[研电赛技术支持] stm32F103、GD32F103读写Nor Flash实战指南
2352|0
 楼主| 观海 发表于 2025-5-7 19:35 | 显示全部楼层 |阅读模式
一、NOR Flash基础与硬件连接
1. NOR Flash简介
NOR Flash是一种非易失性存储器,支持随机访问和XIP(Execute In Place)特性,常用于存储固件代码、特定数据。典型型号如GD25Q128(128Mbit容量,SPI接口),其擦写寿命约10万次,适合嵌入式系统扩展存储。
2. GD32F103硬件设计
以SPI接口的GD25Q系列为例:
引脚连接:
二、SPI外设配置与驱动开发
1. SPI初始化代码
void SPI_FLASH_Init(void)
  u32 temp;
  SPI_InitTypeDef  SPI_InitStructure;
  /* Enable SPI1 and GPIO clocks */
  /*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO,
       SPI_FLASH_SPI_MISO_GPIO, SPI_FLASH_SPI_DETECT_GPIO
       and SPI_FLASH_SPI_SCK_GPIO Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOD, ENABLE);
  /*!< SPI_FLASH_SPI Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
  /*!< Configure SPI_FLASH_SPI pins: SCK */
  GPIO_InitStructure.GPIO_Pin = GPIO_FONT_SPI_SCK;
  GPIO_InitStructure.GPIO_Mode = GPIO_FONT_SPI_SCK_FLAG;
  GPIO_Init(GPIO_FONT_SPI, &GPIO_InitStructure);
  /*!< Configure SPI_FLASH_SPI pins: MISO */
  GPIO_InitStructure.GPIO_Pin = GPIO_FONT_SPI_MISO;
  /*!< Configure SPI_FLASH_SPI pins: MOSI */
  GPIO_InitStructure.GPIO_Pin = GPIO_FONT_SPI_MOSI;
  /*!< Configure SPI_FLASH_SPI_CS_PIN pin: SPI_FLASH Card CS pin */
  GPIO_InitStructure.GPIO_Pin = GPIO_FONT_SPI_NSS;
  GPIO_InitStructure.GPIO_Mode = GPIO_FONT_SPI_NSS_FLAG;
  /* Deselect the FLASH: Chip Select high */
  SPI_FLASH_CS_HIGH();
  /* SPI1 configuration */
  // W25X16: data input on the DIO pin is sampled on the rising edge of the CLK.
  // Data on the DO and DIO pins are clocked out on the falling edge of CLK.
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI2, &SPI_InitStructure);
  /* Enable SPI1  */
  SPI_Cmd(SPI2, ENABLE);
//temp = SPI_FLASH_ReadID();
根据temp = SPI_FLASH_ReadID()返回的值,可以判断Nor Flash的一些信息,比如型号、容量大小等。
2. NOR Flash控制函数
发送一个字节数据或命令
u8 SPI_FLASH_SendByte(u8 byte)
  /* Loop while DR register in not emplty */
  while (SPI_I2S_GetFlagStatus(FONT_SPI, SPI_I2S_FLAG_TXE) == RESET);
  /* Send byte through the SPI1 peripheral */
  SPI_I2S_SendData(FONT_SPI, byte);
  /* Wait to receive a byte */
  while (SPI_I2S_GetFlagStatus(FONT_SPI, SPI_I2S_FLAG_RXNE) == RESET);
  /* Return the byte read from the SPI bus */
  return SPI_I2S_ReceiveData(FONT_SPI);
发送半字数据
u16 SPI_FLASH_SendHalfWord(u16 HalfWord)
  /* Send Half Word through the SPI1 peripheral */
  SPI_I2S_SendData(FONT_SPI, HalfWord);
  /* Wait to receive a Half Word */
  /* Return the Half Word read from the SPI bus */
读取一个字节
u8 SPI_FLASH_ReadByte(void)
  return (SPI_FLASH_SendByte(Dummy_Byte));
三、关键操作实现
1. 数据读取(Read Data)
void SPI_FLASH_BufferRead(u8* pBuffer, u32 ReadAddr, u16 NumByteToRead)
  /* Select the FLASH: Chip Select low */
  SPI_FLASH_CS_LOW();
  /* Send "Read from Memory " instruction */
  SPI_FLASH_SendByte(W25X_ReadData);
  /* Send ReadAddr high nibble address byte to read from */
  SPI_FLASH_SendByte((ReadAddr & 0xFF0000) >> 16);
  /* Send ReadAddr medium nibble address byte to read from */
