| LED灯不断闪烁 GPIO初始化,main文件中的 MX_GPIO_Init(); 也就是在 gpio.c文件中
 void MX_GPIO_Init(void)
 GPIO_InitTypeDef GPIO_InitStruct = {0};
 /* GPIO Ports Clock Enable */
 __HAL_RCC_GPIOE_CLK_ENABLE();
 __HAL_RCC_GPIOC_CLK_ENABLE();
 __HAL_RCC_GPIOA_CLK_ENABLE();
 __HAL_RCC_GPIOB_CLK_ENABLE();
 /*Configure GPIO pin Output Level */
 HAL_GPIO_WritePin(GPIOE, GPIO_PIN_5, GPIO_PIN_SET);
 HAL_GPIO_WritePin(GPIOB, GPIO_PIN_5, GPIO_PIN_SET);
 /*Configure GPIO pin : PE5 */
 GPIO_InitStruct.Pin = GPIO_PIN_5;
 GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
 GPIO_InitStruct.Pull = GPIO_NOPULL;
 GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
 HAL_GPIO_Init(GPIOE, &GPIO_InitStruct);
 /*Configure GPIO pin : PB5 */
 HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
 查看gpio函数,在 stm32f1xx_hal_gpio.h 或 stm32f1xx_hal_gpio.c 中查看
 业务逻辑代码 led.c
 #include "stm32f1xx_hal.h"
 #define LED_PIN GPIO_PIN_5
 #define LED_PORT GPIOB
 void led_on(void)
 HAL_GPIO_WritePin(LED_PORT, LED_PIN, GPIO_PIN_RESET); // 设置GPIOB的Pin5为高电平
 void led_off(void)
 HAL_GPIO_WritePin(LED_PORT, LED_PIN, GPIO_PIN_SET); // 设置GPIOB的Pin5为低电平
 void led_toggle(void)
 HAL_GPIO_TogglePin(LED_PORT, LED_PIN); // 切换GPIOB的Pin5电平
 main.c
 /* USER CODE BEGIN Header */
 * @file           : main.c
 * @brief          : Main program body
 * @attention
 * Copyright (c) 2025 STMicroelectronics.
 * All rights reserved.
 * This software is licensed under terms that can be found in the LICENSE file
 * in the root directory of this software component.
 * If no LICENSE file comes with this software, it is provided AS-IS.
 /* USER CODE END Header */
 /* Includes ------------------------------------------------------------------*/
 #include "main.h"
 #include "gpio.h"
 /* Private includes ----------------------------------------------------------*/
 /* USER CODE BEGIN Includes */
 #include "led.h"
 /* USER CODE END Includes */
 /* Private typedef -----------------------------------------------------------*/
 /* USER CODE BEGIN PTD */
 /* USER CODE END PTD */
 /* Private define ------------------------------------------------------------*/
 /* USER CODE BEGIN PD */
 /* USER CODE END PD */
 /* Private macro -------------------------------------------------------------*/
 /* USER CODE BEGIN PM */
 /* USER CODE END PM */
 /* Private variables ---------------------------------------------------------*/
 /* USER CODE BEGIN PV */
 /* USER CODE END PV */
 /* Private function prototypes -----------------------------------------------*/
 void SystemClock_Config(void);
 /* USER CODE BEGIN PFP */
 /* USER CODE END PFP */
 /* Private user code ---------------------------------------------------------*/
 /* USER CODE BEGIN 0 */
 /* USER CODE END 0 */
 * @brief  The application entry point.
 * @retval int
 int main(void)
 /* USER CODE BEGIN 1 */
 /* USER CODE END 1 */
 /* MCU Configuration--------------------------------------------------------*/
 /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
 HAL_Init();
 /* USER CODE BEGIN Init */
 /* USER CODE END Init */
 SystemClock_Config();
 /* USER CODE BEGIN SysInit */
 /* USER CODE END SysInit */
 MX_GPIO_Init();
 /* USER CODE BEGIN 2 */
 /* USER CODE END 2 */
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 while (1)
 led_toggle();
 HAL_Delay(1000);
 /* USER CODE END WHILE */
 /* USER CODE BEGIN 3 */
 /* USER CODE END 3 */
 * @brief System Clock Configuration
 * @retval None
 RCC_OscInitTypeDef RCC_OscInitStruct = {0};
 RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
 /** Initializes the RCC Oscillators according to the specified parameters
 * in the RCC_OscInitTypeDef structure.
 RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
 RCC_OscInitStruct.HSEState = RCC_HSE_ON;
 RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
 RCC_OscInitStruct.HSIState = RCC_HSI_ON;
 RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
 RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
 RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
 if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
 Error_Handler();
 /** Initializes the CPU, AHB and APB buses clocks
 RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2;
 RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
 RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
 RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
 RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
 if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN 4 */
 /* USER CODE END 4 */
 * @brief  This function is executed in case of error occurrence.
 * @retval None
 void Error_Handler(void)
 /* USER CODE BEGIN Error_Handler_Debug */
 /* User can add his own implementation to report the HAL error return state */
 __disable_irq();
 while (1)
 /* USER CODE END Error_Handler_Debug */
 #ifdef USE_FULL_ASSERT
 * @brief  Reports the name of the source file and the source line number
 *         where the assert_param error has occurred.
 * @param  file: pointer to the source file name
 * @param  line: assert_param error line source number
 * @retval None
 void assert_failed(uint8_t *file, uint32_t line)
 /* USER CODE BEGIN 6 */
 /* User can add his own implementation to report the file name and line number,
 ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
 /* USER CODE END 6 */
 #endif /* USE_FULL_ASSERT */
 轮询方式按键点亮LED灯
 /*Configure GPIO pin : PE4 */
 GPIO_InitStruct.Pin = GPIO_PIN_4;
 GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
 GPIO_InitStruct.Pull = GPIO_PULLUP;
 业务逻辑代码 key.c
 #include "Key.h"
 uint8_t flag = 0;
 uint8_t Key_Getflag(void)
 HAL_Delay(10);
 flag=0;
 if(HAL_GPIO_ReadPin(GPIOE,GPIO_PIN_4)==0)
 while (HAL_GPIO_ReadPin(GPIOE,GPIO_PIN_4)==0);
 flag=1;
 HAL_Delay(10);
 return flag;
 main.c
 * @file           : main.c
 * @attention
 #include "main.h"
 #include "gpio.h"
 #include "led.h"
 #include "Key.h"
 * @retval int
 int main(void)
 HAL_Init();
 MX_GPIO_Init();
 /* Infinite loop */
 while (1)
 if (Key_Getflag() == 1)
 led_toggle();
 * @retval None
 Error_Handler();
 RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
 |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
 Error_Handler();
 * @retval None
 __disable_irq();
 while (1)
 * @retval None
 原文链接:https://blog.csdn.net/qq_65047384/article/details/147097130
