[STM32F7] 进行发布版本(release)构建时会出现错误
215|0
jerry尧 发表于 2025-10-24 11:36 | 显示全部楼层 |阅读模式
为什么我进行发布版本(release)构建时会出现这些错误,而进行调试版本(debug)构建时却没有错误呢?构建前清理(clean)也没有效果。
21:46:25 **** Incremental Build of configuration Release for project I2S-RXTX-F7 ****
make -j4 all
arm-none-eabi-g++ -o "I2S-RXTX-F7.elf" @"objects.list" -larm_cortexM7lfdp_math -mcpu=cortex-m7 -T"/home/jponko/opt/STM32CubeIDE/workspace/I2S-RXTX-F7/STM32F767ZITX_FLASH.ld" -Wl,-Map="I2S-RXTX-F7.map" -Wl,--gc-sections -static -Wl,--start-group -larm_cortexM7lfdp_math -Wl,--end-group -L"/home/jponko/opt/STM32CubeIDE
/workspace/I2S-RXTX-F7/lib" --specs=nano.specs -mfpu=fpv5-d16 -mfloat-abi=hard -mthumb
-Wl,--start-group -lc -lm -lstdc++ -lsupc++ -Wl,--end-group
/opt/st/stm32cubeide_1.6.1/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.linux64_1.5.0.202011040924/tools/bin/../lib/gcc/arm-none-eabi/9.3.1/../../../../arm-none-eabi/bin/ld: Core/Startup/startup_stm32f767zitx.o: in function `LoopFillZerobss':
(.text.Reset_Handler+0x32): undefined reference to `main'
collect2: error: ld returned 1 exit status
make: *** [makefile:80: I2S-RXTX-F7.elf] Error 1
"make -j4 all" terminated with exit code 2. Build might be incomplete.
21:46:26 Build Failed. 3 errors, 0 warnings. (took 524ms)