  SPI_FLASH_SendByte((ReadAddr& 0xFF00) >> 8);
  /* Send ReadAddr low nibble address byte to read from */
  SPI_FLASH_SendByte(ReadAddr & 0xFF);
  while (NumByteToRead--) /* while there is data to be read */
    /* Read a byte from the FLASH */
    *pBuffer = SPI_FLASH_SendByte(Dummy_Byte);
    /* Point to the next location where the byte read will be saved */
    pBuffer++;
2. 扇区擦除(Sector Erase)
void SPI_FLASH_SectorErase(u32 SectorAddr)
  /* Send write enable instruction */
  SPI_FLASH_WriteEnable();
  SPI_FLASH_WaitForWriteEnd();
  /* Sector Erase */
  SPI_FLASH_CS_LOW();
  /* Send Sector Erase instruction */
  SPI_FLASH_SendByte(W25X_SectorErase);
  /* Send SectorAddr high nibble address byte */
  SPI_FLASH_SendByte((SectorAddr & 0xFF0000) >> 16);
  /* Send SectorAddr medium nibble address byte */
  SPI_FLASH_SendByte((SectorAddr & 0xFF00) >> 8);
  /* Send SectorAddr low nibble address byte */
  SPI_FLASH_SendByte(SectorAddr & 0xFF);
  /* Wait the end of Flash writing */
3. 写数据
void SPI_FLASH_BufferWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite)
  u8 NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0, temp = 0;
  Addr = WriteAddr % SPI_FLASH_PageSize;
  count = SPI_FLASH_PageSize - Addr;
  NumOfPage =  NumByteToWrite / SPI_FLASH_PageSize;
  NumOfSingle = NumByteToWrite % SPI_FLASH_PageSize;
  if (Addr == 0) /* WriteAddr is SPI_FLASH_PageSize aligned  */
    if (NumOfPage == 0) /* NumByteToWrite < SPI_FLASH_PageSize */
      SPI_FLASH_PageWrite(pBuffer, WriteAddr, NumByteToWrite);
    else /* NumByteToWrite > SPI_FLASH_PageSize */
      while (NumOfPage--)
        SPI_FLASH_PageWrite(pBuffer, WriteAddr, SPI_FLASH_PageSize);
        WriteAddr +=  SPI_FLASH_PageSize;
        pBuffer += SPI_FLASH_PageSize;
      SPI_FLASH_PageWrite(pBuffer, WriteAddr, NumOfSingle);
  else /* WriteAddr is not SPI_FLASH_PageSize aligned  */
      if (NumOfSingle > count) /* (NumByteToWrite + WriteAddr) > SPI_FLASH_PageSize */
        temp = NumOfSingle - count;
        SPI_FLASH_PageWrite(pBuffer, WriteAddr, count);
        WriteAddr +=  count;
        pBuffer += count;
        SPI_FLASH_PageWrite(pBuffer, WriteAddr, temp);
      else
      NumByteToWrite -= count;
      WriteAddr +=  count;
      pBuffer += count;
      while (NumOfPage--)
      if (NumOfSingle != 0)
四、完整代码
* ÎļþÃû  £ºspi_flash.c
* ÃèÊö    £ºspi µ×²ãÓ¦Óú¯Êý¿â
* ʵÑéÆ½Ì¨£ºÒ°»ðSTM32¿ª·¢°å
* Ó²¼þÁ¬½Ó ----------------------------
*         | PA4-SPI1-NSS  : W25X16-CS  |
*         | PA5-SPI1-SCK  : W25X16-CLK |
*         | PA6-SPI1-MISO : W25X16-DO  |
*         | PA7-SPI1-MOSI : W25X16-DIO |
* ¿â°æ±¾  £ºST3.5.0
* ×÷Õß    £º±£Áô
* ÂÛ̳    £ºhttp://www.amobbs.com/forum-1008-1.html
* ÌÔ±¦    £ºhttp://firestm32.taobao.com
#include "spi_flash.h"
/* Private typedef -----------------------------------------------------------*/
//#define SPI_FLASH_PageSize      4096
#define SPI_FLASH_PageSize      256
#define SPI_FLASH_PerWritePageSize      256
