/*---------------------------------------------------------------------------------------------------------*/ /* */ /* SPDX-License-Identifier: Apache-2.0 */ /* Copyright(c) 2023 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // File Function: ML51 UART0 ISP demo code //*********************************************************************************************************** #include "MG51_SDCC.H" #include "isp_uart0.h" //#define isp_with_wdt unsigned int __xdata start_address,u16_addr; void Serial_ISR(void) __interrupt (4) { PUSH_SFRS; if (RI == 1) { uart_rcvbuf[bufhead++] = SBUF; clr_SCON_RI; // Clear RI (Receive Interrupt). } if (TI == 1) { clr_SCON_TI; // Clear TI (Transmit Interrupt). } if (bufhead == 1) { g_timer1Over = 0; g_timer1Counter = 90; //for check uart timeout using } if (bufhead == 64) { bUartDataReady = TRUE; g_timer1Counter = 0; g_timer1Over = 0; bufhead = 0; } POP_SFRS; } void Timer0_ISR(void) __interrupt (1) { PUSH_SFRS; if (g_timer0Counter) { g_timer0Counter--; if (!g_timer0Counter) { g_timer0Over = 1; } } if (g_timer1Counter) { g_timer1Counter--; if (!g_timer1Counter) { g_timer1Over = 1; } } POP_SFRS; } /************************************************************************************************************ * Main function ************************************************************************************************************/ void main (void) { set_CHPCON_IAPEN; MODIFY_HIRC_24(); #ifdef isp_with_wdt TA=0x55;TA=0xAA;WDCON=0x07; #endif //uart initial for ISP programmer GUI, always use 115200 baudrate UART0_ini_115200_24MHz(); TM0_ini(); g_timer0Over=0; g_timer0Counter=Timer0Out_Counter; g_programflag=0; while(1) { if(bUartDataReady == TRUE) { EA=0; //DISABLE ALL INTERRUPT if(g_programflag==1) { for(count=8;count<64;count++) { // g_timer0Counter=Timer0Out_Counter; IAPCN = BYTE_PROGRAM_AP; //program byte IAPAL = flash_address&0xff; IAPAH = (flash_address>>8)&0xff; IAPFD=uart_rcvbuf[count]; #ifdef isp_with_wdt set_IAPTRG_IAPGO_WDCLR; #else set_IAPTRG_IAPGO; #endif IAPCN = BYTE_READ_AP; //program byte verify if(IAPFD!=uart_rcvbuf[count]) while(1); if (CHPCON==0x43) //if error flag set, program error stop ISP while(1); g_totalchecksum=g_totalchecksum+uart_rcvbuf[count]; flash_address++; if(flash_address==AP_size) { g_programflag=0; g_timer0Over =1; goto END_2; } } END_2: Package_checksum(); uart_txbuf[8]=g_totalchecksum&0xff; uart_txbuf[9]=(g_totalchecksum>>8)&0xff; Send_64byte_To_UART0(); } switch(uart_rcvbuf[0]) { case CMD_CONNECT: case CMD_SYNC_PACKNO: { Package_checksum(); Send_64byte_To_UART0(); g_timer0Counter=0; //clear timer 0 for no reset g_timer0Over=0; break; } case CMD_GET_FWVER: { Package_checksum(); uart_txbuf[8]=FW_VERSION; Send_64byte_To_UART0(); break; } case CMD_RUN_APROM: { goto _APROM; break; } //please for ISP programmer GUI, ID always use following rule to transmit. case CMD_GET_DEVICEID: { READ_ID(); Package_checksum(); uart_txbuf[8]=DID_lowB; uart_txbuf[9]=DID_highB; uart_txbuf[10]=PID_lowB; uart_txbuf[11]=PID_highB; Send_64byte_To_UART0(); break; } case CMD_ERASE_ALL: { set_IAPUEN_APUEN; IAPFD = 0xFF; //Erase must set IAPFD = 0xFF IAPCN = PAGE_ERASE_AP; for(flash_address=0x0000;flash_address<APROM_SIZE/PAGE_SIZE;flash_address++) { IAPAL = LOBYTE(flash_address*PAGE_SIZE); IAPAH = HIBYTE(flash_address*PAGE_SIZE); #ifdef