READ_RX0(SPI0);
- /* Check TX FULL flag and TX data count */
- while((SPI_GET_TX_FIFO_FULL_FLAG(SPI0) == 0) && (g_u32TxDataCount < TEST_COUNT))
- /* Write to TX FIFO */
- SPI_WRITE_TX0(SPI0, g_au32SourceData[g_u32TxDataCount++]);
- if(g_u32TxDataCount >= TEST_COUNT)
- SPI_DisableInt(SPI0, SPI_FIFO_TX_INT_MASK); /* Disable TX FIFO threshold interrupt */
- /* Check the RX FIFO time-out interrupt flag */
- if(SPI_GetIntFlag(SPI0, SPI_FIFO_TIMEOUT_INT_MASK))
- /* If RX FIFO is not empty, read RX FIFO. */
- while((SPI0->STATUS & SPI_STATUS_RX_EMPTY_Msk) == 0)
- /*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