/* Private define ------------------------------------------------------------*/
#define W25X_WriteEnable                      0x06
#define W25X_WriteDisable                      0x04
#define W25X_ReadStatusReg                    0x05
#define W25X_WriteStatusReg                    0x01
#define W25X_ReadData                                0x03
#define W25X_FastReadData                      0x0B
#define W25X_FastReadDual                      0x3B
#define W25X_PageProgram                      0x02
#define W25X_BlockErase                              0xD8
#define W25X_SectorErase                      0x20
#define W25X_ChipErase                              0xC7
#define W25X_PowerDown                              0xB9
#define W25X_ReleasePowerDown            0xAB
#define W25X_DeviceID                                0xAB
#define W25X_ManufactDeviceID           0x90
#define W25X_JedecDeviceID                    0x9F
#define WIP_Flag                  0x01  /* Write In Progress (WIP) flag */
#define Dummy_Byte                0xFF
* Function Name  : SPI_FLASH_Init
* Description    : Initializes the peripherals used by the SPI FLASH driver.
* Input          : None
* Output         : None
* Return         : None
#ifdef _DRIVER_IN_
        u32 temp;
#endif
  /* Enable SPI1  */
#ifdef _DRIVER_IN_
        if ((temp == GD25Q32)||(temp == PY25Q32))
                MassType = MASS_25Q32;
        else
                MassType = MASS_25Q16;
#else
#endif
* Function Name  : SPI_FLASH_SectorErase
* Description    : Erases the specified FLASH sector.
* Input          : SectorAddr: address of the sector to erase.
* Output         : None
* Return         : None
  /* Sector Erase */
  SPI_FLASH_CS_LOW();
* Function Name  : SPI_FLASH_BlockErase
* Output         : None
* Return         : None
void SPI_FLASH_BlockErase(u32 BlockAddr)
  /* Sector Erase */
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(W25X_BlockErase);
  SPI_FLASH_SendByte((BlockAddr & 0xFF0000) >> 16);
  SPI_FLASH_SendByte((BlockAddr & 0xFF00) >> 8);
  SPI_FLASH_SendByte(BlockAddr & 0xFF);
* Function Name  : SPI_FLASH_BulkErase
* Description    : Erases the entire FLASH.
* Input          : None
* Output         : None
* Return         : None
void SPI_FLASH_BulkErase(void)
  /* Bulk Erase */
  SPI_FLASH_CS_LOW();
  /* Send Bulk Erase instruction  */
  SPI_FLASH_SendByte(W25X_ChipErase);
* Function Name  : SPI_FLASH_PageWrite
* Description    : Writes more than one byte to the FLASH with a single WRITE
*                  cycle(Page WRITE sequence). The number of byte can't exceed
*                  the FLASH page size.
* Input          : - pBuffer : pointer to the buffer  containing the data to be
*                    written to the FLASH.
*                  - WriteAddr : FLASH's internal address to write to.
*                  - NumByteToWrite : number of bytes to write to the FLASH,
*                    must be equal or less than "SPI_FLASH_PageSize" value.
