所以对HCLK时钟源要求不高可以直接使用 这一个函数就搞定
- #include <stdio.h>
- #include "M058S.h"
- #define PLLCON_SETTING CLK_PLLCON_50MHz_HXT
- #define PLL_CLOCK 50000000
- void SYS_Init(void)
- /* Init System Clock */
- CLK_SetCoreClock(FREQ_50MHZ);
- CLK_EnableModuleClock(UART0_MODULE);
- CLK_SetModuleClock(UART0_MODULE,CLK_CLKSEL1_UART_S_PLL,CLK_CLKDIV_UART(1));
- /* Init I/O Multi-function */
- /* Set P3 multi-function pins for UART0 RXD , TXD and CKO */
- SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
- SYS->P3_MFP |= (SYS_MFP_P30_RXD | SYS_MFP_P31_TXD);
- void UART0_Init()
- /* Init UART */
- /* Reset UART0 */
- SYS->IPRSTC2 |= SYS_IPRSTC2_UART0_RST_Msk;
- SYS->IPRSTC2 &= ~SYS_IPRSTC2_UART0_RST_Msk;
- /* Configure UART0 and set UART0 Baudrate */
- UART0->BAUD = UART_BAUD_MODE2 | UART_BAUD_MODE2_DIVIDER(__HXT, 115200);
- UART0->LCR = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
- /* Main Function */
- int32_t main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, peripheral clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART0 for printf */
- UART0_Init();
- printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
- This sample code will blinking LED on NuTiny EVB board of M058SSAN.
- The I/O for LED is P2.3 or P3.6
- printf("+---------------------------------------+\n");
- printf("| NuTiny EVB LED Sample Code |\n");
- /* Init P3.6 to be output mode */
- GPIO_SetMode(P3,BIT6,GPIO_PMD_OUTPUT);
- while(1)
- /* Toggle P3.6 */
- P36 ^= 1;
- /* Delay 200ms */
- CLK_SysTickDelay(200000);