isp_with_wdt set_IAPTRG_IAPGO_WDCLR; #else set_IAPTRG_IAPGO; #endif } Package_checksum(); Send_64byte_To_UART0(); break; } case CMD_READ_CONFIG: { READ_CONFIG(); Package_checksum(); uart_txbuf[8]=CONF0; uart_txbuf[9]=CONF1; uart_txbuf[10]=CONF2; uart_txbuf[11]=0xff; uart_txbuf[12]=CONF4; uart_txbuf[13]=0xff; uart_txbuf[14]=0xff; uart_txbuf[15]=0xff; Send_64byte_To_UART0(); break; } case CMD_UPDATE_CONFIG: { recv_CONF0 = uart_rcvbuf[8]; recv_CONF1 = uart_rcvbuf[9]; recv_CONF2 = uart_rcvbuf[10]; recv_CONF4 = uart_rcvbuf[12]; set_IAPUEN_CFUEN; /*Erase CONFIG */ IAPCN = PAGE_ERASE_CONFIG; IAPAL = 0x00; IAPAH = 0x00; IAPFD = 0xFF; #ifdef isp_with_wdt set_IAPTRG_IAPGO_WDCLR; #else set_IAPTRG_IAPGO; #endif IAPCN = BYTE_PROGRAM_CONFIG; /*Program CONFIG*/ IAPFD = recv_CONF0; #ifdef isp_with_wdt set_IAPTRG_IAPGO_WDCLR; #else set_IAPTRG_IAPGO; #endif IAPFD = recv_CONF1; IAPAL = 0x01; #ifdef isp_with_wdt set_IAPTRG_IAPGO_WDCLR; #else set_IAPTRG_IAPGO; #endif IAPAL = 0x02; IAPFD = recv_CONF2; #ifdef isp_with_wdt set_IAPTRG_IAPGO_WDCLR; #else set_IAPTRG_IAPGO; #endif IAPAL = 0x04; IAPFD = recv_CONF4; #ifdef isp_with_wdt set_IAPTRG_IAPGO_WDCLR; #else set_IAPTRG_IAPGO; #endif clr_IAPUEN_CFUEN; READ_CONFIG(); /*Read new CONFIG*/ Package_checksum(); uart_txbuf[8]=CONF0; uart_txbuf[9]=CONF1; uart_txbuf[10]=CONF2; uart_txbuf[11]=0xff; uart_txbuf[12]=CONF4; uart_txbuf[13]=0xff; uart_txbuf[14]=0xff; uart_txbuf[15]=0xff; Send_64byte_To_UART0(); break; } case CMD_UPDATE_APROM: { // g_timer0Counter=Timer0Out_Counter; set_IAPUEN_APUEN; IAPFD = 0xFF; //Erase must set IAPFD = 0xFF IAPCN = PAGE_ERASE_AP; start_address = 0; start_address = uart_rcvbuf[8]; start_address |= ((uart_rcvbuf[9]<<8)&0xFF00); AP_size = 0; AP_size = uart_rcvbuf[12]; AP_size |= ((uart_rcvbuf[13]<<8)&0xFF00); u16_addr = start_address + AP_size; flash_address = (start_address&0xFF00); while(flash_address< u16_addr) { IAPAL = LOBYTE(flash_address); IAPAH = HIBYTE(flash_address); #ifdef isp_with_wdt set_IAPTRG_IAPGO_WDCLR; #else set_IAPTRG_IAPGO; #endif flash_address += PAGE_SIZE; } g_totalchecksum = 0; flash_address = start_address; g_programflag = 1; for(count=16;count<64;count++) { IAPCN = BYTE_PROGRAM_AP; IAPAL = flash_address&0xff; IAPAH = (flash_address>>8)&0xff; IAPFD = uart_rcvbuf[count]; #ifdef isp_with_wdt set_IAPTRG_IAPGO_WDCLR; #else set_IAPTRG_IAPGO; #endif IAPCN = BYTE_READ_AP; //program byte verify set_IAPTRG_IAPGO; if(IAPFD!=uart_rcvbuf[count]) while(1); if (CHPCON==0x43) //if error flag set, program error stop ISP while(1); g_totalchecksum=g_totalchecksum+uart_rcvbuf[count]; flash_address++; if(flash_address==AP_size) { g_programflag=0; goto END_1; } } END_1: Package_checksum(); uart_txbuf[8]=g_totalchecksum&0xff; uart_txbuf[9]=(g_totalchecksum>>8)&0xff; Send_64byte_To_UART0(); break; } } bUartDataReady = FALSE; bufhead = 0; EA=1; } /*For connect timer out */ if(g_timer0Over==1) { CALL_NOP; goto _APROM; } /*for uart time out or buffer error */ if(g_timer1Over==1) { if((bufhead<64)&&(bufhead>0)||(bufhead>64)) { bufhead=0; } } } _APROM: EA=0; MODIFY_HIRC_16(); clr_CHPCON_IAPEN; TA = 0xAA; TA = 0x55; CHPCON = 0x80; //software reset enable boot from APROM /* Trap the CPU */ while(1); }
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
发帖类勋章
等级类勋章
时间类勋章
267
5575
22
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