* Output         : None
* Return         : None
void SPI_FLASH_PageWrite(u8* pBuffer, u32 WriteAddr, u16 NumByteToWrite)
  /* Enable the write access to the FLASH */
  SPI_FLASH_CS_LOW();
  /* Send "Write to Memory " instruction */
  SPI_FLASH_SendByte(W25X_PageProgram);
  /* Send WriteAddr high nibble address byte to write to */
  SPI_FLASH_SendByte((WriteAddr & 0xFF0000) >> 16);
  /* Send WriteAddr medium nibble address byte to write to */
  SPI_FLASH_SendByte((WriteAddr & 0xFF00) >> 8);
  /* Send WriteAddr low nibble address byte to write to */
  SPI_FLASH_SendByte(WriteAddr & 0xFF);
  if(NumByteToWrite > SPI_FLASH_PerWritePageSize)
     NumByteToWrite = SPI_FLASH_PerWritePageSize;
     //printf("\n\r Err: SPI_FLASH_PageWrite too large!");
  /* while there is data to be written on the FLASH */
  while (NumByteToWrite--)
    /* Send the current byte */
    SPI_FLASH_SendByte(*pBuffer);
    /* Point on the next byte to be written */
    pBuffer++;
* Function Name  : SPI_FLASH_BufferWrite
* Description    : Writes block of data to the FLASH. In this function, the
*                  number of WRITE cycles are reduced, using Page WRITE sequence.
*                  - NumByteToWrite : number of bytes to write to the FLASH.
* Output         : None
* Return         : None
      while (NumOfPage--)
        WriteAddr +=  count;
        pBuffer += count;
      else
      WriteAddr +=  count;
      pBuffer += count;
      while (NumOfPage--)
//ÎÞ¼ìÑéдSPI FLASH
//±ØÐëÈ·±£ËùдµÄµØÖ··¶Î§ÄÚµÄÊý¾ÝÈ«²¿Îª0XFF,·ñÔòÔÚ·Ç0XFF´¦Ð´ÈëµÄÊý¾Ý½«Ê§°Ü!
//¾ßÓÐ×Ô¶¯»»Ò³¹¦ÄÜ
//ÔÚÖ¸¶¨µØÖ·¿ªÊ¼Ð´ÈëÖ¸¶¨³¤¶ÈµÄÊý¾Ý,µ«ÊÇҪȷ±£µØÖ·²»Ô½½ç!
//pBuffer:Êý¾Ý´æ´¢Çø
//WriteAddr:¿ªÊ¼Ð´ÈëµÄµØÖ·(24bit)
//NumByteToWrite:ҪдÈëµÄ×Ö½ÚÊý(×î´ó65535)
//CHECK OK
void SPI_Flash_Write_NoCheck(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite)
        u16 pageremain;
        pageremain=256-WriteAddr%256; //µ¥Ò³Ê£ÓàµÄ×Ö½ÚÊý
        if(NumByteToWrite<=pageremain)pageremain=NumByteToWrite;//²»´óÓÚ256¸ö×Ö½Ú
        while(1)
                SPI_FLASH_PageWrite(pBuffer,WriteAddr,pageremain);
                if(NumByteToWrite==pageremain)break;//дÈë½áÊøÁË
                 else //NumByteToWrite>pageremain
                        pBuffer+=pageremain;
                        WriteAddr+=pageremain;
                        NumByteToWrite-=pageremain;                          //¼õÈ¥ÒѾ­Ð´ÈëÁ˵Ä×Ö½ÚÊý
                        if(NumByteToWrite>256)pageremain=256; //Ò»´Î¿ÉÒÔдÈë256¸ö×Ö½Ú
                        else pageremain=NumByteToWrite;           //²»¹»256¸ö×Ö½ÚÁË
u8 SPI_FLASH_BUF[4096];
void        SPI_Flash_Read(u8* pBuffer, u32 ReadAddr, u16 NumByteToRead);
void SPI_Flash_Write(u8* pBuffer,u32 WriteAddr,u16 NumByteToWrite)
        u32 secpos;
        u16 secoff;
        u16 secremain;
        u16 i;
        secpos=WriteAddr/4096;//ÉÈÇøµØÖ· 0~511 for w25x16
        secoff=WriteAddr%4096;//ÔÚÉÈÇøÄ򵀮«ÒÆ
        secremain=4096-secoff;//ÉÈÇøÊ£Óà¿Õ¼ä´óС
        if(NumByteToWrite<=secremain)secremain=NumByteToWrite;//²»´óÓÚ4096¸ö×Ö½Ú
        while(1)
                SPI_Flash_Read(SPI_FLASH_BUF,secpos*4096,4096);//¶Á³öÕû¸öÉÈÇøµÄÄÚÈÝ
                for(i=0;i<secremain;i++)//УÑéÊý¾Ý
                        if(SPI_FLASH_BUF[secoff+i]!=0XFF)break;//ÐèÒª²Á³ý
                if(i<secremain)//ÐèÒª²Á³ý
                        SPI_FLASH_SectorErase(secpos * 4096);//²Á³ýÕâ¸öÉÈÇø
                        for(i=0;i<secremain;i++)           //¸´ÖÆ
                                SPI_FLASH_BUF[i+secoff]=pBuffer;
                        SPI_Flash_Write_NoCheck(SPI_FLASH_BUF,secpos*4096,4096);//дÈëÕû¸öÉÈÇø
                }else SPI_Flash_Write_NoCheck(pBuffer,WriteAddr,secremain);//дÒѾ­²Á³ýÁ˵Ä,Ö±½ÓдÈëÉÈÇøÊ£ÓàÇø¼ä.
                if(NumByteToWrite==secremain)break;//дÈë½áÊøÁË
                else//дÈëδ½áÊø
                        secpos++;//ÉÈÇøµØÖ·Ôö1
                        secoff=0;//Æ«ÒÆÎ»ÖÃΪ0
                           pBuffer+=secremain;  //Ö¸ÕëÆ«ÒÆ
                        WriteAddr+=secremain;//дµØÖ·Æ«ÒÆ
                           NumByteToWrite-=secremain;                                //×Ö½ÚÊýµÝ¼õ
                        if(NumByteToWrite>4096)secremain=4096;        //ÏÂÒ»¸öÉÈÇø»¹ÊÇд²»Íê
                        else secremain=NumByteToWrite;                        //ÏÂÒ»¸öÉÈÇø¿ÉÒÔдÍêÁË
* Function Name  : SPI_FLASH_BufferRead
* Description    : Reads a block of data from the FLASH.
* Input          : - pBuffer : pointer to the buffer that receives the data read
*                    from the FLASH.
*                  - ReadAddr : FLASH's internal address to read from.
*                  - NumByteToRead : number of bytes to read from the FLASH.
* Output         : None
* Return         : None
  SPI_FLASH_CS_LOW();
    pBuffer++;
                SPI_FLASH_BufferRead(pBuffer,ReadAddr,NumByteToRead);
                return;
* Function Name  : SPI_FLASH_ReadID
* Description    : Reads FLASH identification.
* Input          : None
* Output         : None
* Return         : FLASH identification
u32 SPI_FLASH_ReadID(void)
  u32 Temp = 0, Temp0 = 0, Temp1 = 0, Temp2 = 0;
  SPI_FLASH_CS_LOW();
  /* Send "RDID " instruction */
  SPI_FLASH_SendByte(W25X_JedecDeviceID);
  Temp0 = SPI_FLASH_SendByte(Dummy_Byte);
  Temp1 = SPI_FLASH_SendByte(Dummy_Byte);
  Temp2 = SPI_FLASH_SendByte(Dummy_Byte);
  Temp = (Temp0 << 16) | (Temp1 << 8) | Temp2;
  return Temp;
* Input          : None
* Output         : None
u32 SPI_FLASH_ReadDeviceID(void)
  u32 Temp = 0;
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(W25X_DeviceID);
  Temp = SPI_FLASH_SendByte(Dummy_Byte);
  return Temp;
* Function Name  : SPI_FLASH_StartReadSequence
* Description    : Initiates a read data byte (READ) sequence from the Flash.
*                  This is done by driving the /CS line low to select the device,
*                  then the READ instruction is transmitted followed by 3 bytes
*                  address. This function exit and keep the /CS line low, so the
*                  Flash still being selected. With this technique the whole
*                  content of the Flash is read with a single READ instruction.
* Input          : - ReadAddr : FLASH's internal address to read from.
* Output         : None
* Return         : None
void SPI_FLASH_StartReadSequence(u32 ReadAddr)
  SPI_FLASH_CS_LOW();
  /* Send the 24-bit address of the address to read from -----------------------*/
  /* Send ReadAddr high nibble address byte */
  /* Send ReadAddr medium nibble address byte */
  /* Send ReadAddr low nibble address byte */
* Function Name  : SPI_FLASH_ReadByte
* Description    : Reads a byte from the SPI Flash.
*                  This function must be used only if the Start_Read_Sequence
*                  function has been previously called.
* Input          : None
* Output         : None
* Return         : Byte Read from the SPI Flash.
* Function Name  : SPI_FLASH_SendByte
* Description    : Sends a byte through the SPI interface and return the byte
*                  received from the SPI bus.
* Input          : byte : byte to send.
* Output         : None
* Return         : The value of the received byte.
* Function Name  : SPI_FLASH_SendHalfWord
* Description    : Sends a Half Word through the SPI interface and return the
*                  Half Word received from the SPI bus.
* Input          : Half Word : Half Word to send.
* Output         : None
* Return         : The value of the received Half Word.
* Function Name  : SPI_FLASH_WriteEnable
* Description    : Enables the write access to the FLASH.
* Input          : None
* Output         : None
* Return         : None
void SPI_FLASH_WriteEnable(void)
  SPI_FLASH_CS_LOW();
  /* Send "Write Enable" instruction */
  SPI_FLASH_SendByte(W25X_WriteEnable);
* Function Name  : SPI_FLASH_WaitForWriteEnd
* Description    : Polls the status of the Write In Progress (WIP) flag in the
*                  FLASH's status  register  and  loop  until write  opertaion
*                  has completed.
* Input          : None
* Output         : None
* Return         : None
void SPI_FLASH_WaitForWriteEnd(void)
  u8 FLASH_Status = 0;
  SPI_FLASH_CS_LOW();
  /* Send "Read Status Register" instruction */
  SPI_FLASH_SendByte(W25X_ReadStatusReg);
  /* Loop as long as the memory is busy with a write cycle */
  do
    /* Send a dummy byte to generate the clock needed by the FLASH
    and put the value of the status register in FLASH_Status variable */
    FLASH_Status = SPI_FLASH_SendByte(Dummy_Byte);
  while ((FLASH_Status & WIP_Flag) == SET); /* Write in progress */
//½øÈëµôµçģʽ
void SPI_Flash_PowerDown(void)
  SPI_FLASH_CS_LOW();
  /* Send "Power Down" instruction */
  SPI_FLASH_SendByte(W25X_PowerDown);
//»½ÐÑ
void SPI_Flash_WAKEUP(void)
  SPI_FLASH_CS_LOW();
  SPI_FLASH_SendByte(W25X_ReleasePowerDown);
  SPI_FLASH_CS_HIGH();                   //µÈ´ýTRES1
/******************************END OF FILE*****************************/
这里说的完整代码并不是整个工程的全部代码,只是与Nor Flash读写有关的代码。
五、总结
通过GD32F103的SPI接口操作NOR Flash,开发者可灵活扩展嵌入式系统的存储能力。本文提供了从底层驱动NOR Flash的方式。
原文链接:https://blog.csdn.net/weald2000/article/details/147313523
